This page provides information about the V-Ray Surface Luminance Texture.
V-Ray's extra attributes for the Surface Luminance node allow control of luminance calculation.
The most common workflow for the Surface Luminance node attributes is to connect the node to a floating texture input slot of a V-Ray ExtraTex render element. This way you can control the Luminance mode showing in the ExtraTex channel.
UI Path: ||mat Network|| > V-Ray > Texture: Procedural > V-Ray Surface Luminance
