Build 2.50.01
Official release
Date - 14 May 2014
New features
- Support for 3ds Max 2015;
- VRayProxy: Support for Alembic 1.5;
- Added VRayBumpMtl material that allows to add bump to any other material;
Modified features
- VRayMultiSubTex: Added an option to preserve the alpha of the sub-textures;
- VRayProxy: Make the "Animation offset" parameter animatable;
Bug fixes
- V-Ray loses its license when RPManager is running;
- V-Ray RT: The SettingsCurrentFrame was not exported in .vrscene files;
- V-Ray RT GPU: Fixed crash with static geometry rendering;
- VRayCarPaintMtl and VRayFlakeMtl: Wrong material name in info message in 3ds Max 2013 and later;
- VRayDisplacementMod: Fixed a very slow rendering when Noise texture with animated parameter was used;
- VRayDistanceTex: Setting tex_inside_separate_on:true for a VRayDistanceTex constructor from MAXScript causes system exception;
- VRayExtraTex: Cloning VRayExtraTex element didn't clone the include/exclude list;
- VRayIES: Fixed a rare crash when loading scenes with VRayIES;
- VRayIES: Fixed crash after VRayIES light was created in 3D snap mode and 3ds Max was Reset;
- VRaySphereFade: Could not edit the gizmo objects list through MAXScript;
- VRayToon: Could not edit the exclude list through MAXScript;
- VRayLightMtl: Fixed random lighting between renderings with DirectIllumination and CompensateExposure on;
- Fixed truncated error messages in the V-Ray log for missing textures in 3ds Max 2013 and later;
- Increase the max stdio file handles to the maximum possible (2048) on 3ds Max startup;
- Some bake elements has duplicate class names of other plugins;
- The V-Ray caustics Auto save option is errorneously named casutics_autoSave in MAXScript;
- VRScene exporter didn't work for SSS2 materials;
Build 2.40.04
Official release
New features
- Support for 3ds Max 2014;
- V-Ray RT: Support for MultiScatter instancing;
- V-Ray RT: Support for Phoenix FD 2.1;
Modified features
- V-Ray: Changed default settings of VFB's sRGB button, "Don't affect colors" option and "Gamma" value to suit Linear Workflow from the start;
- VRayCarPaint: Added support for displacement texture channel;
- VRayHDRI: Made file open dialog to remember the last used file type filter;
- VRayHDRI: The image file is now reloaded if it had been changed outside 3ds Max;
- VRayMtl: Added Self-illumination slot;
- Raw OpenEXR files now have ZIPS compression by default;
Bug fixes
- VRayProxy: Objects pointing to vrmesh files without extension did not render;
- V-Ray RT: Fixed crash when a texmap is attached to an disabled environment override slot;
- V-Ray RT: Fixed error during initialization when Auto update bitmaps is enabled;
- V-Ray RT: Fixed wrong DOF with physical camera;
- V-Ray RT GPU: Fixed crash with materials with mapped IOR;
- VRayIESLight: Fixed issue causing wrong override shape dimensions when loading, if the previous scene had different units setup;
- VRayMultiSubTex: Fixed issue preventing drag and drop operations for subtex with index greater than 20;
- VRayPTex: Fixed a crash at the end of a rendering;
- V-Ray Light Lister: Fixed error in 3ds Max 2014;
Build 2.40.03
Official release
Bug fixes
- VRayMtl: Incorrect render of translucency;
- VRayProxy: Fixed crashes when rendering proxies with point clouds and motion blur enabled;
- V-Ray RT GPU: Light portals did not render correctly;
- V-Ray RT GPU: VRayMtl opacity mapped with VRayColor texture did not work;
Build 2.40.02
Official release
Bug fixes
- VRayProxy: Fixed crashes when rendering proxies with point clouds;
- VRayProxy: Added an option whether to use point clouds if present in the .vrmesh file;
- VRayLight: Clicking the center of the light selected the line between the light and the target rather than the light itself;
- VFB: Fixed mixed language interface issue when rendering through BackBurner;
- Hair&Fur: Fixed crash at the end of the rendering with 3ds Max 2013 (unfortunately this reintroduces a memory leak);
- VRayFur: The level of detail parameters should use display units;
Build 2.40.01
Official release
Date - 21 January 2013
New features
- VRayHairFarmMod: Added support for rendering HairFarm 2.0 with V-Ray;
- VRayProxy: Support for Alembic .abc files;
- V-Ray RT: Support for instancing;
- V-Ray RT: Support for Forest Pro instancing;
- V-Ray RT CPU: Faster update when adjusting VRayLights;
- V-Ray RT GPU: CUDA speed optimizations and optimizations for GK110 cards;
- V-Ray RT GPU: Support for the ColorCorrection texture;
- V-Ray RT GPU: Support for the Mix texture;
Modified features
- V-Ray: Added include/exclude object lists for different color channels to the MultiMatte render element;
- V-Ray: Added option to the VRayExtraTex render element to avoid auto-renaming the element when the texture is changed;
- V-Ray: Default memory limit for dynamic geometry changed to 4000 MB for x64 versions;
- V-Ray: Fixed issue that was slowing down multi-core rendering for VRayProxy objects;
- V-Ray: Optimized multi-core rendering for OpenEXR textures;
- V-Ray: Optimized unnecessary velocity calculations when no velocity channel is needed;
- V-Ray: V-Ray components now register in the respective menus across different language 3ds Max builds;
- V-Ray RT CPU: Added support for VRayHairMtl;
- V-Ray RT CPU: Added support for VRayFur;
- V-Ray scene converter: Added mr_Sun/mr_Sky lights in export to VRaySun/VRaySky respectively;
- V-Ray scene exporter: Added subdivided geometry export;
- VRayEdgesTex: Improved the round corners algorithm;
- VRayAmbientLight: Made some of the parameters animated;
- VRayFur: Added "Level Of Detail" option to reduce geometry along the distance from the camera;
- VRayHDRI: Added "Color space" section and moved the "Gamma" option there;
- VRayIESLight: Added an option to override the IES shape;
- VRayIESLight: Made selecting both the light and it's target when clicking on the line between them;
- VRayLight: Added a preview of the "directionality" parameter of VRayLights in the viewports;
- VRayLight: Added "targeted" option for rectangle VRayLights;
- VRayLight/VRayIESLight: Added textured lighting in Nitrous viewport, for Dome light enabled by an environment variable VRAY_DOME_VIEWPORT=1;
- VRayMeshGeom: The sample plugin was extended to create V-Ray Standalone shaders on the fly;
- VRayMtl: Made "Fog color" mappable;
- VRayMtl: Made reflections to affect the alpha of matte objects;
- VRayMtlGLSL: Added ability to save and load compiled shaders;
- VRayMtlGLSL: Added cubemap texture support;
- VRayMtlGLSL: Added viewport color parameter;
- VRayMtlGLSL: Added vr_brdf_light builtin BRDF support;
- VRayProxy: Support for flipping of Z/Y axis;
- VRayProxy: Support for visibility lists for .vrmesh and .abc files;
- VRaySphereFade: Added support for box and cylinder gizmos;
- ply2vrmesh: Added option to specify the name of the velocity attribute (-velocityAttrName);
- ply2vrmesh: Added support for .hclassic and .bhclassic files produced by Houdini 12;
- ply2vrmesh: Added support for color sets from .bgeo files;
- ply2vrmesh: Added support for exporting the face and vertex normals in .geo and .bgeo files;
- ply2vrmesh: Added ability to store the V-Ray user attributes when creating a proxy;
Bug fixes
- Hair&Fur: Fixed crash when lit by VRayLightMtl with Direct Illumination on;
- Hair&Fur: Fixed incorrect result with VRayHairInfoTex texture in "Position along strand" mode;
- Hair&Fur: Fixed random swap of custom materials between different Hair&Fur modifiers when reloading a scene;
- Hair&Fur: Fixed memory leak after rendering a frame since V-Ray 2.3;
- imapviewer: Fixed crash when incrementally loading irradiance maps;
- V-Ray: Enabled by default all channels in the MultiMatte render element;
- V-Ray: Fixed crash when pressing the "Remove" button in the VRayLightSelect element with empty lights list;
- V-Ray: Fixed export of objects with ':' in the names, failing to compose file name;
- V-Ray: Fixed incorrect normals for ParticleFlow systems with ShapeInstance where the instanced object has explicit normals;
- V-Ray: Fixed issue causing random crashes when updating material swatches with VRayCarPaintMtl material or bitmap textures;
- V-Ray: Fixed issue causing white edges on matte objects lit with 3ds Max lights with area shadows;
- V-Ray: Fixed issue with V-Ray object properties not applied when changing more than one at a time;
- V-Ray: Fixed misspelled "caustics_autoSave" maxscript property;
- V-Ray: Fixed some warnings that appeared incorrectly due to 3ds Max 2013 Unicode support;
- V-Ray: Fixed standard lights' "Atmosphere shadows" option of doesn't work properly with area VRayShadows;
- V-Ray: Fixed UI issue with MultiMatte render element RGB channel names;
- V-Ray: Fixed V-Ray materials' to appear in the respective categories in the material editor;
- V-Ray RT: Fixed Maxscript access for .warn_unsupported property;
- V-Ray RT: Fixed VRayBlendMtl as coat of another VRayBlendMtl to render properly;
- V-Ray RT: Mirroring instance of VrayIES light using Offset spinner while running RT sent the light to wrong coordinates;
- V-Ray RT: GI multipliers by object which are greater than 1.0 were not working in RT;
- V-Ray RT CPU: Fixed artifacts in layered materials;
- V-Ray RT GPU: Fixed calculations precision on CUDA and OpenCL rendering causing artifacts;
- V-Ray RT GPU: Fixed crash with 8-bit texture mode and light textures;
- V-Ray RT GPU: Fixed OpenCL issue with wrong transparent shadows with motion blur;
- V-Ray RT GPU: Fixed OpenCL issue with motion blurred dome lights;
- V-Ray RT GPU: Scaled IES lights produced different result from the production renderer;
- V-Ray scene exporter: Fixed photometric lights conversion to IES lights;
- V-Ray scene exporter: Fixed Render Elements manager retrieval when selected ActiveShade rendering;
- VFB: Fixed issue with multithreaded ICC profiles loading, that could cause either miscalculations or crash;
- VRayCarPaint/VRayFlakesMtl: Fixed issue with the flakes layer not respecting the global reflection depth limit;
- VRayDisplacementMod: Fixed crash when "Edge length" option is set to 0,0;
- VRayDisplacementMod: Fixed incorrect displacement result on mirrored geometry when using Noise modifier and motion blur;
- VRayDistanceTex: Fixed to work as bump map;
- VRayFlakesMtl: Fixed wrong buckets when rendering with DMC sampler;
- VRayGLSLMtl: GLSL materials were receiving no GI when evaluating shaders executed in light loop mode;
- VRayHairMtl: Fixed random crash in case when applied to normal geometry;
- VRayHairMtl: Optimized material sampling;
- VRayIESLight: Fixed an issue preventing the light to be selected in the viewport with no IES profile assigned;
- VRayIESLight: Fixed "Autogrid" option in creation mode;
- VRayIESLight: Fixed crash when setting ies profile through MAXScript;
- VRayLensEffects: Fixed issue with remaining render elements in the VFB when the effect is deleted;
- VRayLight: 3ds Max crash with dome light;
- VRayLight: Fixed incorrect tab order of UI controls;
- VRayLight: Fixed issue causing the UI to disappear when switching the light type in 3ds Max 2013;
- VRayLight: Fixed issue causing the UI to malfunction when toggling "enable HW lighting" during creation;
- VRayLight/VRayIESLight: Fixed issue with enabling/disabling Nitrous viewport lighting;
- VRayLight/VRayPhysicalCamera: Fixed issue with instanced targeted Vray cameras and lights causing flickering of "target distance" parameter;
- VRayLightMtl: Fixed issue when in X-Ref'd scene with direct illumination mode on;
- VRayMtl: Fixed "Affect shadows" option to work with enabled caustics;
- VRayEnvironmentFog: The "fog height" parameter could not take negative values;
- VRayOrnatrixMod: Fixed issue concerning hairs collections with varying number of guide points per strand;
- VRayPhysicalCamera: Fixed the "Horizontal offset" and "vertical offset" options showing different result in the viewport and the render;
- VRayPhysicalCamera: Fixed issue with animated zoom and motion blur;
- VRayPlane: Fixed rendering with VRayBPTracer;
- VRayStereoscopic: Fixed shade map improperly generated file names;
- VRayBlendMtl: Displacement in the base material was not rendered;
- VRayFastSSS2: Fixed artifacts when rendering point-cached motion-blurred geometry with displacement;
- ply2vrmesh: Fixed crash during RealFlow .bin files conversion;
- ply2vrmesh: Fixed crash when converting .obj file containing face definitions with negative indexes;
Build 2.30.01
Official release
Date - 28 April 2012
New features
- Support for 3ds Max 2013;
- Support for the new shading features of Hair&Fur in 3ds Max 2013;
- VRayOrnatrixMod: support for Ornatrix 2.0;
- Added a "Matte for reflection/refraction" option to the VRayWrapperMtl material and the V-Ray object settings;
- V-Ray RT and V-Ray RT GPU: support for motion blur (transformation and deformation) both in ActiveShade mode and as a production renderer;
- V-Ray RT GPU: added a CUDA engine, in addition to OpenCL (64-bit builds only; requires a Fermi or Kepler card and the newest nVidia drivers);
Modified features
- VRayOrnatrixMod: support for Ornatrix thickness maps;
- Added the possibility to specify a preview mesh for the vrayMeshExport MAXScript function;
- Support for motion blur of V-Ray mesh lights;
- Reduced memory usage and increased speed for dynamic geometry (proxies, displacement etc) in specific situations;
- VRayHDRI: added crop/place options to VRayHDRI;
- VRayHDRI: added Output and curves rollout to VRayHDRI;
- vrimg2exr: added support for RLE compression method for OpenEXR files to vrimg2exr;
- VFB: the V-Ray VFB ICC color correction now takes into account the gamma value from the Color Mapping settings of V-Ray;
- VRayPTex: increased the default cache size for VRayPTex textures;
- V-Ray scene converter: now converts IES lights and mr sun/sky in a Daylight system;
- V-Ray RT GPU: support for sub-pixel filtering;
- V-Ray RT GPU: ability to use full resolution textures;
- V-Ray RT GPU: option to specify material texture bit depth to help control GPU memory usage;
Bug fixes
- V-Ray materials saved as using Realistic viewport preview did not show up in the Direct3D viewports;
- VRayOrnatrixMod: hair radius was clamped (very small values rendered thicker than they should);
- VRayHairInfoTex: fixed invalid material colors;
- VRayHairMtl: fixed occasional crashes;
- VRaySimbiontMtl: fixed a crash when creating a VRaySimbiontMtl in the material editor in 3ds Max 2012;
- Fixed crashes with Particle Flow and motion blur;
- Fixed crashes with motion blur on meshes with changing topology;
- V-Ray RT: VRaySoftBox texture didn't work in V-Ray RT;
- V-Ray RT: "Reload" button in VRayHDRI did not work properly in 3ds Max 2009;
- V-Ray RT: fixed a crash when closing the ActiveShade window with the "Auto update bitmaps" option enabled;
- V-Ray RT: Crashes when scrubbing the time line with the ActiveShade window open;
- V-Ray RT GPU: a VRaySun light illuminated the scene even if it was disabled;
- Textures in the V-Ray environment slots did not show up in the Asset Tracker;
- VRayLensEffects: fixed crashes in specific situations;
- The V-Ray DR spawner did not work without administrator privileges;
- VRayEnvironmentFog: fixed incorrect rendering with scaled mesh gizmos;
- VRayEnvironmentFog: fixed issues interface issues when switching between different VRayEnvironmentFog effects;
- VRayShadowMap: fixed artifacts when rendered with VrayEnvironmentFog;
- VRayProxy: Proxy sequences loaded with '#' characters did not render with motion blur;
- VFB: Rendering failed when any of the render effects was enabled and "Render to memory frame buffer" was turned off;
- VFB: The "Show V-Ray VFB" command did nothing if the VFB was minimized;
- VFB: Fixed UI freeze if compare mode was turned on in the VFB and the user tried to render;
- VFB: When the VFB history was closed, it reopened on the next render;
- VRayPTex: Fixed artifacts in the reflection render element when using VRayPtex textures;
- imapviewer: fixed slowdown when merging light maps;
- VRayColor2Bump: fixed an issue large render resolutions;
- VRayDisplacementMod: fixed possible cracks between different subdivision levels when using subdivision displacement;
Build 2.20.01
Official release
Date - 4 December 2011
New features
- VRayHairMtl specifically for fur and hair rendering;
- VRayOrnatrixMod modifier for direct rendering of Ornatrix hair;
- VRayHairInfoTex texture for additional hair shading effects;
- VRayPTex texture provides support for PTex files;
- MAXScript functions for access to the V-Ray VFB contents;
- V-Ray RT: added "Real zoom" option to the ActiveShade quad menu to modify the rendered region (zoom, pan) directly in the ActiveShade window;
- MetaSL support in VRayGLSLMtl and VRayGLSLTex;
Modified features
- V-Ray RT GPU: initial support for VRayBlendMtl materials;
- V-Ray RT GPU: rendering of VRayProxy objects;
- V-Ray RT GPU: support for affect diffuse/specular/reflection for VRayLights;
- V-Ray RT GPU: support for simple skylight portals;
- V-Ray RT GPU: support for textured area and mesh lights;
- V-Ray RT GPU: limited support for the Falloff map;
- V-Ray RT GPU: support for Tiles and other procedural textures (through baking to bitmaps);
- V-Ray RT: ability to use the 3ds Max bitmap proxy system for the ActiveShade;
- V-Ray RT: support for 32-bit ActiveShade buffer;
- V-Ray RT: add a "Reload" button for VRayHDRI that works with V-Ray RT;
- Distributed rendering: option to specify a maximum number of render slaves;
- Distributed rendering: when a slave completes a DR render, it will automatically try to join other running DR jobs;
- ply2vrmesh: added support for .bgeo files in ply2vrmesh;
- ply2vrmesh: added -info option to ply2vrmesh to print information about .vrmesh files;
- Irradiance map format (*.vrmap) has changed - map files from V-Ray 2.20 cannot be opened by previous V-Ray versions;
- imapviewer: added -incremental command-line option and "File > Incremental add" menu item for incremental merge of irradiance maps produced by V-Ray 2.20;
- imapviewer: added ability to load and display light cache files;
- VRayMtl: added "Affect channels" option for reflections;
- VRayGLSL: split into a VRayGLSLTex texture and a VRayGLSLMtl material;
- VRayGLSLMtl: support for built-in BRDFs;
- VRaySun: added filter color for VRaySun;
- VRayMultiSubTex: added option to specify the number of IDs in VRayMultiSubTex;
- VRayMultiSubTex: reworked the VRayMultiSubTex texture to use lists of properties, rather than separate parameters;
- VRayFastSSS2: ability to save/load illumination maps for VRayFastSSS2 material;
- VRayHDRI: add the "time" rollout for controlling IFL files to VRayHDRI;
- VRayHDRI: support for tiled mip-mapped TIFF files;
- VRayHDRI: optimized VRayHDRI bitmap performance;
- VRayIES: expanded the "Use light shape" option for VRayIES to allow the shape to affect light distribution;
- VRayBPTracer: support for distributed rendering;
- VRayBPTracer: support for the VRayLightSelect render elements;
- VRayDisplacementMod: added option to smooth UVs for subdivision displacement;
- VRayLensEffects: improved multithreading for VRayLensEffects;
- Optimized memory usage and multithreaded performance for dynamic geometry;
- Optimized the VRay2SidedMtl material for GI calculations when translucency is greyscale;
- Add an option to the VRaySamplerInfo render element and texture to wrap the UVW coordinates in the [0,1] range;
- VFB: added ICC color correction to the V-Ray VFB;
- VFB: added right-click menu to the items in the V-Ray VFB history;
- VFB: right-click menu option to add and edit comments in V-Ray History per image;
- VFB: ability to do A/B VFB comparison with a rendered image in the V-Ray VFB;
- VFB: the frame stamp is now saved to and loaded from the V-Ray VFB history images;
- When writing a raw .exr file, V-Ray will attempt to produce a scanline version of the file instead of tiled one;
- Added a glossiness render element, also for texture baking;
- Added a Clear option for the Previous render list in the System rollout;
- Changed the default image sampler to Adaptive DMC;
- Exposed the irradiance map preview mode parameter in the UI;
- Reduced flickering of the irradiance map and light cache when "Time independent" DMC option is disabled;
- Disable any HSDS modifiers before saving the scene for DR;
- SDK: switched to Intel C++ 12.1 compiler;
- SDK: shaders can provide their own sampling rays for GI;
- SDK: multithreaded expansion of dynamic primitives;
Bug fixes
- Nitrous: VRayHDRI did not show up in Nitrous viewports;
- Nitrous: support for the VRaySky environment texture in the Nitrous viewports;
- Nitrous: the first time the user selects "Show realistic material in viewports" the objects with this material disappear;
- The material texture maps were not shown in the Max2012 shaded viewport;
- DR: fixed hanging buckets in specific cases;
- DR: slaves with missing files continuously tried to re-join a DR render when "restart slaves on render end" was on and "Check for missing files" was enabled;
- DR: if a render slave failed to receive the entire irradiance map from the client it still continued the render producing wrong buckets;
- VRayBPTracer: region rendering did not work;
- VRayFastSSS2 did not work correctly with light exclusion;
- Assigning a texmap to material texmapslot caused a crash when the texmap was disabled;
- Exclude from shadow casting did not work for VRayIES lights;
- Fixed a crash when rendering with Particle Flow emitted from animated geometry;
- Fixed a crash with VRaySun when the scene is rendered with the scanline renderer;
- Fixed uneven motion blur for fast moving objects with many geometry samples;
- Scrubbing the time slider created keys for the FOV parameter;
- The .vrscene exporter script did not export the "cast shadows" property of lights correctly;
- The .vrscene exporter script did not detect animated textures properly;
- The .vrscene exporter script did not export correctly objects with animated topology;
- VFB: Pressing the "set A" or "set B" button when the VFB history is empty lead to a crash;
- VFB: Fixed a crash when importing specific .acv file;
- Relative path names for raw image files did not work;
- Crash with Particle Flow events in specific scene;
- VRayFlakesMtl material did not work with the VRayMtlSelect render element;
- Pixel Info window showed colors only for one image during A/B compare;
- Fixed artifact with light portals;
- The height parameter for VRayEnvironmentFog is now greyed out when there are gizmos attached;
- VRayEnvironmentFog did not allow to pick multiple gizmos and lights through the "Select by Name" dialog;
- Incorrect self-shadowing of hairs by themselves for VRayFur and the 3ds Max Hair & Fur modifier;
- Mapped VRayLightMtl does not work as direct light if the color is set to black;
- Hanging buckets with VRayBlendMtl material when one of the blend textures returns an invalid color;
- VRayStereoscopic shademap files were not closed after reading;
- VFB history did not display render times for history images;
- Disappearing geometry when VRayVelocity pass is used;
- Issues with the MAX.vray preset in 3ds Max 2012;
- AA filter type not saved in V-Ray presets;
- Loading a V-Ray preset does not respect the selected rollouts;
- Scripted materials are not handled properly when assigned as sub-materials;
- V-Ray RT: environment override slot in VRayMtl did not work with glossy materials;
- V-Ray RT: DOF did not work with animated cameras;
- V-Ray RT: gamma issues with the ActiveShade window;
- V-Ray RT: IFL sequences did not work with VRayHDRI;
- V-Ray RT: initialization error in stage 2 when Mix material is used as normal map;
- V-Ray RT: differences in RT with 3dsmax Composite map;
- V-Ray RT: environment override slot in VRayMtl materials doesn't work for glossy materials;
- V-Rat RT GPU: OpenCL code failed to compile with the latest nVidia drivers;
- V-Ray RT GPU: invisible dome lights were rendered as visible;
Build 2.10.01
Official release
Date - 3 May 2011
New features
- Separate VRayFlakesMtl material with just the flakes from the VRayCarPaintMtl material;
- Added VRayGLSL material for direct rendering of GLSL shaders with V-Ray extensions;
Modified features
- The V-Ray RT render server prints out some more information in GPU mode (useful for troubleshooting);
- Added access to the V-Ray material override exclude list from MAXScript;
- Support for the four FumeFX render elements;
- Ability to call the "Calculate" and "Save to CSV file" operations on the VRayLightMeter from MAXScript;
- The "Browse" button for the "Split channels" file name now opens the folder with the currently selected name (if any);
- Added an environment override slot for VRayCarPaintMtl material;
- Added bump slot for the base layer of VRayCarPaintMtl material;
- Ability to turn off "trace reflections" for separately for each layer of the VRayCarPaintMtl material;
- Added MAXScript function, vrayEditDRSettings(), to open the DR settings window;
- Added possibility to specify user command-line options to 3dsmax.exe when started from the V-Ray DR spawner;
- VRayMtlID and VRayObjectID render elements now have an option to generate colors instead of integers for proper antialiasing;
- XML output for the VRayRenderID render element;
- MAXScript-only option "dome_visibleOriginal" for dome lights to control filtering of the light texture for glossy rays;
- Added an option to VRayToon to compensate the camera exposure;
- Ability to map the radius in VRayDistanceTex with a texture;
- Option in VRayDistanceTex for a solid inside color;
- Custom V-Ray materials now work in the Hair&Fur modifier;
- Hair&Fur now produces the same object ID as the emitter object;
- The V-Ray bitmap to VRayHDRI converter script did not take into account the input gamma of textures;
- Crash with particular pre-render script that turns off V-Ray lights before rendering;
- VRayBlendMtl material blocks the material IDs of its sub-materials;
- V-Ray RT: Added support for RPManager material;
Bug fixes
- Noise with "Clamp output" option enabled produced noisy renders;
- Hilights from the base reflection layer of VRayCarPaintMtl material were darker than they should be;
- Slow rendering with many overlapping VRayProxy primitives;
- Randomly missing gizmos when rendering VRayEnvironmentFog;
- VRayLights that exclude an object could still affect that object through GI;
- Rendering with GI may use more detailed texture mip-map levels than necessary;
- VRayHDRI may not respect the specified memory limit for tiled textures;
- Crashes with particle systems with 3d displacement and motion blur enabled;
- Spikes with 3d displacement with "Keep continuity" enabled and particular bad geometry;
- Incorrect velocity element with VRayFur;
- Image copied from VFB to clipboard had the first column of pixels swapped for the last one;
- Loading an image in the V-Ray VFB with a different resolution did not work correctly;
- img2tiledexr used wrong formula when converting images from sRGB color space;
- vrim2exr did not preserve the pixel aspect information in the resulting .exr file;
- ply2vrmesh can convert RealFlow .bin files to .vrmesh files;
- VRayExposureControl was not accessible from MAXScript;
- Script error when there is a VRayPlane object in the scene;
- VRayPhysicalCamera in "Movie" mode was not exported correctly;
- Mesh lights were not exported with the .vrscene exporter script;
- Fringes on the edges of flakes in VRayCarPaintMtl material;
- Crash with VRayCarPaintMtl material when rendering of texture maps is globally disabled;
- Warning about "Retrace threshold" and "Use light cache for glossy rays" was printed even when not using the light cache;
- Exception after rendering when the "V-Ray raw image file" is chosen and the V-Ray VFB is not enabled;
- The V-Ray presets did not load if they were saved on a system where the decimal symbol is ",";
- The file save dialog for .vrimg/.exr files was not resizable;
- The VRayFastSSS2 material was not exported by the .vrscene MAXScript exporter;
- The VRayLightSelect element allowed the user to pick meshes instead of just lights;
- Incorrect velocity element when rendering Hair&Fur natively;
- The .dra file exported from the Hair&Fur plugin is now moved to the temporary 3ds Max folder instead of the root one;
- Wrong spelling for "affect specular" option in VRaySun;
- Slow rendering of VRayEnvironmentFog with animated Noise texture;
- V-Ray RT: Objects could disappear in animation;
- V-Ray RT: When used as production renderer, animation of deforming objects was ignored;
- V-Ray RT: Wrong exposure when physical camera type was "Move cam" or "Video cam";
- V-Ray RT: VRayEdgesTex was listed as incompatible with V-Ray RT;
- V-Ray RT: 3ds Max froze if V-Ray RT was working as an ActiveShade renderer and the user attempted to run V-Ray RT as production renderer;
- V-Ray RT: .vrscene export was not correct if the system decimal symbol was ",";
- V-Ray RT: When V-Ray RT was used as production renderer and max. paths per pixel was 0, it was always reset to 64;
- V-Ray RT: ActiveShade rendering is now paused when doing normal production rendering;
- V-Ray RT: Render restarted when changing a perspective view, even if the ActiveShade window was locked to using another camera;
- V-Ray RT: Scene was empty if motion blur was enabled;
- V-Ray RT: Problem with canceling batch render of animations;
- V-Ray RT: Adding new objects/lights is not reflected in the ActiveShade window in 3ds Max 2012;
- V-Ray RT: Standard camera FOV animation was not working;
- V-Ray RT: Support for the "Camera map per pixel" texture;
- V-Ray RT: ParticleFlow systems did not update when an animation with V-Ray RT as production renderer;
- V-Ray RT: Camera target distance was not updated correctly when rendering through Backburner;
- V-Ray RT: Issue with VRayLightMtl material inside a VRayBlendMtl material;
- V-Ray RT GPU: Textures for the color of VRayLightMtl material did not work;
Build 2.00.02
Official release
Date - 15 December 2010
Bug fixes
- VRayLights could render differently (brighter) from V-Ray 1.5;
- V-Ray RT: Right-clicking in the ActiveShade window to bring the quad menu could crash 3ds Max;
- V-Ray RT: Fog color in VRayMtl did not work in the CPU version;
- img2tiledexr would crash if it could not write the result due to permissions;
- Fixed noise with VRayBPTracer;
- Crash with VRayIES lights and VRayBPTracer;
Build 2.00.01
Official release
Date - 6 December 2010
New features
- VRayMultiSubTex texture to allow different colors/textures based on surface material IDs and object IDs;
- VRayExposureControl plugin for proper exposure of perspective and regular camera viewports;
- VRayLightMeter helper for lighting analysis;
- VRayCarPaint material with advanced metalic flake simulation;
- VRayLightSelect render element to hold the (direct) contribution of selected lights;
- VRayStereoRig that can be used together with the VRayStereoScopic helper to manually define the left and right cameras;
- VRayLensEffects render effect for producing realistic glow and glare;
- Filter Generator tool for generating glare maps for VRayLensEffects;
- VRayDistanceTex texture to measure the distance to arbitrary polygonal objects;
- VRayDRBucket render element to show which machine rendered a given bucket;
- Support for tiled mip-mapped OpenEXR files in VRayHDRI;
- img2tiledexr tool for mass conversion of textures to tiled OpenEXR files for use with VRayHDRI;
- Support for shade maps in the VRayStereoScopic helper;
- Support for dispersion for refractions in VRayMtl;
- Support for camera distortion based on .vrlens files;
- Lens Analyzer tool for generating distortion .vrlens files from photographs;
- Light lister for V-Ray lights;
- Added the various V-Ray components in the "Create" menu;
Modified features
Official release:
- Add caustic subdivs for standard lights to the V-Ray light lister;
- The "directional" parameter for rectangle VRayLights is now repmapped to a more usable range;
- Ability to choose texture interpolation in VRayHDRI;
- V-Ray RT: Progress bar update when V-Ray RT is used as production renderer;
- V-Ray RT: Added support for alpha channel;
- Ability to adjust render passes and bounces for VRayBPT;
- VRayMetaSL material is removed for the time being; it will be added in an udpate;
Beta 3:
- V-Ray RT can be used as production renderer (with support for V-Ray VFB);
- Ability to adjust the orientation of IES profiles in VRayIES;
- Added an indication for the orientation of the VRayLightMeter in the viewport;
Beta 2:
- Added ability to store the raw bloom and glare results from VRayLensEffects to separate render elements (with V-Ray VFB only);
- VRayLensEffects now works properly with any color mapping type (with V-Ray VFB only);
- V-Ray now uses auto number of light cache passes when it is specified as zero;
- Copying an image to the clipboard from the V-Rag VFB now preserves sRGB color correction;
- Added camera/reflection/refraction/shadow/GI visibility options for VRayEnvironmentFog;
Beta 1:
- Added option for directional distribution of rectangle VRayLights;
- Added the ability to copy the V-Ray VFB to cliboard using Ctrl+C;
- Ability to specify a mesh for proxy preview when creating the proxy;
- VFB output is now not saved when rendering in "iterative" mode;
- Improved raytracing precision;
- Ability to enter exact coordinate values for the color curves in the V-Ray VFB;
- All log files are saved in non-administrative folders;
- Ray distance parameter for the dome light;
- Added zlib compression to .vrimg files;
- Show information about the value of corrected colors in the V-Ray VFB;
- Ability to load .vrimg files in the V-Ray VFB;
- Ability to compare two images from the VFB history directly in the V-Ray VFB;
- Ability to save and load color correction curves for the VFB in Adobe PhotoShop format;
- Add a "retrace threshold" option to the light cache;
- The vrayMeshExport() MAXScript function can take a list of objects to export instead of using the selection;
- Ability to specify per-gizmo density falloff for VRayEnvironmentFog;
- Implemented correct blending of overlapping VRayEnvironmentFog gizmos;
- "Filter maps for GI" option is now enabled by default (saves memory with large textures);
- The static box for the "Split channels" file name truncates the front of the file name if too long;
- Ability to explicitly set and maintain the FOV of the physical camera;
- Option for the VRaySun to not cast shadows from atmospherics;
- Option to turn off speculars from VRaySun;
- Option in VRayLightMtl material to multiply the color by the transparency texture;
- Option to treat a mesh as static or dynamic geometry in the V-Ray Object Settings dialog;
- Option to disable tiling in VRayBmpFilter;
- Option to specify material effects ID for VRayMtl;
- Option to turn off camera motion blur;
- Option for z-depth render element to take the z boundaries from the camera clipping planes;
- Better viewport representation of the VRayIES lights in the hardware viewport;
- Implemented support for motion blur of regular particle systems, including Thinking Particles;
- Implemented the cutoff threshold for mesh lights;
- Added printing of messages in the V-Ray log when light cache and photon maps are saved successfully;
- "Compensate exposure" option to the VRayLightMtl material;
- Display for the field of view camera cones for the VRayStereoscopic helper;
- Option to override the viewing (focus) distance for the VRayStereoscopic helper;
- Option to select "interocular method" for stereo camera position in the VRayStereoScopic helper;
- V-Ray VFB history button is enabled by default;
- Implemented caching of thumbnails for .vrimg files in the VFB history;
- VRayDirt exclude list is now accessible from MAXScript;
- VRayLog.txt location by default is in the temporary folder of the current user (which is always writable);
- Added browse button in the .vrscene export MAXScript dialog window;
- Added .exr (OpenEXR) extension in raw output browse dialog;
- Option to the V-Ray scene converter script to turn reflections off or on for converted Standard materials;
- "Affect diffuse" and "Affect specular" options for the VRaySun;
- "Affect diffuse" and "Affect specular" options for VRayIES lights;
- Include/exclude list for the VRayExtraTex element;
- MAXScript access to the "Import as mesh" function of the VRayProxy objects;
- Modified the vrayMeshExport() MAXScript command to return the (list of) auto-created proxies;
- Option to flip y/z axes when converting .obj files with ply2vrmesh;
- Ability to select a VRayPhysicalCamera and its target when clicking on the line between the two;
- Implemented better coloring of the SamplingRate render element;
- Option not to expand # in .vrmesh file path to frame number for VRayProxy objects;
- Option in V-Ray toon to just show outlines and not interior edges;
- "Temperature" color mode for the white balance of the physical camera;
- "Render last" button in the V-Ray VFB;
- Options for VRayAmbientLight whether to affect direct illumination and GI;
- "gi distance" parameter to VRayAmbientLight;
- Option in VRayMtl to adjust the "Fog color" based on the current scene units;
- Buttons to lock the aspect ratio for V-Ray VFB resolution and to swap width/height button;
- Option to enable color mapping for the VRayObjectSelect render element;
- "Ray distance" parameter for the dome light;
- Option to dim reflections based on distance for VRayMtl;
- Somewhat faster rendering with many render elements;
- GI subdivs multiplier in the VRayObjectSettings dialog;
Bug fixes
Official release:
- V-Ray RT GPU: Fixed slow performance with the 260.99 nVidia drivers and multiple GPUs;
- vrimg2exr did not work correctly with the -channel option and large images;
- Faceting with subdivision displacement;
- Rectangle VRayLights flipped along one of the axes did not render the correct side;
- VRayLights reflects black when "Base glossiness" of the VRayCarPaintMtl is set to 1;
- VRayBPT did not work with multi/sub materials;
- .vrimg files were not opened correctly with File > View image file;
Beta 3:
- Fixed crash with VRayBPTracer when Default lights are disabled;
- VRayBPTracer did not work with VRayBlendMtl materials;
- VRayLightMeter displayed the day light factor incorrectly;
- VRayExposureControl affected the rendering even if it was not active;
- Fixed noisy rendering with VRayExposureControl and gamma correction in the Color mapping settings;
- VRayStereoscopic did not work with VRayMtlID render element;
- V-Ray RT CPU: Support for the dim reflections option in VRayMtl;
- V-Ray RT CPU: Support for dispersion in VRayMtl;
- V-Ray RT GPU: Fixed an issue with environment maps on multiple GPUs;
Beta 2:
- VRayDistanceTex was broken;
- The "Compensate exposure" options in VRayAmbientLight, VRayLightMtl and VRaySphereFade did not work with the VRayExposureControl;
- Fixed dark results with VRayExposureControl in certain cases;
- Dispersion did not work with bump mapping;
- Irradiance map filename and auto save filename edit boxes did not get updated when changing the filename through MAXScript;
- The "Browse" button for the "Split render channels" parameter did not remember the file name;
- VRayMetaSL texture did not filter shader bitmaps;
- Caustics "Map file name" and "Map auto save file name" static boxes now truncate the front of the file name if too long;
- Ambient occlusion was calculated even if GI was disabled;
- .vrlens files are now declared to the Asset Tracker and also for missing files check;
- VRayLights that only affect reflections were slow to render;
- "Use light shape" option was causing shadow issues with excluded objects;
- Panning the VFB with the middle mouse button and the comparison line enabled did not refresh the comparison properly;
- The shade map in the VRayStereoscopic helper did not work with render elements;
- The stereo hepler shade map did not work properly with the VRayExposureControl;
- V-Ray RT CPU: VRayLightMtl material was always double-sided;
- V-Ray RT: VRayExposureControl was not working in the ActiveShade window;
Beta 1:
- The "Save render servers with scene" option did not work;
- Issue with GI when overriding the environment in VRayMtl;
- Exposure control plugins from the Environment dialog do not affect the background even if that option is enabled;
- Artifacts on shadow/light boundaries with Ward BRDF;
- Noisy VRayEnviromentFog shadow with Target Direct light in certain situations;
- Particle systems could not be exported as .vrmesh files;
- Issue with excluded hidden render nodes with VRayToon and DR;
- Installer timeout was too short for auto uninstall;
- VRayLightMtl material lost opacity texture when copied;
- VRayIES lights could reset the power setting in certain situations;
- Crash with animated proxy in ping-pong mode;
- The VRaySSS2 render element included GI even if its "Scatter GI" option was disabled for the respective VRayFastSSS2 material;
- Potential crash with VRayFastSSS2 and VRayCarPaintMtl at start of rendering;
- V-Ray will now always generate floating point 3ds Max buffer when using VRayLensEffects in order to preserve HDR information;
- Implemented eariler warning for existing .vrimg files before the actual rendering has started;
- VRayIES lights did not use the global light multiplier;
- UNHANDLED EXCEPTION: Creating ObjLightDesc for node Light01;
- Render clients were not failing over to the third license server;
- Problem with VRayFur and VRayPlane in the viewports;
- Crash when clicking on the VFB raw file "Browse" button with no text in the edit box;
- Crash with motion blur when default geometry is set to "Dynamic" and there are meshes with changing topology;
- Bug with Tab key in the VRayProperties dialog;
- Problem when rendering through backburner of a scene with V-Ray VFB history on a machine that does not have VFB history enabled;
- Issue with dimming of controls for VRayLights;
- VRayBlendMtl did not work with scripted materials;
- No velocity information was exported to .vrmesh files when object transformatons were animated;
- 3ds Max UI freeze if rendering with VFB clear confirmation dialog is shown;
- Crash when exporting multiple meshes to .vrmesh files;
- Issue with the "Reset Material Editor Slots" function in 3ds Max 2011 with the new slate Material Editor;
- Problems when using object settings across machines with different Windows regional setttings;
- "Automatically create proxies" option in the VRayProxy export dialog did not work for groups;
- Ability to save .vrimg files through the "Save" button of the VFB (just the visible render element);
- Added .vrimg as option for 3dsmax render ouput;
- Crash with VRayPhysicalCamera in 3ds Max 2009;
- Issues with the "Condense material library" function with the MAX.vray preset;
- Assigning a value to the file name parameter of VRayBmpFIlter texture did not work;
- Issues with scaling of spherical VRayLights;
- Loading of bitmaps is now skipped if "Maps" option is OFF;
- Relative file paths for the irradiance map did not work;
- Could not drag and drop to/from VRayMtlSelect render element material slot;
- Several V-Ray specific materials showed up in the "Standard" category of the material browser in 3ds Max 2011;
- Crash with the VRaySamplerInfo render element;
- Weird colors with VRaySun when it is below the horizon;
- The hilight glossiness of VRayMtl had the same localized name as the reflection glossiness;
- Don't start setvrlservice if installer is started from command line without GUI;
- %camera keyword in the frame stamp did not work with physical camera;
- Errors with region rendering to tiled .exr files;
- Crash with Hair&Fur modifier in "mr prim" mode;
