Live Updates in Revit
When making changes to materials, lights, objects, etc. via Revit, these adjustments are instantly recognized and automatically translated into Enscape when Live Updates is enabled. This functionality can of course also be deactivated when required.
Live Updates is also available whilst VR mode is activated. This allows making adjustments to a project which, when implemented, allows the user who is wearing the VR headset to see the corresponding changes in real time. Furthermore, Live Updates are always activated by default. To deactivate this feature, please follow the corresponding instructions set out below.
Once Enscape has been started in Revit, you can enable / disable the live link between the two softwares by clicking the Resume Live Updates / Pause Live Updates button:
Pause Resume Live Updates button in Revit
As long as Live Updates is enabled the ability to click and access the Active Document menu in the Revit ribbon where you can select a View is maintained. Having Live Updates disabled breaks that link.
You will still be able to create views within the Enscape UI, and these are saved to the Revit Active Document list even when the Live Updates is paused.
Active Documents menu in Revit
Each View saves the corresponding Revit attributes:
- Location and camera perspective
- Hide in View
- Sun Settings
- Phasing
- Design options
- Section boxes
This means you can create a whole presentation just by transitioning between the different Views listed.
An Export Geometry option which speeds up loading when switching between Views is available via the Enscape Export Geometry setting.
View Management in Enscape
Synchronize Views in Revit
Synchronize Views allows synchronizing the view between Revit and Enscape. Any perspective/movement changes which are executed in Revit will immediately be translated into Enscape.
This functionality also allows navigation via Revit only, without having to make use of Enscape’s controls.
To synchronize the view of Revit with Enscape, simply click the following Synchronize Views button:
Synchronize Views button in Revit
Click the Synchronize Views button again to pause the synchronization.
Also notice that this button has an arrow associated with it that when clicked will expand a menu to reveal a button for Revit’s Live Camera option, which is documented in full here.
Notice that the button’s background is highlighted with blue when enabled.
To disable Synchronize Views, click the button once more.
Revit Live Camera button
