VRay SDK for C++
Loading...
Searching...
No Matches
VRay::Plugins::Node Member List
This is the complete list of members for VRay::Plugins::Node, including all inherited members.
get_bake_subdiv_filepath(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_geometry(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_is_instance_prototype(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_lights(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_map_channels(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_material(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_nsamples(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_object_properties(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_object_space_displacement(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_objectID(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_pivot_offset(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_primary_visibility(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_scene_name(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_time_for_geometry(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_transform(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_use_time_for_geometry(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_user_attributes(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_user_attributes_bin(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_visible(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
get_volume(double time=TiMe::Default()) constVRay::Plugins::Nodeinline
getAColor(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getAColor(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getAColor(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getAColor(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getBool(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getBool(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getBool(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getBool(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getCategories() constVRay::Plugin
getColor(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getColor(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getColor(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getColor(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getColorList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getColorList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getColorList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getColorList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getDouble(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getDouble(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getDouble(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getDouble(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getFloat(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getFloat(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getFloat(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getFloat(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getFloatList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getFloatList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getFloatList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getFloatList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getInt(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getInt(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getInt(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getInt(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getIntegerID() const noexceptVRay::Plugin
getIntList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getIntList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getIntList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getIntList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getKeyframeTimes(const char *propertyName) constVRay::Plugin
getKeyframeTimes(const std::string &propertyName) constVRay::Plugin
getKeyframeTimes(const char *propertyName, bool &ok) constVRay::Plugin
getKeyframeTimes(const std::string &propertyName, bool &ok) constVRay::Plugin
getMatrix(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getMatrix(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getMatrix(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getMatrix(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getMeta() constVRay::Plugin
getName() constVRay::Plugin
getPlugin(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getPlugin(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getPlugin(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getPlugin(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getPluginList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getPluginList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getPluginList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getPluginList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getPropertyRuntimeMeta(const char *propertyName) constVRay::Plugin
getPropertyRuntimeMeta(const std::string &propertyName) constVRay::Plugin
getPropertyState(const char *propertyName) constVRay::Plugin
getPropertyState(const std::string &propertyName) constVRay::Plugin
getRenderer() const noexceptVRay::Plugin
getString(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getString(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getString(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getString(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getStringList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getStringList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getStringList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getStringList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getTransform(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getTransform(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getTransform(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getTransform(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getTransformList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getTransformList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getTransformList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getTransformList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getType()VRay::Plugins::Nodeinlinestatic
VRay::Plugin::getType() constVRay::Plugin
getTypeId()VRay::Plugins::Nodeinlinestatic
VRay::Plugin::getTypeId() const noexceptVRay::Plugin
getValue(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getValue(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getValue(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getValue(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getValueAsString(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getValueAsString(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getValueAsString(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getValueAsString(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getValueList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getValueList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getValueList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getValueList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getVector(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getVector(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getVector(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getVector(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getVectorList(const char *propertyName, double time=TiMe::Default()) constVRay::Plugin
getVectorList(const std::string &propertyName, double time=TiMe::Default()) constVRay::Plugin
getVectorList(const char *propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
getVectorList(const std::string &propertyName, bool &ok, double time=TiMe::Default()) constVRay::Plugin
id() const (defined in VRay::Plugin)VRay::Plugininlineprotected
internalId (defined in VRay::Plugin)VRay::Pluginprotected
isEmpty() const noexceptVRay::Plugin
isNotEmpty() const noexceptVRay::Plugin
isPropertyAnimated(const char *propertyName) constVRay::Plugin
isPropertyAnimated(const std::string &propertyName) constVRay::Plugin
isValid() constVRay::Plugin
operator GeometryPluginCategory() (defined in VRay::Plugins::Node)VRay::Plugins::Nodeinline
operator!=(const Plugin &plugin) const noexceptVRay::Plugin
operator<(const Plugin &plugin) const noexcept (defined in VRay::Plugin)VRay::Plugin
operator<=(const Plugin &plugin) const noexcept (defined in VRay::Plugin)VRay::Plugin
operator=(const Plugin &plugin) noexceptVRay::Plugin
operator==(const Plugin &plugin) const noexceptVRay::Plugin
operator>(const Plugin &plugin) const noexcept (defined in VRay::Plugin)VRay::Plugin
operator>=(const Plugin &plugin) const noexcept (defined in VRay::Plugin)VRay::Plugin
Plugin(VRayRenderer &renderer, const char *name) (defined in VRay::Plugin)VRay::Pluginprotected
Plugin(VRayRenderer &renderer, InstanceId id) noexcept (defined in VRay::Plugin)VRay::Pluginprotected
Plugin(VRayRenderer &renderer, InstanceId id, PluginTypeId typeId) noexcept (defined in VRay::Plugin)VRay::Pluginprotected
Plugin(VRayRenderer &renderer, InstanceId id, int typeIdIdx) noexcept (defined in VRay::Plugin)VRay::Pluginprotected
Plugin() noexceptVRay::Plugininline
Plugin(const Plugin &plugin) noexceptVRay::Plugin
pRenderer (defined in VRay::Plugin)VRay::Pluginprotected
PropertyState enum nameVRay::Plugin
set_bake_subdiv_filepath(const char *str, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_bake_subdiv_filepath(const std::string &str, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_geometry(const PluginRef &plugin, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_is_instance_prototype(int val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_lights(const PluginList &pluginList, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_lights(const Plugin *plugins, size_t count, double time=TiMe::Default()) (defined in VRay::Plugins::Node)VRay::Plugins::Nodeinline
set_lights(const Plugin(&plugins)[count], double time=TiMe::Default()) (defined in VRay::Plugins::Node)VRay::Plugins::Nodeinline
set_map_channels(const PluginRef &plugin, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_material(const PluginRef &plugin, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_nsamples(int val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_object_properties(const PluginRef &plugin, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_object_space_displacement(int val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_objectID(int val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_pivot_offset(const Vector &vector, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_primary_visibility(bool val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_scene_name(const StringList &stringList, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_time_for_geometry(float val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_transform(const Transform &transform, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_use_time_for_geometry(bool val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_user_attributes(const char *str, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_user_attributes(const std::string &str, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_user_attributes_bin(const IntList &intList, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_user_attributes_bin(IntList &&intList, double time=TiMe::Default()) (defined in VRay::Plugins::Node)VRay::Plugins::Nodeinline
set_user_attributes_bin(const int *ints, size_t count, double time=TiMe::Default()) (defined in VRay::Plugins::Node)VRay::Plugins::Nodeinline
set_user_attributes_bin(const int(&ints)[count], double time=TiMe::Default()) (defined in VRay::Plugins::Node)VRay::Plugins::Nodeinline
set_visible(bool val, double time=TiMe::Default())VRay::Plugins::Nodeinline
set_volume(const PluginRef &plugin, double time=TiMe::Default())VRay::Plugins::Nodeinline
setArray(const char *propertyName, const int data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const int data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const float data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const float data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const double data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const double data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const Vector data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const Vector data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const Color data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const Color data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const Transform data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const Transform data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const std::string data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const std::string data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const char *const data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const char *const data[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const Plugin plugins[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, const Value values[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, const Value values[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const char *propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())VRay::Plugin
setArray(const std::string &propertyName, Value valuesToMove[], size_t count, double time=TiMe::Default())VRay::Plugin
setArrayAtTimeTemplate(const char *propertyName, size_t count, const T &value, double time) (defined in VRay::Plugin)VRay::Pluginprotected
setName(const char *newName)VRay::Plugin
setName(const std::string &newName)VRay::Plugin
setStringArrayTemplate(const char *propertyName, size_t count, LengthFn lengthAt, PointerFn pointerAt, double time) (defined in VRay::Plugin)VRay::Pluginprotected
setValue(const char *propertyName, const bool value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const bool value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const int value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const int value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const float value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const float value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const double value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const double value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const Color &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const Color &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const AColor &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const AColor &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const Vector &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const Vector &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const Matrix &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const Matrix &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const Transform &transform, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const Transform &transform, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const PluginRefT< Plugin > &pluginRef, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const char *str, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const char *str, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const std::string &str, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const std::string &str, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const Value &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const Value &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, Value &&value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, Value &&value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const ValueList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const ValueList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, ValueList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, ValueList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const Value(&arr)[count], double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const Value(&arr)[count], double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, Value(&&arr)[count], double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, Value(&&arr)[count], double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const IntList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const IntList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, IntList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, IntList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const FloatList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const FloatList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, FloatList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, FloatList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const VectorList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const VectorList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, VectorList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, VectorList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const ColorList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const ColorList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, ColorList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, ColorList &&value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const TransformList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const TransformList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const StringList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const StringList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const PluginList &value, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const PluginList &value, double time=TiMe::Default())VRay::Plugin
setValue(const char *propertyName, const void *data, size_t size, double time=TiMe::Default())VRay::Plugin
setValue(const std::string &propertyName, const void *data, size_t size, double time=TiMe::Default())VRay::Plugin
setValueAsString(const char *propertyName, const char *value)VRay::Plugin
setValueAsString(const char *propertyName, const std::string &value)VRay::Plugin
setValueAsString(const std::string &propertyName, const char *value)VRay::Plugin
setValueAsString(const std::string &propertyName, const std::string &value)VRay::Plugin
setValueAtTimeTemplate(const char *propertyName, const T &value, double time) (defined in VRay::Plugin)VRay::Pluginprotected
swap(Plugin &plugin) noexceptVRay::Plugin
toString() constVRay::Plugin
