This page offers a quick starting point on offline rendering images and animation sequences in Chaos Vantage.
.wiki-content .confluence-embedded-file-wrapper.confluence-embedded-manual-size {
    vertical-align: text-bottom;
@media only screen and (min-width:1550px) {
iframe {
max-width: 600px;
text-align:right;
Steps
1. HQ Snapshot rendering.
You can render a high quality snapshot from the current view. Go to Tools > Render a High Quality Snapshot or use the button in the bottom toolbar.
In the pop-up window, you can set the Resolution, Denoiser and the Samples as well as other parameters related to the render. Here, you can also select the camera type output: Perspective, Cube 6x1 (single or stereo), Stereo Cube 6x1, Spherical (single or stereo), Stereo Spherical, or Orthographic.
Choose the output directory, name and format.
When the render is in progress, you can Stop and save the frame if the quality is sufficient, or Pause, or Abort the render.
2. HQ Sequence rendering.
You can also render a high quality sequence from a set of camera sequences or imported scene animation in the animation editor. Go to Tools > Render a High Quality Sequence or use the button in the bottom toolbar.
In the pop-up window, you can set similar parameters like in the High Quality Snapshot - Resolution, Denoiser, Samples, Camera type as well as other parameters.
In both windows you can also enable the Save as defaults option to set the current output settings as your default.
For additional details, check the Render Setup page.
The more Samples you use, the better the quality of the render, but at the cost of render time. The larger the resolution you set, the more resources(RAM and VRAM) are needed.
