Denoise – Specifies whether to denoise this render element.
Common Uses
The Atmosphere Render Element is useful for changing the appearance of the atmosphere and volumetric effects in a rendered image using compositing or image editing software. In the example, fog is generated using the Environment Fog. A warmer color is assigned to the fog and the intensity is increased using the Atmosphere RE.
Compositing
The Atmosphere Render Element is Added to theBeauty render to form the final image.
