This texture creates a procedural flake normal map that can be used e.g. for car-paint-like materials. It is intended to be used as a normal map inside the bump slot of a material. Note that the map does not perform any filtering, so small flakes require a lot of AA samples to get clean.
The shader code is here: flakes.osl; a sample scene for 3ds Max is here: flakes.zip
Outputs
result - the flake normal map color
alpha - a black and white mask for the flakes
Inputs
flake scale - scales the entire flake structure up or down. Larger values zoom out of the map.
flake size - the relative size of the flakes.
flake size variance - determines the randomness of the flake size. 0.0 means all flakes have the specified size.
flake normal orientation - blends between the random flake normal and the smooth surface normal.
Shader code
Here is the shader code:
shader
flakes
	float flake_scale = 10.0 [[ string description = "Smaller values zoom into the flake map, larger values zoom out" ]],
	float flake_size = 0.5 [[ string description = "Relative size of the flakes" ]],
	float flake_size_variance = 0.0 [[ string description = "0.0 makes all flakes the same size, 1.0 assigns random size between 0 and the given flake size" ]],
	float flake_normal_orientation = 0.0 [[ string description = "Blend between the flake normals (0.0) and the surface normal (1.0)" ]],
	output color result = 1.0,
	output float alpha  = 1.0
	float safe_flake_size_variance = clamp(flake_size_variance, 0.1, 1.0);
	vector cellCenters[9] = {
		vector( 0.5,  0.5,  0.0),
		vector( 1.5,  0.5,  0.0),
		vector( 1.5,  1.5,  0.0),
		vector( 0.5,  1.5,  0.0),
		vector(-0.5,  1.5,  0.0),
		vector(-0.5,  0.5,  0.0),
		vector(-0.5, -0.5,  0.0),
		vector( 0.5, -0.5,  0.0),
		vector( 1.5, -0.5,  0.0)
	point position = vector(u, v, 0.0);
	position = flake_scale * position;
	point base = floor(position);
	point nearestCell = point(0.0, 0.0, 1.0);
	int nearestCellIndex = -1;
	for(int cellIndex = 0; cellIndex < 9; ++cellIndex)	{
		point cellCenter = base + cellCenters[cellIndex];
		vector centerOffset = cellnoise(cellCenter) * 2.0 - 1.0;
		centerOffset[2] *= safe_flake_size_variance;
		centerOffset = normalize(centerOffset);
		cellCenter += 0.5 * centerOffset;
		float cellDistance = distance(position, cellCenter);
		if(cellDistance < flake_size && cellCenter[2] < nearestCell[2]) {
			nearestCell = cellCenter;
			nearestCellIndex = cellIndex;
	result = color(0.5, 0.5, 1.0);
	alpha = 0.0;
	if (nearestCellIndex != -1) {
		vector randomNormal = cellnoise(base + cellCenters[nearestCellIndex] + vector(0.0, 0.0, 1.5));
		randomNormal = 2.0 * randomNormal - 1.0;
		randomNormal = faceforward(randomNormal, I, randomNormal);
		randomNormal = normalize(mix(randomNormal, vector(0.0, 0.0, 1.0), flake_normal_orientation));
		result = color(0.5*randomNormal[0]+0.5, 0.5*randomNormal[1]+0.5, randomNormal[2]);
		alpha = 1.0;
