This page provides information on how to uninstall Corona for C4D.
The installer automatically updates Corona to the newer version if it detects an older version. If you need to manually uninstall Corona, please make sure that Cinema4D or Corona components, such as the Corona Image Editor, are not being used.
Uninstalling Corona for C4D for Windows Users
The uninstaller originally resides as an Uninstall Chaos Corona for Cinema 4D shortcut in the following location:
C:\Program Files\Chaos\Corona
In older versions of Corona, the location is:
C:\Program Files\Corona\Corona Renderer for Cinema 4D\Uninstaller
You can also use the Windows "Add or remove programs" utility to uninstall Corona.
Command Line Parameters
ParameterDescription
-h or --helpDisplays command line help.
-n or --noGuiRuns the uninstallation in console mode with no user input (no confirmation prompt). In this mode, the uninstaller is not able to delete itself, so the file C:\Program Files\Corona\Corona Renderer for Cinema 4D\Uninstaller\RemoveCoronaForC4D.exe is left on disk even after the uninstallation is finished.
Console mode may not work as expected when run directly from the Windows command line console. In such a case, the console does not wait for the uninstaller to finish and displays a new prompt. It also captures and accepts user input while the uninstaller is running and printing into the console.
Solution: The issue does not appear when using a .bat file or any other script, which is the intended use case. Then, the script correctly waits for the uninstaller to finish before proceeding.
Uninstalling Corona for C4D for Mac Users
To uninstall on a Mac, use the following steps:
  1. Navigate to the folder where the uninstaller is located:
    /Applications/Chaos/Corona/
  2. Launch the Uninstall Chaos Corona for Cinema 4D executable.
  3. Click the Uninstall button and wait for the process to complete.
This process uninstalls Corona version 12 Update 1 and later.
  1. Download the remove script from here.
  2. Save the script file on your local drive (It could be in the Desktop or any other folder).
  3. Run the script using the Terminal app on your Mac.
  4. The Terminal will ask for your Mac user password; type it and hit the Enter key.
  5. Wait for the process to finish, and then close it.
This process removes Corona installations previous to Corona 12 Update 1.
Troubleshooting
If, for any reason, you're not able to run the script due to OS permission restrictions, please follow these steps:
  1. Open the Terminal app from the Mac Utilities folder and use the Terminal commands to navigate to the folder path where the script file is located.
    To navigate to the folder where the script is located, use the command "cd" to move between folders.
    (Don't forget to use the commands without the quotes)
    For example, if we've placed the file in the Desktop folder, then we need to type "cd Desktop" (without the quotes) and hit the Enter key on our keyboard.
  2. Once you're in the same folder where the script is located, type the following commands (one by one) and hit the Enter key to set the correct permissions for the script:
    chmod 755 remove_corona.command
    chmod +x remove_corona.command
  3. Close the Terminal, double-click the remove_corona.command file and follow the instructions in the Terminal app.
  4. If the OS does not allow running script files using double click, then right-click on the script file and choose "Open With" > "Other" > "Terminal" from the Utilities folder.
Leftover Files
After the uninstallation is complete, there may be some leftover files that you need to delete. Please check if the following folders are present and delete them:
Windows:
  • %programfiles%\Corona
  • %programfiles%\Chaos\Corona
  • %localappdata%\CoronaRenderer
  • %programfiles%\Maxon Cinema 4D RXX\plugins\Corona (replace RXX with your Cinema 4D version)
Mac:
  • /Applications/Corona
  • /Users/<YourUsername>/Library/Application Support/Corona
  • /Applications/MAXON/Cinema 4D RXX/plugins/Corona (replace RXX with your Cinema 4D version)
