Color – Specifies a custom color that multiplies the texture connected. Texture – Specifies a texture that will be combined with the color. Mix Strength – Specifies a multiplier used to blend between the color and the texture. Result Invert – When enabled, inverts the result of the blending effect. Result Multiplier – Specifies a multiplier for the result. If Result Invert is enabled, this is performed after the inversion. |
