This page provides information about the V-Ray-supported versions of platforms that can use Chaos Cloud Rendering.
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene. For example, a scene created with V-Ray 7 is rendered with the latest publicly available version of V-Ray 7.
The Chaos Support team provides support for the following products:
- V-Ray 7 for: 3ds Max, Maya, SketchUp, Rhino, Houdini, Revit, Blender, and Cinema 4D
- V-Ray 6 for: 3ds Max, Maya, SketchUp, Rhino, Houdini, Revit, and Cinema 4D
- V-Ray 5 for: Revit
All failed jobs created with earlier V-Ray versions will still be automatically refunded. However, the Chaos Support teams won't investigate issues with such jobs.
Cloud Rendering Compatibility
Product Versions | V-Ray 7 | V-Ray 6 | V-Ray 5 | V-Ray Next | V-Ray 3.6 | ||||||||||
Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS | |
3ds Max® | 2020 & later | - | - | 2018-2025 | - | - | 2016-2023 | - | - | 2013-2021 | - | - | - | - | - |
Maya | 2022 & later | 2022 & later | 2022 & later | 2019-2025 | 2019-2025 | 2019-2025 | 2017-2023 | 2017-2023 | 2017-2023 | 2015-2020 | 2015-2020 | 2016.5-2020 | - | - | - |
Cinema 4D | R21 & later | - | R21 & later | R21-2025 | - | R21-2025 | R20-R26 | - | R20-R26 | - | - | - | R18-R21* | - | R18-R21* |
Houdini | 19.5, 20.0, 20.5 | 19.5, 20.0, 20.5 | 19.5, 20.0, 20.5 | 19.0, 19.5, 20.0, 20.5 | 19.0, 19.5, 20.0, 20.5 | 19.0, 19.5, 20.0, 20.5 | 18.5, 19.0, 19.5 | 18.5, 19.0, 19.5 | 18.5, 19.0, 19.5 | 18.5.499 & later | 18.5.499 & later | 18.5.499 & later | - | - | - |
Blender | 4.2 LTS, 4.3, 4.4 | - | - | - | - | - | - | - | - | - | - | - | - | - | - |
Revit | 2021 - 2025 | - | - | 2019-2025 | - | - | 2018-2023 | - | - | 2015-2019 | - | - | 2015-2018 | - | - |
Rhino | v7(7.15.22039.13001 & later) v8(8.4.24044.15001 & later) | - | - | v6(6.29.20238 & later) v7(7.0.20314 & later) | - | - | v6(6.29.20238 & later) v7(7.0.20314 & later) | - | - | v5(5.14 & later, 64-bit only) | - | - | 5.14 & later (64-bit only) 6.6.18117 & later | - | - |
SketchUp | 2021-2025 | - | 2021-2025 | 2019-2024 | - | 2019-2024 | 2017-2022 | - | 2017-2022 | 2016(64-bit)-2020 | - | 2016(64-bit)-2020 | 2015-2018 | - | 2015-2018 |
Modo | - | - | - | - | - | - | - | - | - | 901-13 | - | 901-13 | Modo 701 (SP5) 801 (SP2 or higher) & later | - | Modo 701 (SP5) 801 (SP2 or higher) & later |
*Only still images are supported in Chaos Cloud Rendering with V-Ray 3.7 for Cinema 4D.
Chaos Support
Product | V-Ray 7 | V-Ray 6 |
3ds Max® | ||
Maya | ||
Cinema 4D | ||
Houdini | ||
Blender | ||
Revit | ||
Rhino | ||
SketchUp | ||
Modo |
