This is a V-Ray application that is common across all V-Ray installations.
The VRImg to OpenEXR converter is both a command-line utility and a simple GUI application that can be used to convert .vrimg image files to .exr files in OpenEXR format. The .vrimg file format stores the rendered image with all available render elements. The V-Ray Image to EXR Converter converts .vrimg files to EXR format so the render elements may be loaded into compositing software, where they can be used for Back-to-Beauty compositing or for other adjustments and fine-tuning at the render element level.
Installation
This tool comes with the V-Ray for Rhino installation. You can start the vrimg2exr executable from C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\tools .
