Managing Jobs Rendered in Chaos CloudThis page provides information on managing render jobs through a command line interface in Chaos Cloud Rendering.
With Chaos Cloud Rendering you are able to submit, queue, monitor, and organize your render jobs across projects. To manage render jobs in Chaos Cloud you can use its web-based interface or a command line interface. This page explains how to manage render jobs via а command line interface. All of the functions can be carried out manually with any command line tool, without opening a browser. To do so, you first have to navigate to the location of chaoscloud or chaoscloud.exe on your machine.
For some more examples on how to use the command-line interface of Chaos Cloud Rendering, see the Common Use Cases page.
Default locations:
  • Windows – %APPDATA%\Chaos\Cloud\client\ccloud.exe
  • macOS  $HOME/.Chaos/Cloud/client/ccloud
  • Linux – $HOME/.Chaos/Cloud/client/ccloud.bin
Managing Jobs Through a Command Line Interface
The table below lists all available flags and commands. All commands can be run with multiple tags.
CommandFlag(s)Flag meaningFunctionExamples
auth login
Logs in to Chaos Cloud.
ccloud auth login
auth logoutLogs out of Chaos Cloud.ccloud auth logout
pack
-h, --help,
--output (string)
--sceneFile (string)
Help for pack
Output directory
Path to a .vrscene file
Pack a V-Ray scene and all of its assets into a single directory.
The result from this operation is a directory, called 'package' which contains everything this scene needs to be rendered with V-Ray Standalone. The name of the package directory is the same as the name of the scene file.
All the resources referenced in the .vrscene file are set together into a 'resources' sub directory in the package. The .vrscene file itself is copied as well but transformed so that relative paths to these resources are used instead of the original paths, which may be absolute. This ensures the scene can then be rendered on other computers.
ccloud pack --sceneFile /drive/me/scenes/alfa-red-scene/alfa-red.vrscene --output /drive/me/store/
eula
Prints out the EULA.
ccloud eula
job cancel--id (required)Render Job IDCancels a Chaos Cloud job.ccloud job cancel --id=X8hC6Xg2cb8JeL5
job delete--id (required)Render Job IDDeletes a Chaos Cloud job.ccloud job delete --id=X8hC6Xg2cb8JeL5
job download
--id (required)
--no-progress
--output (required)
Render Job ID
Do not display progress when downloading
Path to output folder
Downloads outputs of a Chaos Cloud job. Multiple jobs can be requested with multiple instances of the --id flag or by separating them with commas, e.g.: 'job1,job2,job3'.
ccloud job download --id=X8hC6Xg2cb8JeL5 --output="C:\Users\Me\Desktop"
ccloud job download --id JobID1,JobID2,JobID3 --output "C:\Users\Me\Desktop"
job list
--format (string)
--name (string)
--project (string)
--status (string)
Sets the format of each job line. Formatting is done via 'verbs', each of which corresponds to a particular property of the job. Verbs are added in double curly braces, following a dot, e.g. '.Verb'. The supported verbs for a job are: Name, ID, Status, Project, CreatedAt. Special formats such as 'full' are recognized. They define a particular format string.
If the --json global flag is used, then --format is ignored and JSON is always emitted for every job. (default ".ID\t{{.Name}}")
Filters only jobs which have one of the names.
Filters only jobs which belong to this project.
Filters jobs with this status. Possible statuses: uploading, upload-failed, upload-cancelled, uploaded, active, completed, failed, cancelled, paused.
ccloud job list --project PROJ1 --project PROJ2
job pause--id (required)Render Job IDPauses a Chaos Cloud job.ccloud job pause --id=X8hC6Xg2cb8JeL5
job rename
--id (required)
--title (required)
Render Job ID
The new title of the V-Ray Cloud job
Renames a Chaos Cloud job.ccloud job rename --id=X8hC6Xg2cb8JeL5 --title="Marbles"
job submit
--sceneFile (required)
--animation
--colorCorrectionsFile
--creditLimit
--frameRange
--frameStep
--height
--width
--ignoreWarnings
--name
--no-progress
--preserveAlpha
--project
--allCameras
--batchFile*
--onlyUpload
--downloadOutput
--camera (stringArray)
Path to .vrscene file
Renders animation instead of a single shot
Path to color corrections file
Sets credit limit per job (still images only)
Frame range of the animation
Frame step of the animation
Height of the rendered image
Width of the rendered image
Ignore warnings in scene file processing
Name of the rendering job
Do not display progress while submitting
Preserve alpha channel of PNG output
Name of the rendering project
Render all cameras in the scene. Applicable for multi-camera scenes
String Path to a JSON file which describes a batch submit
Uploads the scene without rendering
Uploads a set of scenes, waits them to complete rendering and download the outputs
Render specific cameras. The names given need to match those of the cameras in your scene, which you want to render.
Submits a V-Ray scene to Chaos Cloud.
ccloud job submit --sceneFile="C:\Users\Me\Desktop\soccer.vrscene--project="Project Cloud" --width=1280 --height=720 --creditLimit 0.01
ccloud job submit --batchFile
"project": "Project Name",
"scenes": [
"path": "path/to/file.vrscene",
"name": "Example Job Name",
"creditLimit": 2
"path": "path/to/second/scene.vrscene",
"name": "Second Job",
"colorCorrections": "path/to/corrections/file",
"frameRange": "59-300",
"frameStep": 2,
"width": 640,
"height": 480,
"onlyCPU": true,
"onlyUpload": true
"path": "path/to/third/simple.vrscene"
"layers": true
job resubmit
--id (required)
--animation
--frameRange
--frameStep
--height
--width
--ignoreWarnings
--name
--no-progress
--preserveAlpha
--project
--onlyUncompleted
Render Job ID
Clones a job only with the frames that are not in a completed state (failed, canceled, paused)
Resubmits a V-Ray scene to Chaos Cloud.ccloud job resubmit --sceneFile="C:\Users\Me\Desktop\soccer.vrscene --project="Chaosology" --animation --frameRange=30 --ignoreWarnings
job start--id (required)Render Job IDStarts a V-Ray Cloud job.ccloud job start --id=X40YITIaqtb_94E
job status--id (required)Render Job IDPrints status info for a Chaos Cloud job. If an animation has uncompleted frames, it prints information about them, too.
job report
--json (required)
--id (required)
Formats the data into a .json message.
The ID of the job, for which the report is generated. There can be multiple ID flags, depending on how many jobs need to be included in the report.
Fetches report information on specified jobs and formats it into a .json file.
--json job report --id X8hC6Xg2cb8JeL5 --id X40YITIaqtb_94E
project create
--name (required)
--default
Name of the project
Marks the project as default
Creates a new project.ccloud project create --name="Cloudy" --default
project delete--name (required)Name of the projectDeletes a project.ccloud project delete --name="Drains"
project listLists available projects.ccloud project list
project rename
--name (required)
--to (required)
Name of the project
The new name of the project
Renames a Chaos Cloud project.ccloud project rename --name="Marbles" --to="Drains"
updateUpdates the Chaos Cloud Client.ccloud update
versionPrints Chaos Cloud Client version info.ccloud version
version check
Prints out if there is a newer version than the installed and/or if the current version is deprecated.ccloud version check
helpPrints command information.ccloud help; ccloud job help; ccloud job submit help
A 'batch' is a set of .vrscene files which are submitted at once. Individual settings for each file must be placed in the batch file itself. When used, the following flags are ignored:
--height
--width
--creditLimit
--name
--project
--frameStep
--frameRange
--onlyUpload
How to Get a Job ID
The ID of a render job can be obtained in two ways:
  • from the Chaos Cloud's URL of the web interface when the Job Details page is open
  • upon submission, through а command line interface, as shown in the image below
For more information, see Submitting Render Jobs Through the Chaos Cloud application (command line).
HowToGetAJobID_CommandLineInterfacе
