This page provides information about the Two Sided material in V-Ray for Rhino.
||V-Ray Asset Editor|| > Materials (right-click) > Two Sided
||V-Ray Asset Editor|| > Materials (left-click) > Two Sided
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Render Settings.
In this example, the lampshade uses a Two Sided material with only a Front material connected (VRayMtl). A V-Ray sphere light is used to illuminate the inside. Translucency is shown here with grayscale values (RGB).
In this example, the leaves have both front and back materials connected to the Two Sided Material. Notice how the leaves change when the Translucency value (shown in RGB) is changed. The last render uses a Translucency grayscale map.
