This page provides information about the Atmospheric Effects render channel in V-Ray for Blender.
The Atmosphere Render Channel stores only atmospheric or volumetric participating media such as Environment Fog or Aerial Perspective. This render channel can then be used to enhance or color-correct just the atmospheric component of the image during the compositing process.
When atmospheric effects or fog are included in a scene, they are rendered into the Atmospheric Effects channel for compositing use.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Beauty > V-Ray Atmospheric Effects
Properties
Channel Name – Customizable name for the render channel.
Enable Deep Output  Specifies whether to include this render channel in deep images.
Color Mapping  Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Filtering – Applies an image filter to this channel.
Denoise – Enables the render channel's denoising, provided the Denoiser is enabled.
