Copy To Clipboard – Copies the error message or warning to the clipboard. Clear Log – Сlears all current error messages and warnings. Show – Allows to select which messages to show: Errors Only or Errors and Warnings. Select Object – Selects the object where the problem is found. Learn More – Opens a Chaos Held Center article related to the error/warning with various possible solutions. Dismiss – Removes the current notification from the log. Ignore Similar Messages – Stops showing similar messages. Chaos Corona Helpdesk – Open the Chaos Help Center. |
