This page provides information about the Falloff node in V-Ray for Cinema 4D.
To create the texture, Falloff starts with two colors, usually black and white. Placement of these colors on the surface is based on the Falloff Type and Falloff Direction selected. The remainder of the map is generated as a gradient between these two colors, with a gradual falloff between the colors.
For the example shown on the right, Falloff is used in the Diffuse channel of a V-Ray Material. The Falloff type is set to Perpendicular/parallel with the falloff Direction set to World Y Axis. Solid Colors of bright orange and dark red are used for the Front and Side Color parameters.
Falloff Type – Specifies the type of falloff:
Towards/Away – Based on face normal directions. Faces with normals that point in the Falloff Direction generate the Front Color, while those facing in the opposite direction (180 degrees away from the Falloff Direction) generate the Side Color.
Perpendicular/Parallel –Based on face normal directions. Faces with normals that point in the Falloff Direction generate the Front Color, while those facing in a perpendicular direction (90 degrees off the Falloff Direction) generate the Side Color.
Fresnel –Based on changes to the Index of Refraction (IOR) over the surface, due to Fresnel calculations. Faces with normals that point in the Falloff Direction generate the Front Color and those facing in other directions generate varying colors, depending on the IOR set by the Fresnel IOR.
Distance Blend – Sets the falloff range based on distance from the camera, as specified by Near Distance and Far Distance. This option is useful for generating a Z-depth type of map when rendering a very large object such as terrain, where the Falloff Map can be used as a mask to dim distant details.
Falloff Direction – Specifies the falloff direction to be used by the Falloff Type.
View Z – Uses the camera viewing direction. This is the most common selection.
View X / View Y – Uses one of the camera's other axes.
Explicit – Uses the direction specified by the Explicit Direction parameter.
Local X/ Y / Z – Uses one of the object's local axes.
World X/ World Y / World Z – Uses one of the world axes.
Fresnel IOR – Defines the IOR (Index of Refraction)when Falloff Type is set to Fresnel.
Distance Extrapolate – When enabled, the effect continues beyond the range set by Near Distance and Far Distance. Parts of the surface nearer than Near Distance receive the Front Color, while parts farther from the camera than Far Distance receive the Side Color.
Distance Near – When Falloff Type is set to Distance Blend, parts of the surface at this distance from the camera receive the Front Color.
Distance Far – When Falloff Type is set to Distance Blend, parts of the surface at this distance from the camera receive the Side Color.
Explicit Direction – Specifies the direction for falloff, when Falloff Direction is set to Explicit.
