This page provides information on the purchasing process of actors inside Chaos Anima.
*IMPORTANT UPDATE:
As of August 1, 2024, the AXYZ design webshop no longer offers any items for sale.
Also, since anima 5.6.0, the embedded shop is only be available when an anima® PRO license is detected.
There are 2 different ways to purchase more metropoly® models to expand your library:
- From inside the anima® PRO application (see video).
- From the AXYZ design webshop (*)
So you won’t need to leave Anima and use an external browser. You can go through the complete purchase process directly from inside the Anima standalone application itself.
If you used to purchase the models from our webshop in the past, you will find the Anima alternative very comfortable too because both share almost identical interfaces and workflow.
To access the AXYZ design shop included in Anima, use the Mode Switch available in the upper left corner of the application.
That will change the interface of the application and make it look like a simplified web browser.
From here on, the browsing and purchase experience is exactly the same as the one you have on our website.
Start using the search bar or the filters available in the left panel to quickly find the products you need:
Once you got them, you can open the INFO panel to check their details (360º view, animated preview, color variations, formats available, license, etc.).
…and add it to your cart:
Once you got all the models you want to purchase in your cart, you can proceed to the checkout, select the payment method you want to use:
Then, finish the payment with your credit card inside the Unicredit purchase gateway or add it to your library directly if you want to purchase using the Wallet Credit available in your account:
Confirm the type of billing address selected by default in your user profile (Company or Individual) before the payment is made effective.
When the payment process is done, you will find your brand new purchased models in your library, ready to be dropped into your scene.
