This page provides information about the supported .vrscene features exported from 3ds Max.
Lights
UINative nameV-Ray plugin name (plugin/parameter)Support
On
enabled(tick)
Light Type:
Spot
Directional
Omni
LightSpotMax
LightDirectMax
LightOmniMax
(tick)
(tick)
(tick)
Targeted(tick)
Shadowsshadows(tick)
Use Global Settingsuse_global_light_level(tick)
Shadow Type
Adv. Raytraced
Area Shadows
Shadow Map
Ray Traced Shadows
VRayShadow
(minus)
(minus)
(minus)
(minus)
(tick)
Exclude...
SettingsLightLinker/ignored_lights
SettingsLightLinker/ ignored_shadow_lights
(error)
(error)
Transparent shadows –(minus)
BiasshadowBias (tick)
Area shadow:
Box
Sphere
shadowShape=0
shadowShape=1
(tick)
(tick)
U sizeshadowRadius
(tick)
V sizeshadowRadius1
(tick)
W sizeshadowRadius2
(tick)
Multiplierintensity
(tick)
Colorcolor
(tick)
Decay Type:
None
Inverse
Inverse Sqaure
decay_type=0
decay_type=1
decay_type=2
(tick)
(tick)
(tick)
Decay Startdecay_start(tick)
Near Attenuation:
Use
Show
Start
End
near_attenuation
near_attenuation_start
near_attenuation_end
(tick)
(minus)
(tick)
(tick)
Far Attenuation:
Use
Show
Start
End
far_attenuation
far_attenuation_start
far_attenuation_end
(tick)
(minus)
(tick)
(tick)
Show Clone(minus)
Overshootovershoot(tick)
Hotspot/Beamhotspot(tick)
Falloff/Fieldfallsize(tick)
Cirleshape_type=0(tick)
Rectangleshape_type=1(tick)
Aspectrect_aspect(tick)
Bitmap Fit...(minus)
Contrast(minus)
Soften Diff. Edge(minus)
DiffuseaffectDiffuse(tick)
SpecularaffectSpecular(tick)
Ambient Only
Mapprojector_map(tick)
Object Shadows:
Color
Density
Map
Light Affects Shadow Color
shadowColor
(error)
(minus)
(minus)
(minus)
Atmosphere Shadows:
On
Opacity
Color Amount
(minus)
(minus)
(minus)
Ray Bias
(error)
2 Sided Shadows(error)
Max Quadtree Depth(error)
Physical Camera
UINative nameV-Ray Plugin nameSupport
Physical CameraCameraPhysical
Targeted
(tick)
Target Distance
target_distance
(tick)
Show Cone:
When Selected
Always
Never
(minus)
(minus)
(minus)
Show Horizon Line(minus)
Texture Resolutionbmpaperture_resolution
(error)
Use Lens Filedistortion_type=2
(error)
Lens Filelens_file
(error)
Preset(minus)
Widthfilm_width
(tick)
Focal Lengthfocal_length
(tick)
Specify FOVspecify_fov
(tick)
FOVfov
(tick)
Zoomzoom_factor
(tick)
Aperturef_number
(tick)
Use Target Distancetargeted=1
(tick)
Customtargeted=0
(tick)
Focus Distancefocus_distance
(tick)
Lens Breathing
(tick)
Enable Depth of Fielduse_dof
(tick)
Shutter Type(minus)
Durationshutter_speed
(tick)
Offsetshutter_offset
(error)
Enable Motion Bluruse_moblur
(error)
Exposure ControlSettingsColorMapping/exposure
(error)
ManualISO
(tick)
Target
(error)
Illuminantwhite_balance
(error)
Temperaturewhite_balance
(error)
Customwhite_balance
(error)
Enable Vignettingvignetting
(error)
Amountvignetting
(error)
Aperture Shape:
Circular
Bladed
blades_enable=0
blades_enable=1
(tick)
(tick)
Bladesblades_num
(tick)
Rotationblades_rotation
(tick)
Custom Texturebmpaperture_tex
(error)
Affect Exposurebmpaperture_affects_exposure
(error)
Center Bias (Ring Effect)center_bias
(error)
Optical Vignetting (Cat Eye)optical_vignetting
(error)
Anisotropy (Anamorphic Lens)anisotropy
(error)
Lens Shift:
Horizontal
Vertical
horizontal_offset
vertical_offset
(tick)
(tick)
Tilt Correction:
Horizontal
Vertical
horizontal_shift
lens_shift
(tick)
(tick)
Auto Vertical Tilt Correction
(tick)
Distortion Type:
None
Cubic
distortion=0
distortion_type=1
(error)
(error)
Amountdistortion
(error)
Texturelens_file
(error)
EnableRenderView/clipping
(tick)
Clipping NearRenderView/clipping_near
(tick)
Clipping FarRenderView/clipping_far
(tick)
Environment Near Range(minus)
Environment Far Range-(minus)
Materials
SupportNotes
Physical Material-(error)
BlendBRDFLayered(tick)
DirectX Shader-(error)
Double SidedMtl2Sided(tick)
glTF Material-(error)
Material SwitcherMtlSingleBRDF(tick)
Multi/Sub-ObjectMtlMulti(tick)
PBR Material (Metal/Rough)-(error)
PBR Material (Spec/Gloss)-(error)
Shell MaterialMtlSingleBRDF(tick)
ShellacBRDFLayered(tick)
XRef Material
(tick)
Others
Support
jiWindowBox_All_v1_10.osl, wParallax_SMP.osl/wParallax_ADV.osl, Evermotion_wBox_VRay.oslTexOSL(tick)
