©BBB3viz
Build 3.05.04
Beta 3 release
Date – December 11, 2013
New Features
General
  • VRaySkinMtl material
VRayProxy
  •  Initial support for particles in Alembic files
VFB
  • New color corrections - contrast, HSL, color balance
VRayOrnatrixMod / VRayHairFarmMod
  • Added options for dynamic view-dependent hair tesselation
VRayOptionRE
  • Added an option to save three-channel alpha in deep OpenEXR 2 files for compatibility with Houdini
VRayUserColor / VRayUserScaler
  • Reading data directly from a Node's User Properties
VRayRT
  • Support for RailClone instancing
Modified Features
General
  • Right-click on a UI switcher allows to switch all rollups to Basic/Advanced/Expert views
  • Updated to Embree 2.0
  • V-Ray will now print a performance warning in the messages window if the 3ds Max bitmap pager is enabled
  • Support for %d and %0nd tags in file names for irradiance maps, light caches, photon maps and caustics maps
VRayOCIOTex
  • Added an "auto" option to try and automatically convert textures to linear space
VRayVRmatMtl
  • Added a preview of the currently selected .vrmat/.vismat material in the Open File dialog when browsing for a file
  • Added .tx and .tex as valid texture file names
VRayMultiSubTex
  • Added an option to preserve the alpha of the sub-textures
VRayFur
  • Ability to specify face material ID for the hairs
VRayClipper
  • Added an option to exclude the light coming in result of cutted geometry
.vrscene Exporter
  • Make .vrscene exporter's Export and render button render the whole sequence
VRayOrnatrix / VRayHairFarmMod
  • Implement global hair tree support
VRayLight
  • More robust sampling of small rectangle lights
VRayHairMtl
  • Reduced noise on transparent hairs
VRayGLSLMtl / VRayGLSLTex
  • Added the ability to type a shader directly in the Material Editor
VRayGLSL
  • Added a __VRAY_HOST__ macro that expands to the version of vray.dll
Quick Settings
  • Added the possibility to save custom presets
VFB
  • Multithreaded file save with the "Split channels" option is disabled due to instabilities
VRayFakeFresnel
  • Now exposed in the UI
V-Ray RT
  • Improved refresh rate and responsiveness
Bug Fixes
General
  • 3.0 slower than 2.4 in some cases
  • Unnecessary repeated asset transfer after a texture is changed once
  • VRayLightMtl is black in MultiMatte render element when using material ID
  • Reflection/Refraction exclude lists in the V-Ray object properties didn't work with groups
  • Fixed rare crash with progressive sampler
  • Some bake elements have duplicate class names of other plugins
  • Render mask did not work with the VRayStereoscopic helper
  • Artifacts with motion blur and shutter efficiency less than 1.0
VFB
  • Color clamp button selection state not saved when button not pushed
  • The UI colors should match the 3ds Max color scheme
  • When opening a scene with bloom/glare masks turned on, lens effects were not applied after the first rendering
VRayDistanceTex
  • Setting tex_inside_separate_on:true for a VRayDistanceTex constructor from MaxScript causes system exception
VRayCarPaintMtl / VRayFlakeMtl
  • Wrong material name in info message in 3ds Max 2013 and later
VRayHairInfoTex
  • Did not work properly with Hair&Fur
Distributed Rendering
  • Render servers failed to join a DR render
VRayBPTracer
  • Image rendered with BDPT turns black when Glare effect is applied
Hair & Fur
  • The "Visible to camera " option for distribution object was not inherited by Hair&Fur
VRayVRMatMtl
  • Fixed issues with non latin characters in VRMat material
  • Correct default values for TexCloth
  • Loading some .vrmat files in scene caused 3ds Max to crash
  • The vrmat editor preview should have gamma 2.2 applied
VRayLight
  • Fixed issues with targets when creating new lights
VRayIES
  • Fixed a rare crash when loading scenes with VRayIES
VRayProxy
  • Fixed issues with Alembic with dynamic topology and visibility lists
VRayMtl
  • "Affect all channels" didn't work with glossy reflections for some render elements
VRayClipper
  • Strange result when used on Editable Poly with intersecting attached elements
VRaySun
  • Should return the true intensity in the viewport if VRayExposureControl is active in Nitrous
VRayFur
  • Fixed crash when accidentally rendering with the scanline renderer
Render Mask
  • Drag and drop of textures to the render mask button was not working
VRayMetaball
  • Negative particles rendered as positive
V-Ray RT
  • Swirl texture prevented V-Ray RT from starting
  • Rendering production while RT was running in VFB would lock RT properties until VFB is closed
  • Saving images from V-Ray RT as production renderer didn't work with the V-Ray VFB enabled
  • Fixed issues with Multi/Sub-object materials on dynamic geometry (instances)
Build 3.05.03
Beta 2 release
Date – October 14, 2013
New Features
General
  • Added a new camera type "Spherical panorama" for equirectangular panoramas (similar to "Spherical" but allows manual control of the vertical FOV)
  • The full version of V-Ray Standalone is now included in the installation
  • Option to exclude the local machine from DR rendering
  • Options to automatically transfer and cache render assets to the DR servers (3ds Max 2010 and later)
VRayFastSSS2
  • Raytraced mode for multiple scattering
VRayHDRI
  • Added an option for ground environment projection
VRayProxy
  • Support for Alembic 1.5
  • Ability to specify starting path in Alembic files
VRayDisplacementMod
  • Support for Ptex object-space vector displacement
Lens Analyzer
  • Ability to analyze distortion in arbitrary images
Render Mask
  • Added two new modes: include/exclude list and by layer name
VFB
  • Option to automatically save each render in the history (enabled from the VFB history options dialog)
Modified Features
General
  • "Reinhard" color mapping is now the default color mapping mode
  • Added per-object motion blur duration setting in the V-Ray object properties dialog
VRayHDRI
  • Faster shutting down of 3ds Max when "clear on render end" for tiled textures is disabled
VRayMtl/VRayFastSSS2
  •  Print information about which materials require prepass interpolation maps
VRayIES
  • The light dimensions are now shown in scene units in the UI
VRayPhysicalCamera
  • Newly created objects are named "VRayCam001" etc
V-Ray RT
  • Now uses the V-Ray VFB when enabled in the production renderer
  • Up to 5x faster initial scene transfer to render servers
  • Automatic asset transfer to the render servers
V-Ray RT GPU
  • Reduced noise on VRayBlendMtl materials
VRayProxy
  • The default preview mode is "preview from file (faces)" as it's faster in Nitrous
Embree
  • Now is always compiled with pure SSE2 so that it works on older hardware
Bug Fixes
General
  • The V-Ray caustics Auto save option is errorneously named casutics_autoSave in MaxScript
  • Fixed override issue with V-Ray object properties when selecting multiple objects
  • The V-Ray log file was not redirected properly when loading a scene with modified log file path
  • No shadows behind glass with "cast shadows" disabled
  • VRScene exporter didn't work for SSS2 materials
  • Deep OpenEXR 2 files continued to be written even after a render has been cancelled
  • Distributed rendering didn't work after rendering with V-Ray RT
  • Fixed crash with multi-threaded saving of render elements when using the "split render channels" option
Hair & Fur
  • Multiple Hair&Fur materials swap randomly between different modifier instances in the same stack
  • Crashes with VRayLightMtl material
VRayProxy
  • Preview was always as faces instead of edges in Nitrous
  • Alembic hair preview could not be selected in the viewport
  • Convert file paths to UNC option didn't work for VRayProxy
VRayPhysicalCamera
  • Greyed out "Autogrid" in latest builds
Quick Settings
  • Slow update when changing the shading quick settings if Render Globals are open
VRayOSLMtl / VRayOSLTex
  • Problems with OSL shaders with ',' as the system decimal symbol
VRayHDRI
  • Convert file paths to UNC option didn't work for VRayHDRI
  • The Browse button does not work if the texture file name contains <UVTILE> tag
  • The "Show Map in Viewport" button was not working
VRayFastSSS2
  • Phase Function = 1 produced NaN pixels
VRayBPTracer
  • Crash when rendering VRayMetaball objects
  • Materials with glossiness less than 1.0 rendered incorrectly
VRayStereoScopic
  • Stereoscopic rendering through shade maps was not working in beta 1.1
VRayMetaball
  • Fixed crashes when rendering with the V-Ray VFB
  • Incorrect renders with the irradiance map
  • Incorrect surface normals in some cases
  • Fixed incorrect motion blur in some cases
VRayRenderID
  • VRayRenderID render element: XML output was not correct in 3ds Max 2013 and later due to Unicode
V-Ray Object Properties
  • Fixed incorrect setting of properties when multiple objects are selected
VFB
  • The entire history was reloaded when saving an image into the history
Build 3.05.02
Beta 1.1 release
Modified Features
VRayVRMatMtl
  • The material can now read and render materials from .vrscene files
VRayHDRI
  • Can now load unlimited number of OpenEXR tiled texture files
VRayMtl
  •  The default value for the cutoff parameter is now 0.005
V-Ray RT
  • Added option to disable initial image under-sampling
Bug Fixes
General
  • V-Ray didn't load on Windows XP and Windows Vista
  • Fixed increased noise compared to V-Ray 2.x in specific situations
  • Fixed darker GI compared to V-Ray 2.x in specific situation
  • Fixed darker reflections compared to V-Ray 2.x in specific situations
  • Fixed freeze or crash with "Separate render channels" option
  • The "separate channels" file name box did not update correctly
  • Fixed horizontal line artifacts with the Progressive sampler
  • Fixed issues with texture baking
  • Fixed issues with render subset and objects with visibility less than 1.0
  • Fixed occasional corrupted deep image files
  • Fixed crash after loading scenes with VRayEnvironmentFog
  • Fixed render hang with materials using the Raytrace map
  • Fixed noise threshold issue with the Progressive sampler
  • Fixed a crash with probabilistic lights in certain situations involving VRayLightMtl materials;
Embree
  • Fixed artifacts with transparent surfaces
VRayHairInfoTex
  • Support for hair colors from Alembic files
VRayOpenColorIO Texture
  • Various fixes
VRayBPTracer
  • Buckets started where they were last cancelled
  • Fixed black pixels in certain situations
VRayHDRI
  • Fixed a viewport display issue with Alembic hair in 3ds Max 2011
  • Added multiplier for hair width from Alembic files
  • Fixed issues with Alembic files containing meshes with changing topology
V-Ray RT
  • scene exporter: fixed a problem when exporting VRayFastSSS2 material
  • Fixed issues with the noise threshold not working correctly
Build 3.05.01
Beta 1 release
Date – August 20, 2013
New Features
General
  • New progressive image sampler
  • Simplified main renderer user interface: basic/advanced/expert views for some rollouts; help shortcut buttons
  • Extensive optimizations for render speed, especially when using brute force GI
  • The Intel Embree library is now integrated into the V-Ray core for static and motion-blurred geometry
  • Probabilistic light sampling for scenes with many lights
  • Support for render texture mask and render subset from selected objects
  • Added reflection/refraction trace sets in the V-Ray object settings dialog
  • New streamlined installer
  • New "Max ray intensity" parameter to help deal with fireflies in glossy reflections
  • New VRayLUT, VRayICC and VRayOpenColorIO textures
VRayPhysicalCamera
  • Support for bitmap aperture and optical vignetting
VFB
  • Ability to write deep images (OpenEXR 2/vrst/vrsm)
  • Support for OpenColorIO color correction
  • Lens effects can be applied directly in the VFB
VRayHDRI
  • Support for <UDIM> and <UVTILE> tags
  • Support for tags in the bitmap file name based on the node user properties
VRayOrnatrixMod
  • Optimized rendering and reduced memory usage
VRayProxy
  • Ability to render hair from Alembic .abc files
  •  New material and texture with support for the Open Shading Language
VRayVRmatMtl
  • VRayVRmatMtl material for rendering .vrmat/.vismat files
VRayFastSSS2
  • Option for geometry-based sampling for the illumination map
VRayMetaBalls
  • New geometric object
VRayClipper
VRay Quick Presets
  • V-Ray toolbar with a button that shows the Quick Presets window
VRay RT GPU
  • Support for most render elements
VRayBPTracer
  • Initial support for vertex merging
Modified Features
General
  • Updated the OpenEXR library to OpenEXR 2
  • Optimized the loading of irradiance map files over the network
  • The irradiance map prepass now uses the same render region sequence as the main renderer
  • Removed the light cache "Number of passes" parameter; this is now handled internally
  • "Right Click - vrscene exporter" now uses the V-Ray RT translator instead of MaxScript
  • Dynamic bucket splitting towards the end of the image
  • Correct "raw" elements for easier compositing (needs the regular and the filter elements to be present too)
  • Added "shutter efficiency" option for motion blur
  • Multi-threaded saving of images when using "Split render channels" option
  • V-Ray lights now support external atmospherics renderers (AfterBurn/FumeFX)
VRayPtex
  • Updated the Ptex library to the latest version
  • Rewritten the Ptex library texture cache for better multithreading on many-core machines
VFB
  • Ability to switch between the most recent images in the history using the 1-9 keys
  • Ability to switch between render elements in the VFB using PageUp and PageDown
  • The history thumbnails in the VFB now have sRGB color correction if the sRGB setting is enabled
  • Support for the "track mouse" option in the VFB for stereo renders
  • "Compare" button to toggle comparison view on/off
  • Add right-click menu on the border for custom border color selection
VRayExposureControl
  • Affect the Nitrous viewports in 3ds Max 2013 and later
VRayMtl
  • The "fix dark edges" option is now "on" by default for newly created materials
VRayPhysicalCamera
  • The "Show cone" option now respects the pixel aspect ratio
  • Added an "auto guess vert. shift" option to keep the vertical shift when moving the camera
VRayDisplacementMod
  • Added support for hidden faces for displaced and subdivision surfaces
  • Added "static geometry" and UV smoothing options, as well as option to use fast displaced normals
VRayHDRI
  • Added "View map" and "Reveal in explorer" buttons
  • Ability to automatically generate .ifl files when picking a frame from an image sequence
VRayEdgesTex
  • Added "Show subtriangles" option to show tesselation of displaced and subdivision surfaces
VRayHairInfoTex
  • The "Random by strand index" option is now supported for VRayFur
VRayHairMtl
  • The "Simpify for GI" option is now enabled by default
  • Faster rendering of transparent VRayHairMtl material
VRayOptionRE
  • Added an option to group g-buffer fragments by Z-depth rather than render ID
VRayColor2Bump
  • Added a "bump delta scale" parameter
VRayColor
  • Added a "color gamma" option that allows correction of the actual color used for rendering
VRayLight
  • Added an "affect alpha" option for the dome lights
  • Added an option to lock the dome light texture to the orientation of the light icon in the viewports
  • Added the ability to change the wire color
VRayIES
  • Support for motion blurred lights
VRayColor
  • Added a "Temperature" color mode
ply2vrmesh
  • Added support for material IDs in .obj files
vrimg2exr
  • Added an option to truncate channel names to 32 symbols
Bug Fixes
General
  • Fixed truncated error messages in the V-Ray log for missing textures in 3ds Max 2013 and later
  • Some message boxes in 3ds Max 2013 did not display proper Unicode strings
  • Set sensible limits to some parameters in 3ds Max
  • Increase the max stdio file handles to the maximum possible (2048) on 3ds Max startup
  • V-Ray loses its license when RPManager is running
  • Low CPU utilization when the irradiance map prepass is calculating background
  • The parameters of some render elements did not have proper names in Track View
  • Crash/hang when checking/unchecking "V-Ray VFB" option in VRayMtlReflectGlossiness Render Element
  • Hang on "Unloading geometry" when cancelling a render during "Presampling displacement"
VRayMtl
  • Fixed incorrect (brighter) GI with glass objects with "affect shadows" enabled when they are in front of an area light
  • Fixed rare bug with refractions due to precision loss
VRaySphereFade
  • Could not edit the gizmo objects list through MaxScript
VRayToon
  • Could not edit the exclude list through MaxScript
  • Fixed various issues with the include/exclude UI
VRayLightMtl
  • Fixed random lighting between renderings with DirectIllumination and CompensateExposure on
VRayLight
  • Ability to set higher values for dome light texture resolution
  • The light preview in the Nitrous viewport disappeared when the light size if very large
  • Brighter glossy reflections of light portals
  • Incorrect (brighter) GI with glass objects with "affect shadows" enabled when they are in front of an area light
  • Inconsistency between GI on/off when an invisible sphere light intersects geometry
  • Dome light looked pixelated in glossy reflections and refractions (light needs to be recreated for the fix)
VRayEnvironmentFog
  • Fixed crash after deleting environment fog gizmo and rendering
VRayPtex
  • Fixed issue on duplicated objects with modifiers
VFB
  • The V-Ray LUT .cube textures does not load if the system decimal symbol is not "."
  • Comments section of the VFB history changed the information when it was in Korean
VRayHDRI
  • "RGB Offset" and "RGB Level" in the Output rollout had no effect until the Material Editor is opened
VRayDisplacementMod
  • If model using the VrayDisplacementMod was X-Ref'd, the displacement is not considered
VRayMultiSubTex
  • Issue with drag and drop on the texture button
VRayBlendMtl
  • Fixed incorrect diffuse render element with blend material in additive mode inside a 2-sided material
  • The "Use irradiance map" option from the base material is now used
VRayStereoscopic
  • The helper should append .vrst extension to file names if no extension is specified
Build 3.00.08
Official release
Date – September 16, 2014
Download – Build 3.00.08
Modified Features
V-Ray Scene Converter
  • Added option to convert the standard cameras to VRayPhysicalCamera
V-Ray Quick Settings
  • Added preset delete button
VRayDistanceTex
  • Replaced the texmap preview in the material editor slot with a generic but faster rendering one
VRayFastSSS2
  • Added color mode control
VRayHairMtl
  • Added light_multiplier parameter
VRayMeshGeom
  • Updated V-Ray SDK example project
VRayOSLMtl/VRayOSLTex
  • Added support for tweak parameters tooltips display in material editor
  • Made .osl the default file extension
VRayProxy
  • Added support for UV channels with negative indices
Bug Fixes
V-Ray
  • Added "facesPerVoxel" and "oneVoxelPerMesh" parameters to the .vrmesh exporter
  • Fixed a crash when reading mip-map levels for non-square textures
  • Fixed a crash when rendering geometry with incorrect faces
  • Fixed a crash when rendering objects with Linked XForm and motion blur
  • Fixed a crash when rendering with empty layer as render selection mask
  • Fixed a crash when switching RT and Production after changing VRayColor parameters while RT was running
  • Fixed a crash with XMesh having very large surface normals
  • Fixed a random crash in scenes saved with region rendering enabled
  • Fixed artifacts when rendering with mapped IOR
  • Fixed crash with VRayPtex due to incorrect mesh data
  • Fixed memory allocation for non-tiled bitmaps
  • Fixed rare crash with progressive image sampling initialization
  • Fixed rare crash with progressive image sampling and noise threshold greater than 0.0
  • Fixed Embree rendering on machines with lower versions of SSE support
  • Fixed export of multiple splines to .vrmesh through MaxScript
  • Optimized geometry traversing on multi-core machines
  • Fixed "No GI on other mattes" option
  • Fixed "Max ray intensity" not working for the first glossy reflection
  • Fixed rendering of "Matte for reflect/refraction" objects
.vrscene exporter
  • Added point cloud export parameters
  • Fixed animation settings persistence between export sessions
  • Frame range is not written into .vrscene files when exporting animations
  • The "Strip paths" option didn't affect VRayProxy objects
  • Some options didn't work as expected
  • Fixed the On parameter support for 3ds Max lights
V-Ray RT
  • Animated "focus distance" parameter was not exported
  • Fixed a crash when ActiveShade is rendering simultaneously with material editor's swatches
  • Fixed color mapping improperly applied twice when sub-pixel was enabled
  • Make V-Ray RT Animation Preview" command to save images when rendering with VFB
  • Fixed rendering sequence through animated camera, subsequent frames were wrong
V-Ray RT GPU
  • Fixed a crash with animated meshes, during ActiveShade session
  • Fixed a crash with animated proxies, during ActiveShade session
  • Fixed an issue causing lights disappearance when moving dynamic geometry during ActiveShade rendering
  • Fixed slow "Compiling geometry" with Forest Pro
  • "Trace depth" parameter was ignored
V-Ray RT CPU
  • VRayFastSSS2 with raytraced single scattering and Direct light renders differently from production renderer
  • VFB history autosave was always enabled
  • Fixed non-Quick Settings custom presets handling
VFB
  • Ability to set the bloom "shape" parameter for the lens effects to larger values that 40
  • Add a #hide keyword to the vfbControl() command to close the VFB after a command is executed
VRayClipper
  • Fixed include/exclude with grouped objects and hairs
VRaySSS2
  • Fixed incorrect results with raytraced multiple scattering and raytraced single scattering
HairFarmMod
  • Fixed a crash when rendering multiple hair instances
VRayLight
  • Fixed artifacts occurring with irradiance map and "affect reflections" in certain situations
VRayLightMeter
  • Fixed viewport representation in 3ds Max 2015
VRayOrnatrixMod/VRayHairFarmMod
  • Fixed velocity render element
  • Fixed not-working "Open in External Editor" command for 3ds Max 2012 and previous
VRayPhysicalCamera
  •  Fixed undo of "Guess vert/horiz tilt" buttons
VRayProxy
  • Fixed artifacts when rendering with motion blur
  • Prevent unneeded reading proxy particle widths for preview
VRayStereoScopic
  • Render elements were outputting left channel only image files through 3ds Max rendered image window
VRayBPTracer
  • Fixed a crash in a specific scene
miscellaneous fixes
  • Fixed artifacts in certain situations with irradiance map and area lights with "Affect reflections" turned off
Build 3.00.07
Official release
Date – May 22, 2014
Download – Build 3.00.07
Bug Fixes
V-Ray
  • "Direct visualization" of the caustics photon map does not work properly with VRayEnvironmentFog
  • Freeze at render start with memory frame buffer and very large resolutions
VRayProxy
  • Fixed crash with Nitrous in 3ds Max 2015 with a scene created with an older version of V-Ray
VRayStereoscopic
  • Fixed crash when outputting Deep EXR with "Previous render" set to anything but "Unchanged"
Build 3.00.06
Official release
Date – May 5, 2014
Download – Build 3.00.06
New Features
V-Ray
  • Support for 3ds Max 2015
  • Added VRayPointParticleMtl material for shading point particles from .vrmesh/Alembic files
Modified Features
V-Ray
  • Added option to the .vrmesh exporter to automatically create a Multi/Sub-Object material when exporting multiple objects in a single file
V-Ray RT
  • Added lights include/exclude lists support
  • Added statistics when using the VFB
  • Implemented showing Safe Frame when rendering in a viewport
VRayProxy
  • Added option to render particles as points
  • Added option to enable/disable Alembic full names support in the visibility lists
  • Added support for hair and particles color channels from Alembic
  • Make the "Animation offset" parameter animatable
VRayBump2Normal
  • VRayBump2Normal is now included in the V-Ray installation
VFB
  • Added support for the "track mouse" option while rendering for progressive sampling and V-Ray RT
  • The Lens Effects 3ds Max Effect plugin settings are now applied only when the 3ds Max rendered image window is used, as it clashes with the VFB Lens Effects settings
  • Lens effects - the default glare type changed to "From render camera"
  • When the "mono" button of the VFB is pressed, the computed intensity is now based on the selected R/G/B components only
VRayVRmatMtl
  • Material exporter support for VRayBlendMtl
  • Material exporter support for Checker and Falloff textures
Bug Fixes
V-Ray
  • Prevent raw image output, when enabled but empty path is provided
  • Reflection/Refraction trace sets' Clear button was cleaning both of the lists
  • Reflection/Refraction trace sets were not working in inclusive mode
V-Ray RT
  • Fixed a crash when undoing delete of Forest Pro geometry while Active Shade rendering
  • Fixed support of Material Frequency Particle Flow operator when rendering as production renderer
  • Progressive sampler settings were not exported in .vrscene files
  • VRayParticleTex was not translated
  • Region rendering with the V-Ray VFB did not work when using V-Ray RT as production renderer
  • The translucency parameters of VRayMtl are not exported
V-Ray RT GPU
  • Lens effects source channel was incorrect when re-rendering as production renderer
Hair&Fur/VRayOrnatrixMod/VRayHairFarmMod
  • Fixed assigned materials order when rendering with multiple hair nodes and having some of them hidden
Embree
  • Fixed a crash with XMesh and motion blur
  • Rendering in DR mode with "Use local host" unchecked demanded a render node license
  • The "Save hosts in scene" option was not always working correctly when rendering with DR through Backburner
VRayBPTracer
  • Bucket outlines left in VFB after rendering end
VRayDisplacementMod
  • Fixed a very slow rendering when Noise texture with animated parameter was used
  • Fixed smoothstep output values outside the interpolation range
  • Newly opened shaders were not added to the recent files history after clearing history
  • Ensure all user defined global variables are initialized to zero
  • Shader source files were not shown in the Asset Tracker
VRayOSLMTL / VRayOSLTex
  • Fixed crash when assigned to dome VRayLight
VRayProxy
  • Fixed crash with corrupt .vrmesh files with large number of voxels
  • Fixed wrong rendering of multiple instances with particles/hairs
  • Optimized loading of scene with many Alembic proxies
  • Optimized preview voxel loading routine
  • Skip proxy preview calculations if zero number of faces/hairs/particles is provided
VRayPtex
  • Changing PTex cache size had no effect on rendering, 100 MB was always used
  • Added an option for turning off anisotropic filtering for PTex textures
VRayStereoscopic
  • Rendering shade map sequences could cause crashes
VRayLightIES
  • Fixed crash after VRayIES light was created in 3D snap mode and 3ds Max was Reset
V-RayLight
  • Fixed "Lock to dome orientation" option to work for nested textures
VFB
  • V-Ray did not write .vrimg/.exr files if "Generate preview" was enabled, and "Memory frame buffer" was turned off
  • The progressive sampler was not creating a raw .vrimg/.exr file
  • The Lens Effects were not applied to images loaded from the history
  • The Lens Effects were not stored in the output file
VRayExtraTex
  • Cloning VRayExtraTex element didn't clone the include/exclude list
vrimg2exr
  • Fixed batch conversion output names generation
miscellaneous fixes
  • Global subdivs multiplier should be able to go down to zero
  • Fixed a MaxScript system exception error when cancelling the creation of a VRayLight from the V-Ray toolbar
  • Fixed issues with VRayLights and FumeFX with illumination map
Build 3.00.05
Official release
Date – April 7, 2014
Download – Build 3.00.05
Bug Fixes
V-Ray RT GPU
  • OpenCL engine was not working
VRayPhysicalCamera
  • Fixed camera creation unhides hidden lights
miscellaneous fixes
  • Fixed more cases of stuck buckets with GI
  • Wrong render results when using camera DOF and motion blur at the same time
Build 3.00.04
Official release
Date – March 3, 2014
Download – Build 3.00.04
Modified Features
VFB
  • The lens effects sliders position can be set by mouse click
VRayLight
  • Added Affect alpha option for the dome lights
Bug Fixes
VRay RT CPU
  • Phoenix FD did not update in mesher mode when changing frames
  • Stereo mode did not work correctly
VRay RT GPU
  • Crash when trying to render an object with GLSL material
  • Fixed bump mapping with Fresnel reflections
  • Fixed bump mapping with tiled texture
  • Fixed different dynamic tessellation with and without motion blur
VRayPhysicalCamera
  • LENS files were not auto-transferred for DR
VFB
  • Apply inverse gamma correction when loading an image with 8-bit colors
  • Color balance and HSL corrections were applied after display corrections like sRGB instead of before
  • Fixed crash with curve color correction when there were NaN pixels in the image
  • Color balance correction could produce strange results with HDR colors
  • Fixed crash with deep output in certain situations
  • Fixed global presets loading the sRGB/ICC button state
  • Fixed a crash when loading image after 3ds Max reset
  • Lens effects were applied twice when changing the Mode and Type settings
  • Lens effects were not applied on images loaded from the VFB history
VRayHairMtl
  • Fixed cut-off look of the material in the Material Editor
VRayClipper
  • Fixed unexpected behavior when linked to other objects
VRayMap
  • Artifacts with environment override in the texture
miscellaneous fixes
  • Fixed stuck buckets due to long GI paths in certain cases
  • Fixed stuck buckets with dynamic geometry with mixed static and motion-blurred geometry
  • Fixed texmap slots of some of the V-Ray texmaps did not refresh immediately when a new map is connected to them
  • Fixed NaN pixels in certain cases with Noise texture used as displacement map on a large plane
  • Fixed NaN pixels in certain scenes with 3ds Max Fog atmospheric effect
  • Fixed NaN pixels when a bump texture returned a NaN normal
  • Updated DLL version numbers
  • Improved motion blur raycast accelerator for fast rotating objects
  • Fixed rare crashes when preparing scenes with many mesh lights
Build 3.00.03
Official release
Date – February 17, 2014
Download – Build 3.00.03
Bug Fixes
Render Masks
  • Improved performance with threads number scaling
VRayHDRI
  • did not work with the Default Scanline renderer with mapping channels different from 1
V-Ray RT
  • Fixed issue where rendering particle systems was breaking the rendering of motion blur
  • VRayHDRI was not working as bump map
V-Ray RT GPU
  • Fixed crash in V-Ray standalone when moving dynamic geometry with motion blur enabled
  • Fixed driver crash with dynamic motion blurred geometry
  • Fixed artifacts with area lights
VRayUserColor/VRayUserScaler
  • User properties for standalone plugin were not read correctly
VRayVRmatMtl
  • Fixed crash in the VRMat editor in certain builds when previewing materials in the editor
VRayLightMtl
  • A helper meshlight was not created in the same layer as the object's when "Direct illumination" was on
VRayObjectSelect
  • Fixed displaying of include/exclude lists editor on vrayVFB check/uncheck
miscellaneous fixes
  • Fixed slower rendering of scenes with dynamic meshes on many-core machines compared to V-Ray 2.4
  • Fixed updating of texmap buttons on some V-Ray texmaps when connecting them in slate material editor
  • Fixed crash when rendering with 3ds Max frame buffer, V-Ray Stereoscopic's "Adjust resolution" enabled and DR
  • Fixed crash with the "Previous render" option in the render settings when render elements were enabled
  • Fixed issue where the "Check for missing maps" option was breaking the animation export for particle systems
  • Fixed NaN pixels in certain cases when a 3ds Max Bitmap is used as a spherical environment
  • Fixed long irradiance map calculation times in specific cases with matte objects and "Retrace" light cache option enabled
Build 3.00.02
Official release
Date – February 7, 2014
Download – Build 3.00.02
Modified Features
vrimg2exr
  • Increase the default buffer size to 100 MB to speed up conversions
Bug Fixes
V-Ray
  • Fixed handling of tiled textures with mip-map levels that fit into one tile as produced by txmake
  • Fixed rare crash when cancelling a render with tiled textures
  • The render region height parameter was not always updated correctly when locked to the width
Render Mask
  • Fixed rendering with DR
VFB
  • Quad menu command was not showing the VFB in ActiveShade mode
VRayHDRI
  • Fixed slower reading of OpenEXR files compared to previous V-Ray versions
  • Fixed a crash with PSD textures with all layers hidden
VRayMtlWrapper
  • Fixed crash when a Multi/Sub-Object material is used as a base material
VRayBPTracer
  • Fixed rendering of camera motion blur
VRayGLSLMt / VRayGLSLTex
  • Fixed crash with "discard" statement when using uniform global variables
  • Reverted to OSL 1.3 as some input parameters were not updated properly
VRayLightSelect
  • Fixed erroneously disabled Remove button when more than one VRayLightSelect render elements were present
VRayFakeFresnel
  • Moved to the V-Ray category for textures
VRayProxy
  • Fixed proxy selection in viewport, objects behind were selected instead
VRay RT
  • Fixed rendering of animated materials attached to Multi/Sub-Object material
VRay RT GPU
  • Fixed incorrect mapping of baked procedural textures
  • VRayDirt in VRayExtraTex render element did not render properly
imapViewer
  • Reduced the number of messages that are printed to the standard output when merging large irradiance map files
Installer
  • Fixed previous installation license settings acquisition, local license was assumed always
Build 3.00.01
Official release
Date – January20, 2014
Download – Build 3.00.01
New Features
General
  • Redirected all help links to the new official help web site
  • A V-Ray toolbar provides quick access to common V-Ray features
VRay RT GPU
  • Support for VRayDirt, VRayFastSSS2, VRaySkinMtl materials
VRayEnvironmentFog
  •  Added an option for deep output to OpenEXR 2 and .vrst files
ply2vrmesh
  • Added ability to convert particles from Alembic files to .vrmesh files
Modified Features
General
  • For 3ds Max 2014, all related V-Ray files have been renamed to xxxx2014 (e.g. vrender2014.dlr, vray2014.dll etc)
  • Added a "Divide shading subdivs" parameter in the image sampler to prevent V-Ray from balancing shading subdivs vs AA subdivs for those users that find it confusing
  • Exposed in the UI the option for direct visualization of caustics calculations
  • Added an option to control DOF/moblur subdivisions for the Adaptive subdivision image sampler
  • When the maximum transparency level is reached, return the environment color rather than black
Hair & Fur
  • Hair&Fur properties are taken from the source object (except the "Renderable" property)
VRaySkinMtl
  • The material now respects the global "Linear workflow" option
VRayMetaballTex / VRayParticleTex
  • VRayMetaballTex renamed to VRayParticleTex and can be used to read colors from Alembic particles
VRayLight
  • Removed the "Ignore light normals" from the UI
  • Dome lights are now always created with intensity 1.0 instead of the default 30
V-Ray RT CPU
  • Internally uses the production renderer core running in progressive mode
V-Ray RT GPU
  • Use different GPU code depending on the features used in the scene
  • Faster loading of textures
VRayPhysicalCamera
  • Bitmap aperture now has "affect exposure" option
  • Renamed the "offset" and "shift" parameter to the more correct photographic terms "shift" and "tilt" respectively
  • Added an option to prevent custom bitmap aperture from affecting exposure
VRayProxy
  • Added an option to force remap mapping channels so that they always start from 1
VRayHDRI
  • Added a "View image" button that opens a 3ds Max bitmap buffer with the texture
  • Added support for single-channel TIFF and .tx/.tex files
VFB
  • The numpad 1-9 keys can also be used to switch between recent images
  • Ability to load arbitrary file formats
  • Clicking on a slider for HSL, color balance or brightness/contrast now sets the value
  • A color correction rollout can now be hidden or expanded by clicking on its title
Bug Fixes
General
  • Different buckets with probabilistic lights and DR
  • The "Max ray intensity" parameter could introduce color shifts
  • Fixed rare crashes with tiled textures and dynamic geometry when the dynamic memory limit was reached
  • Some V-Ray materials did not generate proper material IDs; Fixed crash with FumeFX render elements
  • Added support for alpha channel from FumeFX render elements
V-Ray RT
  • Fixed mixed up materials with RailClone objects
  • Fixed issues with animated proxy objects
  • Support for VRayBumpMtl
  • Fixed crashes and corrupted 3ds Max window after closing ActiveShade in 3ds Max 2014 with Enhanced Menus enabled
  • Right-click menu in ActiveShade could be flooded with "Missing" entries
  • The scene translation time was counted as render time
  • Wrong Z-depth render element with the "invert z-depth" option enabled
V-Ray RT CPU
  • Fixed a crash with animated displacement
  • Fixed incorrect results with <UDIM> tags
V-Ray RT GPU
  • Fixed crashes when starting rendering
  • ForestPro did not work correctly
  • Reflection environment and background were added randomly to a light select element
  • Invisible lights affected the Z-Depth render element
  • Fixed artifacts with Multi/Sub material and VRayNormalMap on ForestPro objects
  • The "compensate camera exposure" option for the VRayLightMtl material didn't work
VRayLight
  • Fixed an issue with spherical lights when "Use texture" was enabled
  • The options for previewing the directional parameter were not grayed out for non-rectangle lights
  • Fixed a glitch when creating dome lights
  • Incorrect rendering of non-uniformly scaled lights with directionality greater than 0.0
  • When looking through a sphere light, black parts of the geometry could appear
  • Fixed issues with dome lights with the "Lock to dome orientation" option enabled
  • Textured dome lights could appear pixelated to the camera and in reflections
VRayProxy
  • Alembic particles didn't work correctly with irradiance map and motion blur
  • Alembic particles rendered black with light cache enabled
  • Velocity render element didn't work with Alembic hair and particles
  • Saving of servers inside the scene file did not work
  • Fixed multiple transfers of assets with Unicode characters
  • Missing assets could incorrectly prevent other assets from being transferred to the render servers
VRayHDRI
  • Modified bitmaps were not transferred properly to DR servers when "Transfer missing assets" was enabled
  • Lists all supported image formats by default
VRayMetaBall
  • Fixed a crash when a velocity render element was present in the scene;
Render Mask
  • Irradiance map was calculated even for parts of the image not covered by the mask
Hair&Fur
  • Mapped scale of Hair&Fur could take the entire RAM
VRayHairFarmMod
  • Fixed flickering with motion blur when the hairs change the number of knots between frames
Embree
  • V-Ray failed to load when 3ds Max was started with an affinity mask set from the command prompt
VRayIES
  • Lights with different power from the default could produce different buckets in DR
  • Fixed slow rendering compared to V-Ray 2.x
VRaySkinMtl
  • The primary reflection glossiness map didn't work, just the numeric value
VFB
  • Fixed a crash when trying to apply lens effects to an image loaded from the VFB history
  • The HSL and color balance corrections were not saved in the 3ds Max scene
  • Some of the new color corrections were not taken in account when displaying corrected pixel info
  • The curves were not updated properly if the numerical input fields were used
  • HSL color correction didn't work unless there is at least one other correction enabled
VRayOCIO
  • The .ocio file was not read correctly if the system decimal symbol was comma
VRayLightMeter
  • Fixed incorrect results due to probabilistic light sampling
