This page provides information about the Refraction Filter Render Element in V-Ray for Cinema 4D.
In comparison, the Raw Refraction Render Element is a color render element that takes materials and their colors into account when rendering refraction. Multiplying these two render elements together produces the Refraction Render Element.
UI Path: ||V-Ray|| > Render Elements > Refraction Filter
How to add a render element to a scene
Properties
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – Applies the color mapping options specified in the Color Mapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – Applies the post-render color adjustments made from the VFB.
Compositing Example
In this example, we have multiplied (i.e., set the Blend mode to Multiply) the Raw Refraction RE by the Refraction Filter RE to create the Refraction RE. This gives us better control over the final Refraction RE.
