This page provides a quick starting point to create a previz animation with Chaos Vantage.
To create a previz animation you need to learn how to set up your scene to work in Chaos Vantage, tweak camera transitions, and set your high-quality sequences render settings, optimizing memory consumption. The video and the instructions below show you how to do it.
Download Free Trial
Steps
1. Open your animation.
Create and scroll through your animation to view camera and object movements in your preferred DCC (C4D was used in this example).
2. Set a scene for export to Vantage.
Set a start and end frames for the animation and export a .vrscene file.
3. Load and preview the scene in Vantage.
Go to File > Open Scene to load the exported .vrscene in Vantage. Click the Play (Vantage_Bottom_Bar_PlayAnimation.png) button to preview the scene animation.
4. Import pre-made camera config (optional).
Go to File > Open Scene as Config Only to load previously created cameras and camera transitions. Modify transitions' durations and type as necessary.
5. Open HQ sequence render settings.
Set the render settings as desired. Enable Denoiser, Reduce flickering and keep a small Samples limit to produce a faster yet clean rendering. Increase Samples limit and disable Reduce flickering for cleaner and sharper result. Click Start to begin rendering the previz animation.
