# Compatibility with Python 2.7.
from __future__ import print_function
# The directory containing the vray shared object should be present in the PYTHONPATH environment variable.
# Try to import the vray module from VRAY_SDK/python, if it is not in PYTHONPATH
import sys, os
VRAY_SDK = os.environ.get('VRAY_SDK')
if VRAY_SDK:
sys.path.append(os.path.join(VRAY_SDK, 'python'))
import vray
# When VRAY_SDK is set, the App SDK binding will search for the VRaySDKLibrary binary and its dependencies inside VRAY_SDK/bin.
# If the directory structure of a product that uses App SDK doesn't include the binaries inside a /bin folder, VRAY_App SDK_BIN can be used instead of VRAY_SDK.
# In that case, the App SDK binding will try to load the binaries directly from the folder that VRAY_APPSDK_BIN points at.
# If no environment variables are set, the search path could be passed as the parameter of the function vray.setSDKLibraryPath(path)
with vray.VRayRenderer() as renderer:
# Create a new static geometry
mesh = renderer.classes.GeomStaticMesh()
# Assign a box geometry
mesh.vertices=vray.VectorList(
vray.Vector(-26.7598, -30.5826, 0.0),
vray.Vector(26.7598, -30.5826, 0.0),
vray.Vector(-26.7598, 30.5826, 0.0),
vray.Vector(26.7598, 30.5826, 0.0),
vray.Vector(-26.7598, -30.5826, 125.389),
vray.Vector(26.7598, -30.5826, 125.389),
vray.Vector(-26.7598, 30.5826, 125.389),
vray.Vector(26.7598, 30.5826, 125.389)
mesh.faces=vray.IntList(
0, 2, 3,
3, 1, 0,
4, 5, 7,
7, 6, 4,
0, 1, 5,
5, 4, 0,
1, 3, 7,
7, 5, 1,
3, 2, 6,
6, 7, 3,
2, 0, 4,
4, 6, 2
mesh.normals=vray.VectorList(
vray.Vector(0.0, 0.0, -1.0), vray.Vector(0.0, 0.0, -1.0), vray.Vector(0.0, 0.0, -1.0),
vray.Vector(0.0, 0.0, 1.0), vray.Vector(0.0, 0.0, 1.0), vray.Vector(0.0, 0.0, 1.0),
vray.Vector(0.0, -1.0, 0.0), vray.Vector(0.0, -1.0, 0.0), vray.Vector(0.0, -1.0, 0.0),
vray.Vector(1.0, 0.0, 0.0), vray.Vector(1.0, 0.0, 0.0), vray.Vector(1.0, 0.0, 0.0),
vray.Vector(0.0, 1.0, 0.0), vray.Vector(0.0, 1.0, 0.0), vray.Vector(0.0, 1.0, 0.0),
vray.Vector(-1.0, 0.0, 0.0), vray.Vector(-1.0, 0.0, 0.0), vray.Vector(-1.0, 0.0, 0.0),
mesh.faceNormals=vray.IntList(
0, 1, 2,
3, 4, 5,
6, 7, 8,
9, 10, 11,
12, 13, 14,
15, 16, 17,
18, 19, 20,
21, 22, 23,
24, 25, 26,
27, 28, 29,
30, 31, 32,
33, 34, 35
# Create a BRDF with diffuse color
newBRDF = renderer.classes.BRDFDiffuse()
# We specify solid green color
newBRDF.color = vray.Color(0.0, 1.0, 0.0)
# Create a new material with single BRDF
newMaterial = renderer.classes.MtlSingleBRDF()
# Assign the BRDF to the material
newMaterial.brdf = newBRDF
# Create a new node for the box
newNode = renderer.classes.Node()
newNode.material = newMaterial # Assign the new material to the new node
newNode.geometry = mesh # Assign the mesh
# We must specify transform in order to position the box in the world
newNode.transform = vray.Transform(vray.Matrix(vray.Vector(1.0, 0.0, 0.0),
vray.Vector(0.0, 0.0, 1.0)), vray.Vector(-20.6777, 131.6402, 0))
# Create the light
light = renderer.classes.LightRectangle()
# We must specify transform in order to position the light in the world
light.transform = vray.Transform(vray.Matrix(vray.Vector(1.0, 0.0, 0.0),
vray.Vector(0.0, 0.0, 1.0)), vray.Vector(-20.6777, 131.6402, 150))
# Set white color
light.color = vray.AColor(1.0, 1.0, 1.0)
# Increase the light's size (by default it's 1x1)
light.u_size = 50
light.v_size = 50
# Increase the default intensity
light.intensity = 100
# Create the camera
renderView = renderer.classes.RenderView()
# Position the camera towards the box
renderView.transform=vray.Transform(vray.Matrix(vray.Vector(0.92, 0.37, 0.0), vray.Vector(0.12, -0.3, 0.94), vray.Vector(0.35, -0.87, -0.32)), vray.Vector(59, -140, 44))
# Set Field of view (horizontal) in radians
renderView.fov=1.65806
renderer.start()
renderer.waitForRenderEnd(60000)
#define VRAY_RUNTIME_LOAD_PRIMARY
#include "vraysdk.hpp"
#include "vrayplugins.hpp"
using namespace VRay;
using namespace VRay::Plugins;
int main(int argc, char* argv[]) {
// The first parameter is the VRaySDKLibrary DLL/SO/DYLIB name (full path optional). Here the default name is used.
// When VRAY_SDK is set, the App SDK binding will search for the VRaySDKLibrary binary and its dependencies inside VRAY_SDK/bin.
// If the directory structure of a product that uses App SDK doesn't include the binaries inside a /bin folder, VRAY_APPSDK_BIN can be used instead of VRAY_SDK.
// In that case, the App SDK binding will try to load the binaries directly from the folder that VRAY_APPSDK_BIN points at.
// If no environment variables are set, the full path containing the VRaySDKLibrary filename could be passed as the first parameter.
// The second parameter is enable or disable the V-Ray Frame Buffer (VFB)
VRayInit init(NULL, true);
// Create an instance of VRayRenderer with default options
VRayRenderer renderer;
// Create a new static geometry
GeomStaticMesh mesh = renderer.newPlugin<GeomStaticMesh>();
// Assign a box geometry
Vector vertices[] = {
mesh.set_vertices(VectorList(vertices, vertices + 8));
int faces[] = {
0, 2, 3,
3, 1, 0,
4, 5, 7,
7, 6, 4,
0, 1, 5,
5, 4, 0,
1, 3, 7,
7, 5, 1,
3, 2, 6,
6, 7, 3,
2, 0, 4,
4, 6, 2
mesh.set_faces(IntList(faces, faces + 36));
Vector normals[] = {
Vector(0.0, 0.0, -1.0), Vector(0.0, 0.0, -1.0), Vector(0.0, 0.0, -1.0),
Vector(0.0, 0.0, 1.0), Vector(0.0, 0.0, 1.0), Vector(0.0, 0.0, 1.0),
Vector(0.0, -1.0, 0.0), Vector(0.0, -1.0, 0.0), Vector(0.0, -1.0, 0.0),
Vector(1.0, 0.0, 0.0), Vector(1.0, 0.0, 0.0), Vector(1.0, 0.0, 0.0),
Vector(0.0, 1.0, 0.0), Vector(0.0, 1.0, 0.0), Vector(0.0, 1.0, 0.0),
Vector(-1.0, 0.0, 0.0), Vector(-1.0, 0.0, 0.0), Vector(-1.0, 0.0, 0.0),
mesh.set_normals(VectorList(normals, normals + 36));
int faceNormals[] = {
0, 1, 2,
3, 4, 5,
6, 7, 8,
9, 10, 11,
12, 13, 14,
15, 16, 17,
18, 19, 20,
21, 22, 23,
24, 25, 26,
27, 28, 29,
30, 31, 32,
33, 34, 35
mesh.set_faceNormals(IntList(faceNormals, faceNormals + 36));
// Create a BRDF with diffuse color
BRDFDiffuse newBRDF = renderer.newPlugin<BRDFDiffuse>();
// We specify solid green color
newBRDF.set_color(Color(0.0, 1.0, 0.0));
// Create a new material with single BRDF
MtlSingleBRDF newMaterial = renderer.newPlugin<MtlSingleBRDF>();
// Assign the BRDF to the material
newMaterial.set_brdf(newBRDF);
// Create a new node for the box
Node newNode = renderer.newPlugin<Node>();
newNode.set_material(newMaterial); // Assign the new material to the new node
newNode.set_geometry(mesh); // Assign the mesh
// We must specify transform in order to position the box in the world
newNode.set_transform(Transform(Matrix(Vector(1.0, 0.0, 0.0),
Vector(0.0, 0.0, 1.0)), Vector(-20.6777, 131.6402, 0)));
// Create the light
LightRectangle light = renderer.newPlugin<LightRectangle>();
// We must specify transform in order to position the light in the world
light.set_transform(Transform(Matrix(Vector(1.0, 0.0, 0.0),
Vector(0.0, 0.0, 1.0)), Vector(-20.6777, 131.6402, 150)));
// Set white color
light.set_color(AColor(1.0, 1.0, 1.0));
// Increase the light's size (by default it's 1x1)
light.set_u_size(50);
light.set_v_size(50);
// Increase the default intensity
light.set_intensity(100);
// Create the camera
RenderView renderView = renderer.newPlugin<RenderView>();
// Position the camera towards the box
renderView.set_transform(Transform(Matrix(Vector(0.92, 0.37, 0.0),
Vector(0.35, -0.87, -0.32)), Vector(59.0, -140, 44)));
// Set Field of view(horizontal) in radians
renderView.set_fov(1.65806f);
// Start rendering
renderer.startSync();
// Wait until rendering has finished or 60000ms have elapsed
renderer.waitForRenderEnd(60000);
return 0;
using System;
using System.IO;
using VRay;
using VRay.Plugins;
namespace ConsoleApplication1
class Program
// If no environment variables are set, the search path could be passed as the parameter of the function Globals.SetSDKLibraryPath(path);
static string SCENE_PATH = Path.Combine(Environment.GetEnvironmentVariable("VRAY_SDK"), "scenes");
static void HandleStartEvent(object source, System.EventArgs e)
Console.WriteLine("The V-Ray render process has started!");
static void Main(string[] args)
try
using (VRayRenderer renderer = new VRayRenderer())
GeomStaticMesh mesh = renderer.NewPlugin<GeomStaticMesh>();
Vector[] vertices = new Vector[] {
new Vector(-26.7598, -30.5826, 0.0),
new Vector(26.7598, -30.5826, 0.0),
new Vector(-26.7598, 30.5826, 0.0),
new Vector(26.7598, 30.5826, 0.0),
new Vector(-26.7598, -30.5826, 125.389),
new Vector(26.7598, -30.5826, 125.389),
new Vector(-26.7598, 30.5826, 125.389),
new Vector(26.7598, 30.5826, 125.389)
mesh.Vertices = vertices;
int[] faces = new int[]{
0, 2, 3,
3, 1, 0,
4, 5, 7,
7, 6, 4,
0, 1, 5,
5, 4, 0,
1, 3, 7,
7, 5, 1,
3, 2, 6,
6, 7, 3,
2, 0, 4,
4, 6, 2
mesh.Faces = faces;
Vector[] normals = new Vector[] {
new Vector(0.0, 0.0, -1.0), new Vector(0.0, 0.0, -1.0), new Vector(0.0, 0.0, -1.0),
new Vector(0.0, 0.0, 1.0), new Vector(0.0, 0.0, 1.0), new Vector(0.0, 0.0, 1.0),
new Vector(0.0, -1.0, 0.0), new Vector(0.0, -1.0, 0.0), new Vector(0.0, -1.0, 0.0),
new Vector(1.0, 0.0, 0.0), new Vector(1.0, 0.0, 0.0), new Vector(1.0, 0.0, 0.0),
new Vector(0.0, 1.0, 0.0), new Vector(0.0, 1.0, 0.0), new Vector(0.0, 1.0, 0.0),
new Vector(-1.0, 0.0, 0.0), new Vector(-1.0, 0.0, 0.0), new Vector(-1.0, 0.0, 0.0),
mesh.Normals = normals;
int[] faceNormals = new int[]{
0, 1, 2,
3, 4, 5,
6, 7, 8,
9, 10, 11,
12, 13, 14,
15, 16, 17,
18, 19, 20,
21, 22, 23,
24, 25, 26,
27, 28, 29,
30, 31, 32,
33, 34, 35
mesh.FaceNormals = faceNormals;
BRDFDiffuse newBRDF = renderer.NewPlugin<BRDFDiffuse>();
newBRDF.Color = new Color(0.0f, 1.0f, 0.0f);
MtlSingleBRDF newMaterial = renderer.NewPlugin<MtlSingleBRDF>();
newMaterial.Brdf = newBRDF;
Node newNode = renderer.NewPlugin<Node>();
newNode.Material = newMaterial; // Assign the new material to the new node
newNode.Geometry = mesh; // Assign the mesh
newNode.Transform = new Transform(new Matrix(new Vector(1.0, 0.0, 0.0),
new Vector(0.0, 0.0, 1.0)), new Vector(-20.6777, 131.6402, 0));
// Create the light
LightRectangle light = renderer.NewPlugin<LightRectangle>();
light.Transform = new Transform(new Matrix(new Vector(1.0, 0.0, 0.0),
new Vector(0.0, 0.0, 1.0)), new Vector(-20.6777, 131.6402, 150));
// Set white color
light.Color = new AColor(1.0f, 1.0f, 1.0f);
light.USize = 50;
light.VSize = 50;
light.Intensity = 100;
RenderView renderView = renderer.NewPlugin<RenderView>();
renderView.Transform = new Transform(new Matrix(new Vector(0.92, 0.37, 0.0),
new Vector(0.12, -0.3, 0.94),
new Vector(0.35, -0.87, -0.32)), new Vector(59, -140, 44));
// Set Field of view (horizontal) in radians
renderView.Fov = 1.65806f;
renderer.Start();
renderer.WaitForRenderEnd(60000);
catch (Exception ex)
Console.WriteLine(ex.ToString());
var path = require('path');
var vray = require(path.join(process.env.VRAY_SDK, 'node', 'vray'));
// If no environment variables are set, the search path could be passed as the parameter of the function vray.setSDKLibraryPath(path);
var renderer = vray.VRayRenderer();
var mesh = renderer.classes.GeomStaticMesh();
mesh.vertices = vray.VectorList(
mesh.faces = vray.IntList(
0, 2, 3,
3, 1, 0,
4, 5, 7,
7, 6, 4,
0, 1, 5,
5, 4, 0,
1, 3, 7,
7, 5, 1,
3, 2, 6,
6, 7, 3,
2, 0, 4,
4, 6, 2
mesh.normals = vray.VectorList(
mesh.faceNormals = vray.IntList(
0, 1, 2,
3, 4, 5,
6, 7, 8,
9, 10, 11,
12, 13, 14,
15, 16, 17,
18, 19, 20,
21, 22, 23,
24, 25, 26,
27, 28, 29,
30, 31, 32,
33, 34, 35
var newBRDF = new renderer.classes.BRDFDiffuse();
newBRDF.color = new vray.Color(0.0, 1.0, 0.0);
var newMaterial = new renderer.classes.MtlSingleBRDF();
newMaterial.brdf = newBRDF;
var newNode = renderer.classes.Node();
newNode.material = newMaterial; // Assign the new material to the new node
newNode.geometry = mesh; // Assign the mesh
vray.Vector(0.0, 0.0, 1.0)), vray.Vector(-20.6777, 131.6402, 0));
// Create the light
var light = renderer.classes.LightRectangle();
vray.Vector(0.0, 0.0, 1.0)), vray.Vector(-20.6777, 131.6402, 150));
// Set white color
light.color = new vray.AColor(1.0, 1.0, 1.0);
light.u_size = 50;
light.v_size = 50;
light.intensity = 100;
var renderView = renderer.classes.RenderView();
renderView.transform = vray.Transform(vray.Matrix(vray.Vector(0.92, 0.37, 0.0),
vray.Vector(0.35, -0.87, -0.32)), vray.Vector(59, -140, 44));
renderView.fov = 1.65806;
// Start rendering
renderer.start();
renderer.waitForRenderEnd(60000, function () {
renderer.close();
