This page provides information on uninstalling Chaos Bridge for SketchUp.
The Chaos Bridge installer automatically uninstalls any previous versions before installing a newer version. If you need to manually uninstall Bridge, please make sure that SketchUp is not being used.
Uninstall Bridge
The Uninstaller originally resides in the following location: C:\Program Files\Chaos\Bridge\Chaos Bridge for SketchUp\uninstall
To access the Bridge uninstaller from the Start menu, search for Uninstall Chaos Bridge for SketchUp.
This starts the Bridge uninstaller. Follow the on-screen instructions to remove Bridge from your system and restore any files overwritten by the installation.
After uninstallation, you can also delete the Bridge folder from its location: C:\Program Files\Chaos\Bridge.
The uninstaller originally resides in /Applications/Chaos/Bridge/Chaos Bridge for SketchUp/uninstall
Double-click the Uninstaller.app program. This starts the Bridge uninstaller. Follow the on-screen instructions to remove Bridge from your system and restore any files overwritten by the installation.
After uninstallation, you can also delete the Bridge folder from its location: Applications/Chaos/Bridge
