This page provides information about the Bump node in V-Ray for Cinema 4D.
The Bump gives the ability to add bump map and normal map effects when using any material.
Connect a material into the Bump node to add additional bump or normal map functionality. Stacking multiple Bump nodes together can create a more complex surface material by allowing the use of several bump and or normal maps together easily.
Base Material  – Allows the user to select the base material to which the bump/normal effect is added.
Map Type – Allows the user to specify whether a bump map or a normal map effect is added to the base material.
Bump Map
Normal map in tangent space
Normal map in object space
Normal map in screen space
Normal map in world space
From texture bump output
Explicit
Texture Map – Specifies the bump/normal map that is used.
Bump Multiplier – A multiplier for the bump/normal effect.
Bump Delta Scale – Scale for sampling the bitmap when using bump mapping. The exact value is calculated automatically by V-Ray, but can be scaled here.
Bump Shadows – When enabled, V-Ray considers the bump maps when rendering shadows produced by objects with the bump material applied to them.
