VRay SDK for C++
This is the complete list of members for VRay::Value, including all inherited members.
| alignment (defined in VRay::Value) | VRay::Value | |
| as() | VRay::Value | |
| as() const | VRay::Value | |
| constructListWithIterators_(const T *first, const T *last) (defined in VRay::Value) | VRay::Value | protected |
| constructOnly_() noexcept (defined in VRay::Value) | VRay::Value | protected |
| constructWithValue_(T &&value) noexcept(noExcept) (defined in VRay::Value) | VRay::Value | protected |
| copyValue(const Value &value) (defined in VRay::Value) | VRay::Value | protected |
| destroyValue() noexcept (defined in VRay::Value) | VRay::Value | protected |
| get() const | VRay::Value | |
| getAColor() const | VRay::Value | |
| getBool() const | VRay::Value | |
| getColor() const | VRay::Value | |
| getColorList() const | VRay::Value | |
| getCount() const | VRay::Value | |
| getDouble() const | VRay::Value | |
| getFloat() const | VRay::Value | |
| getFloatList() const | VRay::Value | |
| getInt() const | VRay::Value | |
| getIntList() const | VRay::Value | |
| getMatrix() const | VRay::Value | |
| getPlugin() const | VRay::Value | |
| getPluginList() const | VRay::Value | |
| getPluginRef() const | VRay::Value | |
| getString() const | VRay::Value | |
| getStringList() const | VRay::Value | |
| getStringType() const | VRay::Value | |
| getTransform() const | VRay::Value | |
| getTransformList() const | VRay::Value | |
| getType() const noexcept | VRay::Value | |
| getValue_() const (defined in VRay::Value) | VRay::Value | protected |
| getValueList() const | VRay::Value | |
| getVector() const | VRay::Value | |
| getVectorList() const | VRay::Value | |
| Internal::BinaryValueBuilder (defined in VRay::Value) | VRay::Value | friend |
| Internal::BinaryValueParser (defined in VRay::Value) | VRay::Value | friend |
| Internal::MeshFileDataParser (defined in VRay::Value) | VRay::Value | friend |
| interpretAs_() (defined in VRay::Value) | VRay::Value | protected |
| interpretAs_() const (defined in VRay::Value) | VRay::Value | protected |
| isBad() const | VRay::Value | |
| isList() const | VRay::Value | |
| isOK() const | VRay::Value | |
| moveValue(Value &&value) noexcept (defined in VRay::Value) | VRay::Value | protected |
| operator!=(const Value &value) const noexcept (defined in VRay::Value) | VRay::Value | |
| operator<< (defined in VRay::Value) | VRay::Value | friend |
| operator=(const Value &value) (defined in VRay::Value) | VRay::Value | |
| operator=(Value &&value) noexcept (defined in VRay::Value) | VRay::Value | |
| operator==(const Value &value) const noexcept (defined in VRay::Value) | VRay::Value | |
| operator[](int i) | VRay::Value | |
| operator[](int i) const | VRay::Value | |
| set(int value) | VRay::Value | |
| set(float value) | VRay::Value | |
| set(double value) | VRay::Value | |
| set(bool value) | VRay::Value | |
| set(const Color &value) | VRay::Value | |
| set(const AColor &value) | VRay::Value | |
| set(const Vector &value) | VRay::Value | |
| set(const Matrix &value) | VRay::Value | |
| set(const Transform &value) | VRay::Value | |
| set(const Plugin &value) | VRay::Value | |
| set(const PluginRef &value) | VRay::Value | |
| set(const char *value) | VRay::Value | |
| set(const std::string &value) | VRay::Value | |
| set(std::string &&value) | VRay::Value | |
| set(const IntList &value) | VRay::Value | |
| set(IntList &&value) | VRay::Value | |
| set(const FloatList &value) | VRay::Value | |
| set(FloatList &&value) | VRay::Value | |
| set(const ColorList &value) | VRay::Value | |
| set(ColorList &&value) | VRay::Value | |
| set(const VectorList &value) | VRay::Value | |
| set(VectorList &&value) | VRay::Value | |
| set(const TransformList &value) | VRay::Value | |
| set(TransformList &&value) | VRay::Value | |
| set(const ValueList &value) | VRay::Value | |
| set(ValueList &&value) | VRay::Value | |
| set(const StringList &value) | VRay::Value | |
| set(StringList &&value) | VRay::Value | |
| set(const PluginList &value) | VRay::Value | |
| set(PluginList &&value) | VRay::Value | |
| set(const int *values, size_t count) | VRay::Value | |
| set(const float *values, size_t count) | VRay::Value | |
| set(const Vector *values, size_t count) | VRay::Value | |
| set(const Color *values, size_t count) | VRay::Value | |
| set(const Transform *values, size_t count) | VRay::Value | |
| set(const std::string *values, size_t count) | VRay::Value | |
| setToValue_(T &&value) (defined in VRay::Value) | VRay::Value | protected |
| swap(Value &value) noexcept (defined in VRay::Value) | VRay::Value | |
| swapValue(Value &value) noexcept (defined in VRay::Value) | VRay::Value | protected |
| toString() const | VRay::Value | |
| type (defined in VRay::Value) | VRay::Value | protected |
| Unspecified() noexcept | VRay::Value | static |
| val (defined in VRay::Value) | VRay::Value | |
| Value(Type type) noexcept (defined in VRay::Value) | VRay::Value | explicitprotected |
| Value(VRayRenderer *renderer, InstanceId id, int outIdx) noexcept (defined in VRay::Value) | VRay::Value | protected |
| Value() noexcept | VRay::Value | |
| Value(const Value &value) (defined in VRay::Value) | VRay::Value | |
| Value(Value &&value) noexcept (defined in VRay::Value) | VRay::Value | |
| Value(int value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(float value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(double value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(bool value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Color &value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const AColor &value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Vector &value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Matrix &value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Transform &value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const IntList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(IntList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const FloatList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(FloatList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const VectorList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(VectorList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const ColorList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(ColorList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(TransformList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const TransformList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const ValueList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(ValueList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const StringList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(StringList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const PluginList &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(PluginList &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const char *value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const std::string &value) (defined in VRay::Value) | VRay::Value | explicit |
| Value(std::string &&value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const PluginRef &value) noexcept (defined in VRay::Value) | VRay::Value | explicit |
| Value(const int *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const float *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const Vector *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const Color *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const Transform *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const Plugin *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const Value *values, size_t count) (defined in VRay::Value) | VRay::Value | |
| Value(const int(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const float(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Vector(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Color(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Transform(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Plugin(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(const Value(&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| Value(Value(&&arr)[count]) (defined in VRay::Value) | VRay::Value | explicit |
| viewAs_() (defined in VRay::Value) | VRay::Value | protected |
| viewAs_() const (defined in VRay::Value) | VRay::Value | protected |
| ~Value() noexcept (defined in VRay::Value) | VRay::Value |
