This page provides information about the V-Ray Hair Sampler texture in Cinema 4D.
The VRayHairSampler is an utility texture that provides extra output attributes which can be used when shading hair. Used with the Hair Next Material, this texture allows you to map color, incandescence, and transparency along the length of a hair strand, as well as the ability to randomize such properties on a per-strand basis to create stunning hair looks. UI Path: Texture > V-Ray > VRayHairSampler |
Texture – Specifies a texture to be mapped when the Output is Position Across Strand. Output – Determines how the texture is mapped. See the examples below for more information. Distance Along Strand – Provides information about the shaded part of the hair strand. For the base of the strand, the value is 0.0, and for the tip it is 1.0. With this option, a texture can be mapped along each strand regardless of each strand's length. Distance Along Strand Absolute – Provides information about the shaded part of the hair strand using absolute distance. This option uses the Hair Max Distance parameter to allow length-dependent mapping. For instance, when used with a gradient, this allows for all hair strands (regardless of length) to have a root color all up to the same length followed by the rest of the ramp. Note that when Hair Max Distance is lower than the actual length of the hair strand, the gradient is repeated over the length of the hair strand. Position Across Strand – Allows textures to be mapped across each strand. Random By Strand – Provides an unique random floating point value for each strand in the hair system, which allows shading each strand with a random color sampled from a texture. Hair Max Distance – Sets the max strand length when using Distance Along Strand Absolute. Typically, this value should be equal to the longest strand of hair. This option is mappable, allowing different parts in a hair system to have different max lengths.
Common Setup Examples
Random by Strand
The V-Ray Hair Sampler is set up by connecting an output from VRayHairSampler to a 2D driven texture; most commonly a ramp. This example shows VRayHairSampler's Random By Strand attribute to control the V channel of a ramp connected to a VRayHairNextMtl's Diffuse Color parameter.
The ramp is driven by the Random By Strand parameter. The ramp is connected to the VRayHairNextMtl's Diffuse Color. Multiple colors are set with no interpolation. |
Resulting render |
Here, VRayHairSampler is used to create variation in the color along the length of a hair strand to give hair a more natural look. This is done by using the VRayHairSampler's Distance Along Strand attribute to control the V channel of a ramp connected to a VRayHairNextMtl's Diffuse Color parameter. Note that the full ramp is mapped along each strand regardless of the strand's length.
The ramp is driven by the Distance Along Strand parameter. The ramp is connected to the VRayHairNextMtl's Diffuse Color. Multiple colors are set with smooth interpolation. |
Resulting Render |
This example uses the VRayHairSampler's Distance Along Strand Absolute attribute. Similar to the previous example, it controls the V channel of a ramp connected to a VRayHairNextMtl's Diffuse Color parameter. However, this attribute uses the Hair Max Distance to allow length-dependent mapping. The renders below use the same setup and ramp but with different Hair Max Distance values. Note that when Hair Max Distance is lower than the actual length of the hair strand, the gradient is repeated over the length of the hair strand.
The ramp is driven by the Distance Along Strand Absolute parameter. The ramp is connected to the VRayHairNextMtl's Diffuse Color. Multiple Colors are set with smooth interpolation. |
This final example uses the VRayHairSampler's Position Across Strand option. Unlike the previous examples, it controls the U channel of a ramp connected to a VRayHairNextMtl's Transparency parameter. Note how the hair color looks more transparent to the sides of each hair compared to the other render which did not use a ramp.
The ramp is driven by the Position Across Strand parameter. The ramp is connected to the VRayHairNextMtl's Transparency. Grayscale map is set with Linear interpolation. |
