June 13th, 2025 | Version: Chaos Corona 13 | Plugin: 3ds Max
Render engine
  • Biased and Unbiased solution
  • Path Tracing: unbiased solution
  • UHD and 4K (experimental) cache: two options for faster biased cached solution for interiors
  • Denoising
    • Reduces the number of passes needed to get a noise-free image, with render time reductions of 50 to 70%
    • Easy to use and fast to render
    • Corona High Quality denoiser, best quality, recommended for final renders
    • NVIDIA AI GPU-based denoising can be used for final renders at the user’s discretion (requires a compatible NVIDIA GPU)
    • Intel AI denoising can be used for final renders. CPU-only, and works with any CPU (not just Intel)
    • Interactive amount adjustment
    • Checkbox to enable/disable the result in the VFB
  • Fast Caustics Solver
    • Easy to use, and fast to render
    • Includes caustics from reflection, refraction, and dispersion (splitting light into separate colors)
    • Enable or disable caustics being visible through volumes
    • Adjust surface and volume caustic intensities independently
    • Enable or disable for specific light sources
    • Works with LightMix
    • Separate render element available for compositing caustics in post processing for even greater control
    • Works correctly with motion blur
    • Include/Exclude list for control over which objects receive caustics
  • Adaptive Image Sampling
    • Balances out the rendering calculations over the image to focus more processing power on tricky areas
    • High Quality Image filtering, gives a more natural and “less CGI” look to noise, making it less noticeable to the eye
    • AI Image Upscaling for faster test renders, particularly useful for draft animations; renders to one half of the image size and upscales (requires a compatible NVIDIA GPU)
    • Progressive rendering
    • Max Sample Intensity (MSI): automatically removes fireflies - accuracy/render speed tradeoff
    • Proudly CPU based
  • Firefly Removal, via the Simple or Accurate Firefly Filter, used for reducing or removing persistent fireflies in the image, with Accurate mode being better at preserving genuine specular highlights
Interactive lightmix
  • Adjust color and intensity of lights, during and after rendering
  • Single-click set up (by instances, groups, individual lights, or layers,  with memory requirements reported)”
  • Supports multiple suns and multiple environments for different times of day from one render (see Corona Sky and Corona Sun in the Lights section)
  • Manual set up if required
  • Controlled from the VFB
  • Results can be pushed to the scene
  • Can be used for anything from subtle adjustments, to turning day into night, without re-rendering
  • Create multiple Lightmix render elements to save your different set ups all in the same scene and/or CXR
  • Each light select pass can be denoised independently (this can be enabled during automatic setup)
  • LightMix result can be saved to a CXR file and then adjusted in the Corona Image Editor, or saved for compositing in other post-processing software
  • Lights can be selected in the scene from the LightMix tab
Interactive rendering
  • 100% the same render engine as for the final frame
  • All final frame rendering features supported, including Interactive LightMix, post-production effects such as bloom & glare, LUTs, etc.
  • NVIDIA AI GPU-based denoising, for denoising during Interactive Rendering (requires a compatible NVIDIA GPU)
  • AI Image Upscaling for faster redraw of Interactive Rendering; renders to one half of the image size and upscales (requires a compatible NVIDIA GPU)
  • Pick objects directly in the docked viewport
  • Set DOF focus point directly in the docked viewport (for Corona Cameras)
  • Image upscaling factor to allow rendering to a smaller resolution and upscaling (ideal for HighDPI displays)
  • While zooming-in in the IR, rendering is focused on visible area only
  • Subsampling lowers initial resolution at the beginning of rendering, for virtually real-time performance
  • Blue Noise Dithering to give visually pleasing results in the first few passes, for quick assessment of a scene when using Interactive Rendering
  • Results shown in 3ds Max viewport or Corona VFB
Chaos Vantage (sold separately)
  • Standalone application providing real time ray tracing on the GPU
  • Supports many Corona materials, lights, etc.
  • Render animations created in 3ds Max using Vantage via the Live Link
    • Lets you take advantage of faster GPU rendering for drafts, or even for finals where that fits the needs of the project
    • Supports any animation that can be created in 3ds Max by any tools or plugins
  • Live Link
    • Use as an alternative to Interactive Rendering in order to explore your scene from within 3ds Max, find good camera angles, modify lighting, adjust materials, layout a scene, etc.
    • One-click solution to open your scene in Vantage from 3ds Max
    • Changes in 3ds Max are automatically sent over to Vantage
  • Export your scene
    • Use for a full 3D walkthrough of the scene to explore it in detail
    • Build animations in Vantage itself for quick test renders
    • Send the scene to other Vantage users for them to view without them requiring 3ds Max or Corona
Chaos Cosmos
  • Instant content for your scenes, including
    • Models
    • Materials
    • HDRI Skies
    • Scatter presets
    • Decal presets
    • Pattern presets
  • Accessible directly within 3ds Max or Cinema 4D
  • Content is categorized and easily searchable
  • Mark your favorites to find them quickly in other projects
  • Drag and drop anything you have downloaded into your 3D application
  • Content loads as Corona Proxies, with fully editable Corona Materials
  • On-demand downloads, only download what you need when you need it
  • New content added between Corona releases
Chaos Scatter
  • Ideal for adding grass, trees, rocks, traffic or parked cars, crowds or pedestrians, etc. to your scenes
  • Can be used to scatter Decals
  • Control the distribution of hundreds, thousands, or millions of objects
  • Scatter on geometry, in a volume, or along splines
  • Distribute randomly, or in patterns
  • Clusters allows objects or groups of objects to be placed in clusters or clumps, with three alternate modes:
    • Generate mode uses procedural noise to create the clusters, with control over Roughness, Edge Blend, and Diversity to control how sharp or diffuse the clusters are
    • Map mode lets you use a color map to define the areas where the objects should be grouped
    • Paint with instances lets you create and paint layers which define the areas where the objects should be grouped
  • Limit distribution based on the steepness of a slope, e.g. prevent trees growing on cliffs etc.
  • Limit distribution based on altitude, e.g to create a treeline
  • Use spline include/excludes with controllable near and far parameters, e.g. to carve a path through trees, or limit flowers to a flowerbed
  • Edge Trimming to control and tidy the edging of scatters
  • Associated texture map that colors scattered objects based on the colors of the object they are scattered on – ideal for created patterned rugs, variations in color on a lawn, etc.
  • Camera Clipping to limit scattering to within the camera field of view
  • Set scattered objects to look at a particular target
  • Extend view parameter allows expanding the camera view culling to allow correct shadows or reflections from instances outside of the field of view
  • Edit or even delete individual instances after scattering
  • Use the Instance Brush to paint instances in or out of the Scatter result
  • Random translation/rotation/scaling of instances, with optional discrete stepped values
  • Optionally avoids objects intersections, with tweakable inter–object spacing
  • Supports aligning instances to local normal
  • Control density and scale by maps, including preset distribution maps
  • Different modes for using maps to control scatter scale, including RGB mode to define x, y, and z scaling independently in one map
  • Several display modes and limits, to keep viewports responsive
  • Included Lister plugin to easily access and control all scatters in a scene
  • Fully replaces the older Corona Scatter
  • Position Distribution allows scattering the instances based on a pattern
Chaos Cloud for Collaboration
  • Share draft or final deliverables with your clients - removes the need to use dropbox, ftp, email communication with your clients for change requests, etc.
  • Send to Chaos Cloud directly from within the VFB
  • Call out particular information with Highlights non-destructively on an image
  • Receive comments from and have a conversation with your clients on change requests etc., with non-destructive markup on an image
  • Virtual Tours
    • Automatic recognition of when an image is a panorama (aspect ratio of 2:1)
    • Automatically generate hotspots for navigating through the Virtual Tour
    • Optionally, set up manual hotspots
    • Appearance and interactivity of hotspots can be controlled, for example a choice of hotspot icons, hotspot titles (if any), and whether the title is always shown or only on hover-over, etc.
    • Share the result with your client
    • Your client can then share with their target audience, e.g. via embedding on their website
  • Organize your work by project, and manage access and sharing for each separately
  • Deliverables can have versioning, to track the history of requests and changes
  • Optional manual upload of deliverables
  • Managed within a web browser environment
Materials
  • Corona Decal
    • Easily add surface details or imperfections, which can include displacement
    • Independently choose which channels (Diffuse, Displacement, Metalness, etc.) are affected by a Corona Decal
    • Control scaling, positioning, and rotation using a 3D object in the viewport – no need to fiddle with complex UV mapping and placement
    • Stack Decals on top of each other, intuitively controlled by positioning in the 3D space
    • Decals apply to all objects they overlap, with an include/exclude list for fine control
    • Can take a mask from the input material, or a dedicated Map
    • Option to replace base displacement and base bump
    • “Fit to Bitmap” and “Fit to assigned mtl” to get correct aspect ratio for the Decal object
    • “Max angle limit” lets you avoid the decal being applied to backfaces, etc.
    • “Max angle blur” softens the transition from the “Max angle limit” control
    • Option to display the material as a preview in the 3D viewport
    • Can be curved in width and height independently
    • Easily bend labels around curved objects like bottles and spherical items without distortions.
  • Toon Material
    • Gives your renders a stylized look
    • Use to keep the focus on layout and design without getting locked into specific photoreal materials, or for an artistic effect
    • Creates banding / posterization in the Diffuse and Specular lighting
    • Adjust the ramps used to posterize the Diffuse and Specular results
    • Light color replacement lets you modify the color of all lights falling on the material, using a variety of modes (Overwrite, Add, Multiply, etc.)
    • Includes controls for Displacement, Anisotropy, Opacity, Refraction, and Ambient color
    • Can be used in the regular Global Material Override like any other material, to apply to the whole scene at once
    • Combine with the Outline Material for an even stronger “cartoon-like” effect
    Outline Material
    • Draw outlines around objects
    • Used to highlight particular objects, give an “illustrated” look, enhance the Toon Material, or for artistic effects
    • Unlike the CoronaWire texmap, the Outline material does not highlight internal edges
    • Adjust Line Width, Color, and Opacity, including being able to map them via bitmaps or procedurals
    • Individually choose whether Exposure, Tone Mapping, and LUTs affect the Outline or not
    • New Global Outline Override to apply the effect to the entire scene at once (with Include / Exclude functionality to add or remove specific objects from being affected)
  • Corona Slicer Material
    • Used to cut away sections of geometry at render time
    • Cut with any shape that has the Slicer material applied
    • Cuts through all objects overlapped by the slicer, customizable via exclude/include lists
    • Option to cap resulting exposed surfaces
    • Caps can have their own material, or take the material from the object being sliced
    • Can preserve interior lighting of a house with cutaway by combining with the RaySwitch Material
  • CoronaPhysicalMtl
    • Default material since Corona 7
    • Base Layer for diffuse, roughness, reflection, bump, and translucency controls
    • Base layer uses Oren-Nayar shading model
    • Clearcoat Layer for adding a layer of varnish, lacquer, etc., featuring separate bump from the Base Layer
    • Sheen for creating realistic fabrics
    • Thin Film simulates the effect of thin film interference, such as the colors seen on soap bubbles or oil slicks
    • Choice of Roughness or Glossiness workflow, both per-material and as scene default
    • Choice of IOR or Disney Specular workflow, both per-material and as scene default
    • Metalness workflow, where Metalness can be mapped
    • Metals can be controlled by simple Edge Color, or by Complex IOR
    • UI interactively enables or disables parameters based on whether a material is Metal or Non-Metal
    • 35 presets built-in to the material, as starting points, or to ‘reverse engineer’ to learn in creating your own materials
    • Refraction, including dispersion, caustics, and thin absorption (for Thin Mode)
    • Anisotropy correctly affects both Refractions and Reflection (both correctly affect caustics)
    • Thin mode for glass correctly blurs reflections and refractions
    • Opacity
    • Adaptive displacement with low memory requirements
    • Vector displacement
    • SSS mode for wax, marble, and other materials that do not use Thin Mode or full Refraction
    • Volumetric scattering and absorption mode for fog, mist, and for colored glass, liquids and other materials that use Refraction without Thin Mode
    • Self-illumination
    • Adjustable PBR reflection tail
  • CoronaLegacyMtl
    • Uses Lambertian shading model
    • Legacy material, to preserve identical results from scenes created in earlier versions of Chaos Corona
  • CoronaSkinMtl
    • Dedicated material for skin
    • Three independent Subsurface Scattering layers
    • Two independent Reflection layers
  • CoronaHairMtl
    • Dedicated material for hair and fur
    • Colored and Colorless reflection layers
    • Color controls via melanin amounts, or directly
    • Adjustable random Glints
  • CoronaLayeredMtl
    • Similar to 3ds Max Blend material
    • Combines multiple materials instead of just two
    • Individual layers can be toggled on/off
    • Displacement from the individual materials can be combined via blend or additive modes, or taken only from the base layer
  • CoronaSelectMtl
    • Store multiple materials for one object, and select between them via radio buttons
    • Radio buttons can be keyframed, and accessed via MAXScript
  • CoronaLightMtl
    • Identical performance to CoronaLight
    • Various non-physical settings
    • Textured emission (useful for backplates)
  • CoronaRaySwitchMtl
    • Uses different material for different ray types: direct, GI, reflections, refractions
  • CoronaShadowCatcherMtl
    • Custom backplate textures
    • Screen, spherical, or no projection
    • Supports glossy surfaces
    • Bump mapping
    • Lights work additively (illuminators) or subtractively
  • CoronaVolumeMtl
    • Simplified material for volumetric scattering and absorption
    • “Inside Mode” allows for true 3D volumetric materials
  • Drag and drop bitmaps from Windows Explorer directly into Corona material slots
  • 3ds Max materials
    • Standard
    • Blend (including nested blend materials)
    • Multi/Sub-Object
    • XRef
    • Shell
    • Double Sided
    • Top/Bottom
    • DirectX Shader
  • Support for 3ds Max physical material
Texmaps
  • CoronaSky
    • See the Lights section
  • CoronaTileMap
    • Create tiled walls, floors, and more
    • A variety of inbuilt tiling patterns
    • Supports multiple inputs and outputs, so one TileMap can control color, glossiness, displacement, etc.
    • Overall scale
    • Tile color (which can be mapped)
    • Gap thickness, and color (which can be mapped)
    • Gap distortion for randomization
    • Gap blur to blend sharply or smoothly into the Tile color
    • Adjustable rounding of tile corners
    • Can be used as a map e.g. in a Layered Material
  • CoronaCurvature
    • Add wear-and-tear or dirt to an object, based on the curves of the surface
    • Identify concave areas, convex areas, or both at once
    • Ray directionality to control how “focused” the effect is
    • Distance to control how far the effect extends
    • Color spread to control smoothness of blending between colors
  • CoronaAO
    • Ambient occlusion shader
    • Supports textures
    • Includes/Excludes
    • Additional controls: spread, directionality, inverted mode, etc.
  • CoronaDistance
    • Gradient based on distance to other objects
    • Supports textures
    • List of objects to calculate distance from
    • Can be used in Chaos Scatter density map to control placement of objects
    • Wide range of other creative uses, e.g. ripples on water around objects, controlling light intensity and color, etc.
    • Supports all geometry including Corona Proxy, Chaos Scatter, and 3ds Max particle objects, as well as Cameras and other objects
    • Works as an input to bump mapping
  • CoronaColorCorrect
    • Adjust brightness, saturation etc. of a texture map (and still have it affected by VFB post-processing)
    • Unique tone mapping capabilities (not present on other output nodes), including LUTs, gamma, curves, green-magenta tint, etc.
    • Mode available so that one CoronaColorCorrect controls multiple other CoronaColorCorrects, allowing you to apply the same adjustments to multiple maps and adjust those from one location
    • Optional multiple inputs and outputs, to apply the same color correction to multiple maps and connect to different materials or material channels
  • CoronaTonemapControl
    • Specify whether a texture map should be affected by VFB Exposure, Tone Mapping, etc.
  • CoronaMappingRandomizer
    • Apply random offset / rotation / scale to textures and maps by instance, material id, mesh element, etc., each of which can be enabled via checkbox to allow multiple randomization modes at once
    • Options to allow randomization of seamless textures, e.g. to avoid visibly obvious tiling
    • Optional multiple inputs and outputs, to apply the same randomization to multiple maps and connect to different materials or material channels
    • Option to randomize by Tile from the CoronaTileMap (see “CoronaTileMap” earlier)
  • CoronaMix
    • Advanced mix shader
    • Texture or color inputs, different blending modes
  • CoronaRaySwitch
    • Same as RaySwitch material, but on texmap instead of material level
  • CoronaColor
    • Allows to input single constant color using a color picker
    • HDR numerical values, Kelvin temperature, web hex input
  • CoronaTriplanar
    • Apply textures without explicit UV mapping, with no stretching or seams thanks to the built-in blending
    • Optional multiple inputs and outputs, to apply the same triplanar mapping to multiple maps and connect to different materials or material channels
  • CoronaBitmap
    • Out-of-core Textures (enabled by default) saves memory by automatically adjusting textures based on their placement in the scene
    • Works similarly to 3ds Max bitmap, but faster (10-20%)
    • Can load .tx files (via drag and drop into the “Load File” section of the UI in the Corona Bitmap)
    • Spherical, Dome, Cross and Mirrorball modes for use as an Environment
    • Rotation via degrees or U Offset (for environments)
    • Asynchronous loading (start work on a scene without a wait for all textures and proxies to load)
  • CoronaSelect
    • Store multiple maps in a material, and select between them via radio buttons
    • Batch load option to load multiple maps at once
  • CoronaMultiMap
    • Randomly assigns colors/maps to instances, mesh elements, Tiles (from the CoronaTileMap, see earlier), or decals, each of which can be enabled via checkbox to allow multiple randomization modes at once
    • Frequency spinners
    • Hue, Gamma and Saturation randomization
    • Features advanced blending modes
    • Global blur multiplier to affect all multimaps elements
    • Supports up to 25 inputs directly, with another 75 accessible via MAXScript
    • Supports multiple outputs. A new set of inputs will be created for each additional output (e.g. if you have 4 inputs to randomize between, each additional output will have 4 additional inputs created for it). For example, this can let you apply a matching randomization between a set of Diffuse textures and a matching set of Glossiness textures, etc.
    • Can be used with just one input, applying gamma and hue randomization
  • CoronaRoundEdges
    • Rounded corners shader
    • Works as an input to bump mapping and other material slots
    • Fast mode for faster rendering and no noise, with no parameters needed
    • Precise mode for blending across other objects / elements / materials
  • CoronaEdgeMap
    • Add weathering or staining to edges of objects
    • Creates a color gradient based on how far away a point is from a geometric edge
    • Primarily for objects with no thickness (paper, leaves, etc.)
  • CoronaNormal
    • Automatic detection of incorrect input gamma
  • CoronaBumpConverter
    • Converts RGB maps to be compatible with the Bump channel (e.g. 3ds Max native Marble, Wood, ColorCorrect, etc.)
  • CoronaFrontBack
    • Shows different colors/texmaps on front/back sides of a material
  • CoronaWire
    • Wire shader
    • Allows to set edge/vertex size in world or screen coordinates
    • Falloff between Base and Edges / Vertices color
    • Can be used as input to bump mapping
  • CoronaUserProperty
    • Assign a numeric value to a node, for use with MAXScript
  • CoronaOutput
    • Legacy only, used in scenes created before Chaos Corona 2. Replaced by CoronaColorCorrect and CoronaToneMapControl
Lights
  • CoronaSky
    • Procedural Clouds allow you to add, control, and animate clouds and airplane contrails
    • New PRG Sky model based on atmospheric data
    • “Aerial Perspective” via Volume Effect
    • Altitude sets the height of the observer
    • Turbidity controls whether sky is clear or overcast
    • Density controls the thickness / heaviness of the clouds
    • Clouds affected by the Sun’s Direct Color
    • Artistic control over Horizon Blur
    • Can be linked to a Corona Sun, allowing different times of day
    • Supports dawn/twilight with the Corona Sun as low as -12 degrees (approximately 24 sun diameters) below the horizon
    • Allows changing of the ground color
    • Also offers Hošek & Wilkie, Preetham et al., and Rawa-fake sky models
    • Alternatively can be set to use an HDRI, see Corona Bitmap for more information
    • Multiple skies are supported, and each one can be paired with specific Corona Suns, for use in LightMix
  • CoronaSun
    • Standalone object or part of 3ds Max daylight assembly
    • Multiple Suns are supported, and each one can be paired with specific Corona Skies, for use in LightMix
    • Allows non-physical properties (such as changing size, color, disabling visibility in reflections, etc.)
  • CoronaLight
    • Shapes: sphere, rectangle, disk, cylinder
    • IES profiles
    • Directionality
    • Textured emitters
    • Physical units
    • Color (RGB input, Kelvin temperature, texmap)
    • Non-physical settings: disabling shadows, includes/excludes, disabling visibility in reflections, preventing black appearance for lights with directionality
  • Corona Light Material
    • Turns any object into a light
    • No render time differences compared to using a CoronaLight
  • 3ds Max native lights
Environment
  • Drag and drop any texture into the 3ds Max environment slot to illuminate your scene
  • No dome object required
  • Adaptive Environment Sampler ensures fast and accurate sampling of HDRI and Sky environments, without the need for portals
  • Importance sampling speeds up rendering
  • Direct/Reflect/Refract overrides
  • Global material for volumetric effects such as fog (also see Volume Effect under Corona Sky for an “aerial perspective” instead
Corona Virtual Frame Buffer
  • An optional, feature-rich replacement for the 3ds Max native VFB
  • New VFB 2 for enhanced performance and controls (legacy VFB available as an option)
  • Integrated tone mapping controls
    • Fully customizable stack – add, delete, and move all the parameters to create precisely the effect you want
    • Presets to provide a starting point
    • Tone mapping stacks can be saved and loaded, independent of other VFB controls
    • Each Corona Camera can have its own unique tone mapping stack and settings, which are displayed and controlled in the VFB without having to edit the Camera settings
    • Included parameters:
      • Auto Adjustment - can be toggled on and off affecting the two settings below at once
        • Exposure - can be toggled on and off, baked to the scene, and allows additional manual Exposure adjustments
        • White Balance - can be toggled on and off, baked to the scene, and allows additional manual White Balance adjustments
      • Basic
        • Contrast
        • Green-Magenta Tint
        • Lift Gamma Gain
        • Photographic Exposure
        • Saturation
        • Simple Exposure
        • Tint
        • Vignette
        • White Balance
        • Legacy White Balance
      • Curve Control
        • Advanced Filmic Mapping
        • Curves
        • Filmic Mapping
        • Tone Curve
      • Highlight Control
        • Reinhard Highlight Compression
      • Final Look
        • ACES Output Transform
        • LUT
  • Integrated Interactive LightMix, allows changing color and intensity of lights without re-rendering, including multiple LightMix layers for storing different lighting settings within the image (day, night, etc.)
  • Integrated lens effects offering a high degree of realism and creativity for bloom & glare effects affected by lens scratches, dirt, etc. Includes option to defer the calculation until render end, rather than recalculate as rendering happens
  • Sharpening/blurring
  • Save and load post-processing configurations, and exchange those to and from the Corona Image Editor and Corona Cameras
  • Save and load LightMix configurations, and exchange those to and from the Corona Image Editor
  • Pick objects directly in the VFB
  • Set DOF focus point directly in the VFB (for Corona Cameras)
  • VFB History and Comparison, with ability to toggle between using the current post-processing, or the post-processing at the time of saving the image to history
    • Load or drag-and-drop images into the VFB history
    • A/B Compare images of different resolutions or aspect ratios
  • Statistics: render time, remaining time, performance, polycount, tooltip explanations, etc.
  • Displaying/saving render elements
  • Pixel color probe on right mouse button
  • Controls: start render/stop render, resume last render, resume rendering from file, save/clone/copy image, etc.
  • Optional stamp with scene info at the bottom of rendered image
  • Customizable information in the title bar
  • Interactive and Multiple Render Regions
  • Render Regions scale with the VFB, are saved with the 3ds Max scene file, and can be globally disabled or enabled
  • Fuzzy render regions
  • Zoom buttons for use when accessing a machine remotely
  • Automatic Exposure and White Balance (Auto Adjustments)
  • Send an image to the AI Image Enhancer on Chaos Cloud, for refining of people and vegetation
Corona Image Editor
  • Runs outside of any 3D software
  • All the familiar controls from the Corona VFB
  • Adjust lighting in the rendered image using the full range of LightMix controls (on Corona EXRs)
  • Apply Denoising (on Corona EXRs)
  • Apply all the Corona post-processing options (on any EXR)
  • Save and load post-processing configurations, and exchange those to and from the Corona VFB and Corona Cameras
  • Save and load LightMix configurations, and exchange those to and from the Corona VFB
  • Bloom & Glare virtual element which can be viewed or saved separately
  • Save to EXR, PNG, JPG and BMP
Geometry
  • Corona Pattern
    • Tile geometry as easily as tiling a texture
    • Greater realism than maps of opacity, displacement etc. and needs less memory
    • Use scene geometry (cube) to define the crop box, taking advantage of e.g. snapping
  • CoronaProxy
    • Cross-platform proxy format – .cgeo
    • Faster save/load/display of large scenes
    • Compressed format to save disk space
    • Supports animated meshes
    • Supports loading of vrmesh proxies (mesh data only)
  • CoronaVolumeGrid
    • Allows loading and rendering of OpenVDB files
    • Useful for importing simulations such as clouds, smoke, fire, liquids, etc.
Post-processing effects
  • Controlled from render settings, Corona Camera, or VFB
  • All settings are adjustable during/after rendering
  • Image updated in real time
  • Bloom & Glare
    • Both controlled independently
    • Threshold
    • Color intensity & shift to adjust colors
    • Glare ray count, blurriness and rotation
    • Lens Effects for scratches, dirt, etc.
Corona Camera
  • Dedicated Corona camera offering all standard camera controls plus all Corona controls such as exposure, DOF, motion blur, LUTs etc.
  • Shutter Curve for flexible control of Motion Blur
  • Set focus distance using a static or animated target object
  • Per-camera object includes / excludes
  • Each camera can have its own override for the Global Volume Material
  • Control whether Bloom & Glare is shown in the default 3ds Max Alpha element
  • Camera can move through volumes (e.g. be half submerged in water, showing above and below the water at the same time, or fly through clouds, etc.)
  • Customizable viewport appearance
  • Save and load post-processing configurations, and exchange those to and from the Corona VFB and Corona Image Editor
  • Tone mapping parameters respond immediately in Interactive Rendering without restarts
  • Render to fisheye, orthographic, perspective, spherical, cylindrical, or cubemap projections
  • DOF supported for Fisheye renders
Camera effects
  • High quality (raytraced) depth of field and motion blur effects
  • Photographic controls (optional): shutter speed + ISO + f-stop
  • Fisheye lens effects
  • Bokeh shape
    • Circular
    • N-gonal (bladed aperture)
    • Custom image
    • Center Bias
    • Vignetting
    • Anisotropy
  • Multi-segment (curved) motion blur
  • 3ds Max 2016 Physical Camera support
  • Virtual Reality Camera
Exposure and color mapping
  • Two exposure control modes
    • Photographic exposure: shutter speed + ISO + f-stop
    • Simple exposure: single EV value
  • See the Corona Virtual Frame Buffer section for a full list of controls
Corona Camera Mod
  • Legacy Camera object modifier for backwards compatibility
  • Allows setting Corona exposure/DOF/ motion blur/bloom & glare/color mapping on any camera
Render elements
  • Arbitrary number of render elements
  • Optional render elements anti-aliasing
  • Optional render elements Denoising (where relevant)
  • Beauty element, with independent Denoise amount
  • Alpha element
  • Beauty composition elements
    • Direct, indirect, reflect, refract, translucency, emission, caustics, volumetrics
  • Geometry elements
    • Geometry normals, shading normals, primitive coordinates, UVW coordinates, world position, z-depth, Velocity render element
  • Masking elements
    • Wire color
    • Primitive/Material/Object ID
    • Cryptomatte
    • Option to propagate masks through reflection, refraction, both, or none
    • Custom mask
    • Object selection
    • Material G-buffer ID
    • Object G-buffer ID
  • Shading elements
    • Albedo, individual direct/indirect BRDF components, raw components, source colors, shadows, caustics, Bloom & Glare
  • Informational elements
    • RenderStamp, SamplingFocus
  • Arbitrary texmap elements
    • Ambient occlusion
    • Wire shader
    • Vertex colors
Distributed rendering
  • Slaves can join or quit the render session after it has started
  • Auto discovery of slaves on local network
  • Auto sending of assets to all machines (only if required)
  • Pass, Time and Noise Level limits can be used
  • Can be enabled / disabled during rendering
Chaos Corona Toolbar
  • Provides one-click access to many Chaos Corona functions, such as creating a Corona Camera from the current perspective view, opening the VFB, opening the Material Library, creating Corona Proxies and Lights, etc.
Corona Power Tools
  • Object Replacer
    • Replace selected objects with other objects taken from a user-defined list
  • Pivot Placer
    • Place pivot to a selected point on an object, or to the bounding box of multiple selected objects
  • Transform Randomizer
    • Randomize the translation, rotation, and/or scaling of the selected objects
  • Scene Cleaner
    • Remove animation keys, layers, etc.
    • Checkboxes give options on what features to clean up
  • Selection Randomizer
    • Randomly select only a certain percentage of objects from the current total selection
    • E.g randomly delete 40% of a large number of rocks to thin out a scene (where those rocks are fixed and not controlled by a Scatter)
Corona Unified Lister
  • Provides access to and control over the major parameters of any Corona Lights, Light Materials, Suns, Proxies, Displacement Materials, Cameras, Decals, and Scatters in the scene
VR
  • Corona Camera can render to spherical or cubemap format, supporting a wide range of VR apps
  • Easy setup, with default settings handling 99% of cases
  • Conventional stereo rendering (non-360)
  • Bloom & Glare supported for spherical VR images
Supported Chaos tools
  • AI Image Enhancer on Chaos Cloud, enhances people and vegetation and upscales an image
  • Chaos Cosmos and Chaos Scatter included
  • Chaos Phoenix compatibility (license also included with Corona Premium subscription)
  • Chaos Scans compatibility (license also included with Corona Premium subscription); Chaos Scans can be found in the Chaos Cosmos material library
  • Chaos Player license included with Corona Premium subscription
  • Chaos Anima 6 supported (license not included)
Supported 3ds Max features
  • Most texmaps
    • Including Bitmap, Camera Map Per Pixel, Cellular, Checker, ColorCorrection, Composite, Dent, Falloff, Gradient, Gradient Ramp, Marble, Mix, Noise, Output, Particle Age, Perlin Marble, RGB Multiply, RGB Tint, Smoke, Speckle, Splat, Stucco, Vertex Color, Waves, Wood
  • Support for 3ds Max Compound nodes
  • 3ds Max standard/photometric lights
    • Including soft shadows via CoronaShadows
  • 3ds Max render switches
    • Disabling Displacement, Render Hidden Geometry, Renderable, Object Visibility, etc.
  • XRef geometry/scenes
  • 2D Pan Zoom Mode
  • Render to Texture (RTT) basic support; denoising RTT results is supported
  • Color Management options in 3ds Max
MISC
  • 2.5 D Displacement
    • This method of calculating displacement saves significant memory and parsing times
    • CoronoBitmap and Proxies are now loaded in the background, allowing faster scene opening
  • V-Ray compatibility
    • Supports assets from V-Ray 3.60 or newer (assets from older versions may work, but not guaranteed)
    • Renders VRayMtl and VRayLight, even if V-Ray is not licensed or not installed, without running any sort of conversion
  • Hair and Fur support
    • 3ds Max native Hair and Fur
    • Ephere Ornatrix
    • HairFarm
    • Hair rendering both as billboards or as full cylindrical geometry
  • Chaos Phoenix support
    • Supports Chaos Phoenix 3.10.00 or newer (3.10.03 required for compatibility with Interactive Rendering)
    • Supports Foam
    • License included with Corona Premium subscriptions
  • Corona Displacement Modifier
    • Allows setting per-object Subdivision Quality
    • Adaptive displacement, with low memory requirements
    • All displacement features and settings that are available in a CoronaMaterial
  • Advanced “Render Selected”
    • Render mask by an include list, object ID, or viewport selection
  • Improved Color Picker
    • Can be set to replace default 3ds Max color picker
    • Choice between sRGB modes for ease of use with Photoshop and similar, or Linear modes
    • Perceptually uniform color gradients in both modes
    • Color selection by RGB, HSV, CMYK, or Temperature
    • Choice between 0-255, 0-1, or 0-100% for values
    • Adjustable averaging of neighboring pixels
    • Inverse color picker allows setting of white balance in combination with the Color Tint parameter in the VFB
  • Error reporting with online help
    • Error messages linked to dedicated support pages with more info and possible solutions
    • Automatic selection of the offending object
    • Automatic correction of certain errors
    • Error message forwarding from render slaves in DR
  • Corona Converter
    • One-click solution to convert materials, lights, and maps from other renderers, and from older versions of Chaos Corona
  • Improved material editor scene
    • More representative previews
  • Override material option (with excludes/includes; options to preserve displacement, light materials, glass materials, slicer materials, bump mapping, opacity, portals, and unsupported materials; also works for multi/sub-object materials)
  • Comprehensive support for file formats
    • CoronaBitmap supports Kodak Cineon, SGI file, RLA image file, Adobe PSD Reader, and DDS image file formats, as well as all the more common formats (JPG, PNG, etc.)
    • CoronaVFB supports saving to the most common formats, including .TIF with specified output color depth, alpha channel, etc.
  • Save and resume
    • Ability to save VFB and resume rendering later (even on a different computer)
  • Render only elements
    • Computes render elements in seconds without doing shading
  • Autosave
    • Optionally saving the VFB every few minutes and after rendering. Rendering can be resumed from these backups
  • Bundled LUTs
    • Over 90 LUTs included with the install
  • Bundled IES profiles
    • Sample IES files included
  • UI supports HiDPI monitors
  • FumeFX support
