This page provides information about the Chaos Improvement Program in Corona for Cinema 4D.
The Chaos Improvement Program is based on telemetry. It allows Chaos to track general Product usage statistics and to automatically collect crash information. The information collected includes what Product functionality and/or parameter values people use most often, which helps Chaos to optimize and improve the Product's performance.
No scenes, assets, or materials are collected.
Enable Chaos Telemetry
Once Corona for Cinema 4D is successfully installed, you are invited to participate in the Chaos Improvement Program. By choosing to participate you can contribute to the improvement decisions for the future versions of Corona.
Your participation involves sharing anonymized telemetry, with the option to enable personalized telemetry too.
With Anonymized Telemetry, you share data on frequently used features and parameter values, which is not personally identifiable and is used mainly for aggregated statistics.
With Personalized Telemetry, you share the same data as with Anonymized Telemetry, along with information tied to your individual user license. This information contains personally identifiable information and enables
Chaos to further optimize the product for better personal use.
You can change your choice at any time.
Chaos Telemetry Settings
You can change the telemetry settings directly in Cinema 4D at any time after installing Corona. The Usage Data settings can be found in the Preferences window > Renderer > Corona. You can access the Corona Renderer Preferences through the Corona menu > Preferences. Alternatively, you can access the Preferences through the Edit menu > Preferences.
Send Product usage data – When you click on the field, it opens the Chaos Telemetry window.
When you open the dropdown menu, you can see some additional options:
Adjust shader data... – Opens the Chaos Telemetry window, where information about the telemetry program is displayed.
Save preview of collected data... – Saves the telemetry data onto a specified .txt file.
This window allows you to change your telemetry settings. When you are done, click Confirm to apply your choices.
Learn More... – Opens the Chaos Privacy policy at https://www.chaos.com/privacy
Product Usage Data
