This page describes how to set up your local system so that it loads the files for the correct V-Ray version.
Since V-Ray 6, update 1 the Portable installation replaces the .zip builds. See the Portable installation page for more.
Installing V-Ray for Cinema 4D from a .zip file provides the advantage of easy setup and flexible folder management.
When installing V-Ray for Cinema 4D from a .zip file, note that Chaos Cosmos is not included by default in the installation. To add it, you can separately download and install it.
Note also that the EULA is not automatically accepted when installing from a .zip file. A window pops up, when V-Ray is first initiated in Cinema, which prompts you to accept the End User License Agreement.
Download V-Ray for Cinema 4D
Required Steps
  1. Unpack the .zip file to a directory of your choice.
  2. Cut or copy the V-Ray folder.
  3. Paste it to the Maxon's plugins folder.
    For Windows, by default, it is located in C:\Program Files\Maxon Cinema 4D Rxx\plugins.
    For macOS, by default, it is located in /Aplications/Maxon Cinema 4D RXX/plugins.
    If you already have an existing V-Ray folder there, replace it with the one from the archive.
  4. You are all set and ready to start Cinema 4D, where V-Ray is automatically loaded.
Note
Note that the GPU device selection tool is not located in the default plugins location, instead it can be found under:
For Windows: C:/Program Files/Maxon Cinema 4D R26\plugins\V-Ray\res\libs\win64
For macOS: /Applications/Maxon Cinema 4D R26\plugins\V-Ray\res\libs\win64
