UI Path: ||Preferences|| > Renderer > Corona > Interactive Rendering |
# Of Threads Override – Number of cores to use for interactive rendering. Positive values work in a straightforward way, a value of 0 uses all system cores, a value of -1 uses all cores but 1, a value of -2 uses all but 2, etc. |
Image Upscaling Factor – Specifies an upscaling factor for the image rendered during interactive rendering. By increasing this value, render resolution gets reduced which makes the interactive rendering more responsive. This is useful for High-DPI displays. Maximum Resolution – This setting specifies the maximum resolution at which the interactive rendering will be displayed in the viewport. IR Subsampling – The number of pixelated passes that are determined by the IR subsampling value. Adjust render resolution to VFB – When enabled, the image output size is adjusted by the VFB window size. The adjustment is only available while the Interactive Rendering is running. If disabled, the VFB uses the image output size defined in the Output section from the Render Settings. |
