This page provides information about the VRayUserInteger texture in V-Ray for Cinema 4D.
The VRayUserInteger texture allows the user to read and return a single integer value from the currently shaded object as a result. This can be useful if the same material or texture is applied to several objects in the scene, but you want to control some of its properties with user-defined properties. Visit the User Attributes Workflow page for information and tutorials on user-defined properties
UI Paths:
||Texture|| > plugins > V-Ray > VRayUserInteger
||Texture|| > V-Ray > VRayUserInteger
Properties
User Attribute – Specifies the name of the user attribute that is looked up and returned from this utility texture.
Default value – Specifies the value to return if the user attribute is not found on the shaded object.
