Color (Color) – Specifies the color of the lines. Opacity (Number) – Specifies the opacity of the outlines. Width Type (Integer) – Controls the width measurement units. Width (Number) – Specifies the width of the outlines (in the units set in Width Type parameter). Inner On (Boolean) – Enables rendering of the inner lines. Inner Color (Color) – Specifies the color of the inner lines. Inner Width (Number) – Specifies the width of the inner lines (in the units set in Width Type parameter). Excl. Type (Number) – When set to Exclude(0) - the outlines affect all scene objects except for those in the Exclude List. When set to Include(1) - the outlines affect only the scene objects from the Exclude List. Exclude (Generic Data) – Specifies which scene objects will be affected by the outlines. |
