©Anton Podvalny
Please make sure that your system fulfills these requirements to start using V-Ray App SDK.
Note that V-Ray is only supported for 64-bit operating systems.
Processor
  • Intel64*/AMD64 processor with AVX2 support (Windows)
  • Intel64/AMD64 processor with AVX2 support or 64-bit Arm v8.2A compatible processor (Linux)
  • Intel64/AMD64 processor with AVX2 support or Apple silicon (M1, M2 or newer) (macOS)
RAM
  • Minimum: 8 GB RAM
  • Recommended: 64 GB or more RAM
    (Will vary with scene size and complexity.)
GPU
Operating System
  • Microsoft® Windows 10, or Windows 11
  • Red Hat® Enterprise Linux® 7 WS or CentOS 7 (Linux x64)
  • Red Hat® Enterprise Linux® 8 WS or Rocky Linux 8 (Linux x64 and Linux arm64)
  • Apple® macOS® 10.9 or higher (macOS x64)
  • Apple® macOS® 10.14 or higher (macOS universal)
Development Environment
  • Microsoft Visual C++ Redistributable Package, the latest version (Windows)
  • Python 2.7, 3.6, 3.7, 3.8, 3.9, 3.10, 3.11, 3.12 or 3.13, if you plan to use the V-Ray App SDK Python API
  • .NET Framework v4.0 or higher, if you plan to use the V-Ray App SDK .NET API
  • .NET Core 3.1 or higher, if you plan to use the V-Ray App SDK .NET Core API
  • Node.js 10, 12, 14, 16, 18, 20 or 22, if you plan to use the V-Ray App SDK Node.js API
  • Electron 5, 6, 11, 16, 23 or 27 , if you plan to use the V-Ray App SDK Electron API
Windows 11 is required for running Intel Alder Lake processors.
** CUDA compute capability and card reference
  • No labels
