MainEnable – Enables the V-Ray Toon effect. See the Toon Effect example below. Line Color – Specifies the color of the outlines using a map. See the Line Color example below. Line Width– Specifies the width of the outlines using a map. Width Units – Specifies if the width of the lines is measured in Pixels or in World units. Use Inner Line Controls – When enabled, uses the same Line Color/Width parameter values for both silhouette and inner edges. Inner Line Width – Specifies the cartoon line width of inner lines. Line Inner Color – Specifies the color of the cartoon line at inner edges. Opacity – Specifies the opacity of the outlines using a map. OptionsCompensate Exposure – When enabled, the VRayToon compensates the Line Color brightness to adjust for any Exposure correction from a V-Ray Physical Camera. Hide Inner Edges – Determines whether lines are created for parts of the same object with varying surface normals (for example, at the inside edges of a box). Material Edges – When enabled, renders lines on the material boundaries if the mesh has multiple materials. Toon Render Elements Only – When enabled, applies only to toon render channels. Normal Threshold – Determines when lines are created for parts of the same object with varying surface normals (for example, at the inside edges of a box). A value of 0.0 means that only 90 degrees or larger angles generate internal lines. Higher values mean that more smooth normals can also generate an edge. Don't set this value to pure 1.0 as this fills curved objects completely. Overlap Threshold – Determines when outlines are created for overlapping parts of one and the same object. Lower values reduce the internal overlapping lines, while higher values produce more overlapping lines. Don't set this value to pure 1.0 as this fills curved objects completely. Outer Overlap Treshold – Determines when outer edges are created for overlapping parts of one. Min./Max. Depth – Defines the minimum/maximum distance where the depth-based Line Width takes effect. Edges at points closer than the Min Depth are rendered with the Line Width at position 0. Edges further than the Max Depth are rendered with Line Width at position 1. Show Toon Lines in Reflections – When enabled, toon lines are shown in reflections.
Trace Bias – Determines the ray bias when the outlines are traced in reflections/refractions. Depends on the size of your scene. Exclude Type – Specifies on which objects to apply the toon effect. Exclude List – Specifies if the provided list is treated as an inclusive or exclusive list. |
