This section holds information about the V-Ray Application SDK (App SDK). It is intended for developers interested in integrating V-Ray into new applications or making some other custom software, be it script or web-based, etc.
Did you know you can use Chaos Vantage via V-Ray App SDK? If not you can look into this tutorial how you can add some lines to your V-Ray App SDK code to use this real-time GPU renderer.
If you are interested in evaluating V-Ray App SDK, fill out the Evaluation Request form.
The App SDK can't be used to write custom render plugins (i.e. shaders). If you want to write one, you can use the C++ SDK bundled with V-Ray Standalone, V-Ray for 3ds Max or V-Ray for Maya.
