This shader attempts to recreate the look of fabric materials. This is a material shader and should be used with the VRayOSLMtl material. The shader is provided by Derek Flood.
The shader code is available here: fabric.zip
Shader code
The shader code is below.
fabric.osl
/* * * fabric.osl shader by Derek Flood (c)2015 * from http://docs.sharktacos.com/misc.php?action=help&hid=66 * */ float fresnelReflectionFactor(normal bumped_normal, float ior) { float c = abs(dot(I, bumped_normal)); float g = ior * ior - 1.0 + c * c; if (g > 0.0) { g = sqrt (g); float A = (g - c) / (g + c); float B = (c * (g + c) - 1.0) / (c * (g - c) + 1.0); return 0.5 * A * A * (1.0 + B * B); } return 1.0; } normal getBumpedNormal(color centerColor, color uColor, color vColor, float inverseBumpAmount) { vector worldTangent = normalize(dPdu); vector worldBitangent = normalize(dPdv); vector worldNormal = normalize(N); vector average = vector(0.3333333); float center = dot (average, vector(centerColor)); float ddu = center - dot(average, vector(uColor)); float ddv = center - dot(average, vector(vColor)); return normalize(ddu * worldTangent + ddv * worldBitangent + inverseBumpAmount * worldNormal); } surface fabric [[ string description = "artist based fabric material" ]] ( /* Diffuse section */ color Sheen_color = color(1.0, 1.0, 1.0) [[ string description = "Sheen color can be black for nylon sheen." ]], float Sheen_opacity = 1.0 [[ string description = "Determines amount of sheen effect as fibres pick up light at incident angle." ]], float Sheen_tint = 0.5 [[ string description = "Tints both the sheen and specular." ]], int Sheen_ramp_type = 3 [[ string widget = "mapper", string description = "Six types of interpolation for sheen. 1-3 (linear, exponential and smooth) are sharper, 4-6 (Sigmoid, square root and Fresnel) are softer.", string options = "linear:1|exponential:2|Smooth:3|Sigmoid:4|Square_root:5|Fresnel:6" ]], string Diffuse_color = "", float Diffuse_weight = 0.8, float Diffuse_roughness = 0.4, /* Spec section */ color Spec_color = 1.0, float Spec_amount = 0.5, float Spec_glossiness = 0.6, float IOR = 1.33 [[ string description = "Determines the strength of Fresnel reflections; fabric generally has low frontal reflections." ]], int Subdivs = 8, int Trace_reflections = 1 [[ string widget = "checkBox" ]], int Fresnel = 1 [[ string widget = "checkBox" ]], /* Anisotropy section */ float Anisotropy = 0.25, // Fabric is anisotropic due to weave. float Aniso_rotation = 0, /* Bump section */ string Bump_texture = "", float Bump_amount = 1.0, output color result = 1 ) { /* Define Bump */ normal bumped_normal = N; if (Bump_amount > 0.0) { float delta = 0.004; color center = texture(Bump_texture, u, v); color uColor = texture(Bump_texture, u + delta, v); color vColor = texture(Bump_texture, u, v + delta); bumped_normal = getBumpedNormal(center, uColor, vColor, 1.0 / Bump_amount); } /* Define Main color */ color MainColor = texture (Diffuse_color, u, v, "missingcolor", color(1,0,0)); MainColor = pow (MainColor, 2.2); /* Define Edge color */ color TintBoost = transformc("hsl", MainColor); TintBoost[2] = pow (TintBoost[2], 0.2); TintBoost[2] = clamp(TintBoost[2],0,1); TintBoost = transformc("hsl","rgb", TintBoost); color EdgeColor = Sheen_color / 10; color TintEdge = EdgeColor * TintBoost; EdgeColor = mix (EdgeColor, TintEdge, Sheen_tint); EdgeColor = clamp (EdgeColor, 0, 1); /* Define Spec color */ color SpecColor = Spec_color; color TintedSpec = SpecColor * TintBoost; SpecColor = mix (SpecColor, TintedSpec, Sheen_tint); /* Define Ramp */ float facingRatio = 1 - abs(dot(I, bumped_normal)); if( Sheen_ramp_type == 1) // linear {facingRatio = facingRatio; } if( Sheen_ramp_type == 2) // exponential (Down) { facingRatio *= facingRatio; } if( Sheen_ramp_type == 3) // smooth { facingRatio = smoothstep (0,1, facingRatio ); } if( Sheen_ramp_type == 4) // sigmoid S-curve { float Sigmoid = facingRatio / (1 + abs(facingRatio)); facingRatio = clamp( 2 * Sigmoid, 0, 1); } if( Sheen_ramp_type == 5) // square root { facingRatio = sqrt (facingRatio); } if( Sheen_ramp_type == 6) // fresnel { facingRatio = 2 * fresnelReflectionFactor(bumped_normal, IOR); } /* Fresnel */ if (Fresnel) { SpecColor *= fresnelReflectionFactor(bumped_normal, IOR); } if (Trace_reflections) { MainColor *= (1.0 - SpecColor); } /* BRDF Mixes*/ color SheenMix = EdgeColor * facingRatio * Sheen_opacity; color EdgeMask = mix(1, Sheen_color, (facingRatio * Sheen_opacity) ); MainColor *= EdgeMask; MainColor *= (1.0 - SheenMix); closure color sheen_component = SheenMix * diffuse(bumped_normal, "roughness", Diffuse_roughness); closure color diffuse_component = MainColor * Diffuse_weight * diffuse(bumped_normal, "roughness", Diffuse_roughness); closure color specular_component = Spec_amount * SpecColor * vray_blinn (bumped_normal, Spec_glossiness, Anisotropy, Aniso_rotation, "subdivs", Subdivs, "trace_reflections", Trace_reflections); closure color reflect_component = SpecColor * reflection(bumped_normal, IOR); Ci = diffuse_component + specular_component + reflect_component + sheen_component; }
