Here we will discuss how to properly link and load the App SDK and V-Ray dynamic libraries.
Where we refer to .dll files for Windows, just treat this as lib.so or lib*.dylib for Linux and macOS. |
There are four DLL files or groups that need to be loaded at various stages:
In most cases this is done with just one line of code, but the API allows for custom file layouts through additional settings.
There is no binding DLL because the binding is header only. There are two ways to link the main SDK library described in the following subsections:
In this case you need to use the VRaySDKLibrary.lib import library when building on Windows and the -lVRaySDKLibrary linker switch on Linux/macOS. The VRaySDKLibrary dynamic library will have to be on the system paths for loading dynamic libraries before you run the application: PATH on Windows, LD_LIBRARY_PATH on Linux, DYLD_LIBRARY_PATH on macOS. You don't need to define additional preprocessor macros.
To avoid having to modify the system search paths you may load the library dynamically at runtime. Exactly one of your source files has to define the VRAY_RUNTIME_LOAD_PRIMARY macro before including vraysdk.hpp
. The rest of the sources have to define VRAY_RUNTIME_LOAD_SECONDARY before including the header. The VRAY_RUNTIME_LOAD_PRIMARY source file should create a VRayInit instance that lasts for the lifetime of the application. It takes an optional path to VRaySDKLibrary.dll, including the filename.
The runtime loading version of VRayInit also provides a getSDKLibraryErrorString() method for diagnosing failures.
The .Net binding is implemented in two assemblies: VRaySDK.Net.dll
and VRaySDK.Net.Plugins.dll
that your application has to reference. The second assembly can be omitted if you don't need the concrete Plugin classes, but usually it is needed.
The Python binding is implemented in vray.pyd
on Windows or vray.so
on Linux and macOS. It should either be installed in your site-packages directory or you would have to add its location to the PYTHONPATH environment variable.
The Node.js binding is implemented in the VRay.node
binary file, but should be loaded through the vray.js
script which adds a few helpers to it.
You can use a static method to add a search path for VRaySDKLibrary.dll if it is not in the system PATH. You have to do this before calling any other App SDK methods.
.Net
Use Globals.SetSDKLibraryPath(search_path)
Python and Node.js
When you import or require the vray module, it will try to load VRaySDKLibrary.dll. It may fail. You can call vray.setSDKLibraryPath(search_path)
to specify a search path and force VRaySDKLibrary.dll (re)loading. The function returns 'true' on success. You can get extended info by calling vray.getSDKLibraryErrorString()
The directory containing vray.dll and the other DLLs from the original App SDK bin
directory needs to be on the system library search path (PATH on Windows, LD_LIBRARY_PATH on Linux, DYLD_LIBRARY_PATH). The VRAY_PATH
environment variable can be set to an alternative location.
IMPORTANT: The VRAY_PATH
variable may be set on the user system from another V-Ray install (such as V-Ray Standalone). Don't rely on it being empty! It can cause crashes due to loading mismatched DLLs. You should also make sure PATH/LD_LIBRARY_PATH/DYLD_LIBRARY_PATH does not contain other V-Ray paths on the system or that your path is at the front.
This is how the render plugins are loaded: 1. A string containing semicolon separated paths is constructed from the optional RendererOptions::pluginLibraryPath
parameter - this is usually empty, but allows for overriding the defaults. 2. The value of the VRAY_PATH
environment variable is appended with "/plugins" and this is appended to the list. If the variable is not set, the path of VRaySDKLibrary is appended instead (again appended with "/plugins"). 3. The path list is passed to the V-Ray plugin manager to load the plugin classes from vray_*.dll
or libvray_*.so
If you have third party V-Ray render plugins (textures, geometry or anything) you should either copy them in the same plugins
directory or add their directory to the RendererOptions::pluginLibraryPath
parameter as described above. The file names should match the template vray_*.dll
or libvray_*.so
The RendererOptions::pluginLibraryPath
parameter could be optionally set to a path, which contains the rt_cuda.dll/so and rt_opencl.dll/so libraries if they are not at their default location next to vray.dll and VRaySDKLibrary.dll.
You should make sure that the respective runtime or a compatible one is available where you deploy the SDK. Currently the App SDK is built using:
You may want to clean up the binary folder to reduce the installation size of your application. You can remove some of the files there if you know for a fact that you will never use the features that require them:
