In this section we'll talk about the animation which one can produce using V-Ray:
Animations with Moving Objects
Generally V-Ray is able to animate all numeric/color values of plugin properties - so animation could be every plugin property which value is changing over time.
Flythrough Animations
Scenes where the camera "flies through" the scene, e.g. has its position animated. The other name which is used is "walk-through" animations.
