This page provides information about the Diffuse render element in V-Ray for Rhino.
Shows the color or texture used in a material Diffuse slot.  All the scene objects appear flat in this element with no lighting information included. The colors are the actual colors set in the material definition and each texture appears as it does in the texture (file) itself.
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Diffuse
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements > Diffuse
Denoise – Specifies whether to denoise this render element.
