This page provides a quick starting point for rendering multiple camera views and sequences with Render Queue.
Chaos Vantage allows you to render multiple camera views at once, without the need to manually initiate each one individually. Thus, you can set up and queue multiple render tasks (still images or animation sequence), saving significant time and effort, especially for complex projects involving numerous camera angles.
Steps
Step 1: Add image/animation for rendering
You can set and render multiple camera views and sequences systematically, without the hassle of manually starting each one in Chaos Vantage. To do so, follow these steps:
Open the Common settings window from Tools menu > High Quality Render, or from the High Quality Render
toolbar button.Still image
To add still images for rendering, click the Still image button. Proceed with selecting a camera view and type, resolution, sample count, quality presets, render elements, etc.
Then in the Render queue panel, click the Add to render queue
button to add the image to the queue.Sequence
To add a sequence for rendering, click the Sequence button. Note that you have to prepare the sequence in the Animation Editor in advance, otherwise the Sequence button is grayed-out. Proceed with selecting a camera view and type, resolution, sample count, quality presets, output frame ranges, render elements, etc.
Then in the Render queue panel, click the Add to render queue button to add the sequence to the queue.
If you select a Recorded Camera (an animated camera view captured with the Record Camera Movement button) from the dropdown in the Common settings window > Still image tab, only the first frame will be rendered.
In order to render the whole sequence of the recorded camera, you have to first add it to the camera track of the Animation Editor and then use the Common settings window > Sequence tab.
Step 2: Update settings
You can update the render settings of any item added to the queue.
First, load the stored settings from the Edit settings from dialog Update settings from dialog button of the respective item. After changing the settings, click the button to save the changes to the item in the queue.
Step 3: Disable image/animation for rendering
You can prevent an item from being rendered by simply disabling its toggle
in the Render queue panel.Step 4: Delete image/animation
Use the Delete
button of the respective image or animation to delete them from the render queue.To clear the entire render queue, use the global Delete button.
Step 5: Render
Click the Start Queue button to begin rendering.
