There are some context options that V-Ray materials have. The Search Scene field will search the assets by name from all the categories that are selected. Right-click on any material in the Material's list for a context menu to appear. You can apply the material to the currently selected object, object's face, or to a layer. Use the Apply To Layer and select any layer to apply the material. Use the Apply to Selection option and select an object or an object face to apply the material on it. The Select Objects in Scene option allows selection of groups or components in the viewport that the material will be applied to. Select a material to Use as Replacement for any other material in the scene. Then, use the Replace In Scene option over the chosen material or the Replace All References to replace this material in all places that is used. For example, a Generic material is used as part of Two Sided and Multi Material. Replace All References will overwrite the Generic material in both Two Sided and Multi Material. The Asset lists have some additional multi-selection functionalities: - Ctrl on deselected item - Adds to the selection;
- Ctrl on selected item - Removes it from the selection;
- Ctrl + A - Selects all items in the list/category;
- Shift + Left-click - expands the range of the current selection;
- Click + Drag - Leaves only the clicked item selected;
- Right-Click on deselected item - Shows the context menu for the item, selects the item and deselects all other items;
- Right-Click on selected item - Shows the context menu for the item and doesn't change the selection.
