©BBB3viz
Build 3.10.03
Official release
Date – January 12, 2015
Download – Build 3.10.01
Modified Features
V-Ray RT GPU
  • Added support for VertexColor texture
  • Basic support for rendering VRayDirt texmap
VRayMetaball
  • Added support for MaxScript vector color source
VRayProxy
  • Force first map channel option disabled by default
.vrmesh viewer
  • Added a slider controlling the point size of particles
  • Enabled OpenGL point smoothing only when the point size is greater than 1.0
Bug Fixes
V-Ray
  • Fixed 3ds Max 2015 with Extension 2 crash on remote DR hosts
  • Fixed hairs smooth normals rendering with V-Ray Standalone
  • Fixed MaxScript VFB functions not working when V-Ray RT set as production renderer
V-Ray RT
  • Added export of GI ambient occlusion parameters
  • Fixed export of "sample lookup" Irradiance Map parameter
  • Fixed not exporting the default geometry type for objects with type set to Default in the V-Ray object properties
  • Fixed crash when disc light has VRayColor for texture
  • Fixed issue with multiple disc lights with different colors rendering only the color of the first light
V-Ray RT GPU
  • Fixed crash when UVW coordinates are invalid
  • Fixed crash with refractive overlapping faces
  • Fixed Light Cache loading on DR hosts
VFB
  • Apply color corrections even when rendering to file
  • Fixed crash caused by NaN output values with Curve color correction
  • Fixed wrong time stamp when loading images from history
VRayClipper
  • Fixed artifacts near the edges of intersection surfaces
VRayHDRI
  • Fixed "Match Bitmap Size as Closely as Possible" 3ds Max option to work for VRayHDRI with Legacy Direct3D driver
  • Fixed viewport preview not working for map channels differing from 1
VRayProxy
  • Fixed crash with displacement when no vertex normals are present
ply2vrmesh
  • Fixed conversion from Alembic particles, that was causing crash during rendering
Build 3.10.02
Official release
Date – December 15, 2014
Download – Build 3.10.02
Bug Fixes
V-Ray
  • Fixed random crashes due to Windows messages processing, happening mostly with 3ds Max 2012, but not only
  • Fixed wrong rendering of dynamic geometry with opacity using Embree
  • Work around Royal Renderer's renderer window handling
VRay RT
  • Fixed crash with scenes with many plugin instanced objects
  • Fixed crash when rendering as production renderer with Max.vray UI preset is selected
  • Fixed random crash in CUDA engine
  • Fixed random hang during "Starting RT render server..." phase
  • Redirected log messages to appear in the Message Log window for production renderer
VRay RT CPU
  • Fixed rendering hanging at Light Cache pass when using SSS2 on CUDA CPU
VRay RT GPU
  • Fixed darkening in corners when using the light cache with "retrace" option
  • Fixed not reflecting highlight glossiness
VRayInstancer
  • Fixed crash when the source object(s) do not have any materials applied
VRayMtl / VRayLight
  • Fixed crash on 3ds Max 2012 and older when showing the DMC samples
VRayPhysicalCamera
  • Bitmap aperture was producing black renders
VRayScannedMtl
  • Fixed license checkout fail in DR mode
  • Fixed memory leak when no input file was provided
setvrlservice
  • Fixed help text for "-password" option
Build 3.10.01
Official release
Date – November, 2014
New Features
V-Ray
  • Further optimizations for render speed
  • Added "GI filter multiplier" option to the Global switches rollout to control texture filtering for GI rays for VRayHDRI
  • Embree can now accelerate hair rendering for Ornatrix and HairFarm
  • Secondary matte environment background slot to control the appearance of matte objects in reflections/refractions
  • When created, V-Ray will automatically load a preset named "default" if there is one (allows for customized default values)
V-Ray RT
  • Added support for the Mask texture map
  • Support for Carbon Scatter
  • Support for the V-Ray VFB for ActiveShade session
V-Ray RT CPU
  • Support for the VRayClipper object
  • Support for Ornatrix and HairFarm rendering
V-Ray RT GPU
  • Support for using the light cache for GPU rendering
  • Support for coherent tracing (may improve rendering performance)
V-Ray RT GPU CUDA
  • Support for the NVIDIA Maxwell GPU architecture
  • Support for the VRayFastSSS2 material
  • Initial support for hair rendering for Ornatrix and HairFarm
  • On-the-fly recompilation of the GPU kernel to include only features used by the particular scene
VFB
  • Ability to dock/undock History window and Color Corrections window to the main VFB window
  • Added highlight burn color correction to the VFB
  • Added "background image" color correction to the VFB
  • Added white balance color correction
  • Added the ability to save multi-channel .vrimg and OpenEXR files from the VFB UI
  • Added the ability to load arbitrary file formats in the V-Ray VFB for post-processing
VRayInstancer
  • Implement a new geometric plugin for instancing objects on a ParticleFlow and other particle systems
VRayHDRI
  • Added image preview in the file open dialog
  • Added controls to specify UDIM/UVTILE tiles for the preview in material editor
  • Added support for elliptical texture filtering
VRayScatterVolumeMtl
  • Greatly improved calculations
  • Ability to use the light cache
VRayScannedMtl
  • Support rendering of scanned real-world BRDF materials
VRayProxy
  • Support for hair and particle instances
  • Support for subdivision objects in Alembic files using OpenSubdiv
VRayLight
  • Disc light shape added
VRayLight, VRayIES, VRaySun
  • Added parameters to control the diffuse and specular contributions separately
VRayLightSelect Render Element
  • Added "mode" parameter to allow extracting the full/raw/diffuse/specular contribution of specific lights
VRayMtl
  • Added GGX BRDF model
  • Added clip opacity mode option for faster rendering of trees, etc.
VRayMultiSubTex
  • Extended with new randomized modes for choosing colors
VRayVelocity Render Element
  • Added include/exclude list
ply2vrmesh
  • Added export options to export specified frames to separate files
  • Added Alembic frame offset output to the files
  • Added option to merge two or more .vrmesh files into one
vrimg2exr
  • Added -multiPart option to vrimg2exr that produces an OpenEXR 2 file with each render element in its own "part"
Embree
  • Update to Embree 2.3
  • Proxies and instances can now be accelerated by Embree
 miscellaneous features
  • Updated to OpenEXR 2.2.0 and added new DWA compression options to VRayOptionsRe
  • Support for point cloud rendering in 3ds Max 2015
  • Built-in DMC samples calculator for VRayLight, VRayMtl and brute force GI
Modified Features
V-Ray
  • Added an option to open the V-Ray messages window on error or warning only
  • Added by Object IDs selection method for Render mask
  • Added MaxScript access to the Trace sets include/exclude flag
  • Added %numPasses and %numSubdivs stamp keywords
  • "Camera Motion Blur" is controlled independently on "Motion Blur" setting
  • Embree enabled by default
  • Improved render speed when not using any render elements
  • Light cache "Use for glossy rays" option is enabled by default
  • Optimized hair rendering in general
  • Reduced memory usage for hair and particles
  • Renamed the "Time independent" option to "Lock noise pattern" in the DMC sampler rollout
  • The default GI methods are set to Brute force/Light cache
  • The default image sampler set to Progressive
  • The image sampler parameters rollout is unfolded by default
  • VFB is cleared always when doing network rendering with render mask
V-Ray RT
  • Added support for animated rotation of VRayHDRI
  • Added support for the 3ds Max default lights in production mode
  • Added support for VRayHairInfoTex
  • Added support for VRayLensEffects object selection (Intensity, Object ID and Material ID)
  • Adjust the width of the ActiveShade renderer UI to match the standard width of the production renderer
  • Clear the VFB when the camera is moved
  • Frameless progressive and RT rendering, which provides for earlier preview passes
  • Implemented export of the Area AA filter settings to .vrscene files
  • Improved refresh speed
  • Properly show statistics with region renders
  • Removed the Show Mask option from the user interface, the mask is written in VRaySampleRate render element for the progressive sampler
  • Remove ActiveShade related settings from the UI when used as production renderer
  • When V-Ray RT is used as a production renderer, hide unused render settings
V-Ray RT GPU
  • Added support for Crop/Place parameters of the Bitmap texture
  • Added support for the Flip Red/Green options of the standard Normal Bump texmap
  • Added support for the Visibility parameter in the 3ds Max Object properties
  • CUDA driver API errors are replaced with more meaningful error messages
VFB
  • Improved anaglyph stereoscopic preview to reduce retinal rivalry
  • Improved initialization speed of the History window when there are a lot of images in the history
  • The vfbControl MaxScript function returns values for the commands that have states
  • Made the History window compliant with the 3ds Max color theme
VRay2SidedMtl
  • Added ability to filter the translucency effect through the diffuse color of the front-facing side
VRayClipper
  • More robust and faster algorithm is used
VRayDirt
  • Added "double sided" option
  • The distribution parameter can now take negative values for more defined edges
VRayFastSSS2
  • Added opacity texture slot
VRayHairFarmMod & VRayOrnatrixMod
  • Faster rendering of hair
VRayHDRI
  • Added MaxScript access to "coords" parameters
VRayLight
  • Added the ability to display the light name in the viewport
  • Somewhat faster sampling of rectangle lights
VRayMtl
  • Multiple layers of glass rendered with noise
VRayOSLMtl / VRayOSLTex
  • Improved shader cache logic, now the compiled shaders reside entirely in a memory buffer
  • Removed dependency of shader name on the shader file name
VRayProxy
  • Export texture coordinates for .vrmesh preview, if preview mesh is specified
  • Same proxies are automatically instantiated
  • Show proxy color set names in Vertex Color texture "Channel Name" list
  • Show the extra color channels from Alembic files in the "Channel Name" drop-down of Vertex Color maps applied to the proxy object
  • Support for Material ID channel when rendering with point clouds
VRayShadow
  • Made the U, V, W Area shadow sizes animatable in the VRayShadows params rollout
.vrscene exporter
  • Added combo box to select between Scene Animation/Frame range, the latter remembers the start/end values
Bug Fixes
V-Ray
  • DR hosts saved in scene were appended to the hosts list and used for consequent renderers
  • Fixed Embree crash on AMD machines
  • Fixed Embree crashes with specific scenes
  • Fixed incorrect rendering of 3ds Max Populate with motion blur with Embree
  • Fixed a crash when rendering a scene with ParticleFlow that is not generating geometry
  • Fixed a crash with VRayFur density map when rendering with V-Ray RT or Standalone
  • Fixed imageSampler_renderMask_texmap MaxScript property name
  • Fixed issue where VRayMtl's "Affect all channels" affects matte surfaces visible through refractive objects
  • Fixed light leaks when rendering bump mapping on surfaces that face away from the light
  • Fixed Render mask with Light Cache as secondary GI engine, causes darker final result
  • Fixed rendering wrong object when render selection mask is used with object that has Renderable property disabled
  • Fixed tiled EXR clipping to half-float precision
  • Fixed wrong error message "error: Auto-backup is enabled at file..." appearing when license is not found
  • Fixed wrong Irradiance Map buckets appearing from the DR render hosts
  • MaxScript V-Ray ".imageSampler_normal_threshold" parameter's name was ".imageSamper_normal_threshold"
  • Removed artifacts caused by overlapping geometry with disable Visible To Camera option for hairs
  • Strand index was not returned to shaders (e.g. Ox Hair)
V-Ray RT
  • Adaptive image sampling based on the Noise threshold did not work correctly
  • Added support for the color mode parameter
  • Camera movement was not updated if motion blur Duration was smaller than 1.0
  • Fixed no motion blur when the rendered frame is the last of the range and the keyframe is beyond the range
  • Fixed progress window update
  • Fixed rendering of scenes containing objects with many primitives and many texture mapping channels at the same time
  • Fixed updating of GI depth parameter
  • Fixed wrong camera field of view with network rendering
  • Hair is rendered with preview counts even when using V-Ray RT as production renderer
  • Rendering was not finished when Don't render (just export) option was enabled
  • The "Scatter coeff" and "Fwd/bck coeff" parameters of VRayMtl are swapped
  • The "Min shading rate" parameter was not exported to .vrscene files
  • VRayFur was exported with wrong coordinates instead of the Source object's
  • VRayHairMtl was not listed with compatible materials in the material editor
  • VRaySun was replaced by another object, when linked to it
  • When "dynamic tesselation" was turned on, the hairs UVs were lost
  • When V-Ray RT was used as a production renderer, output images were saved without alpha channel
V-Ray RT GPU
  • CUDA engine could not render VRayFlakesMtl unless VRayCarPaintMtl is was present in the scene
  • Did not fully utilize the GPU after certain noise level was reached
  • Direct light render elements were rendering black if GI depth was 0
  • Falloff texture was rendering wrong (greenish)
  • Fixed crash with V-Ray RT GPU on scenes with more than 100 lights
  • Fixed crash with Normal map assigned to Mix map that is assigned to Bump map slot
  • Fixed crash with VRayOSLMtl
  • Fixed handling of environment override maps intensity multipliers
  • Fixed inverted bump effect when using bitmap in VRayNormalMap
  • Fixed memory leak
  • Fixed Fresnel texmap shading
  • Fixed render server crash when changing materials of VRayProxy
  • Fixed some render elements cause others data shift in the wrong channel
  • Global illumination BF/LC setup was rendering differently than on the CPU
  • Multi/Sub-Object material was not wrapping the IDs for static meshes
  • VRayMtls bump multiplier was not working with VRayNormalMap
Progressive sampler
  • Progressive sampler: Fixed crash with region rendering and sample rate render element
  • Progressive sampler: Switch to sRGB color mapping for AA, leading to faster sampling
DR
  • X-Ref scenes were not transferred with DR option "Transfer missing assets"
VFB
  • Edit boxes accept values without pressing enter
  • Fixed crash with Lens effects and active link to PDPlayer when an update occurs
  • Fixed lag when clicking between the VFB and other 3ds Max windows
V-Ray mesh exporter
  • Fixed crash when exporting point clouds with "lowest level point size" < 1.0
  • Particle systems were not exported with the "Export all selected objects in a single file" option
V-Ray Toolbar
  • Button were not working after 3ds Max Custom UI Layout load/reset
V-Ray Bitmap to V-RayHDRI converter
  • Fixed error when converting bitmaps to tiled EXR
V-Ray Light Lister
  • Fixed an issue with light temperature, not handling very low values
VRayBPTracer
  • Fixed calculation errors causing NAN results
  • Fixed crash with particular scenes
VRayClipper
  • The clipper showed up with ambient occlusion
  • The clipper affected objects from its exclude list even when it is hidden
  • There is ambiguous situation with instancing, rendering the last copy only
VRayColor
  • Color swatch and gamma were not displayed as Additional Params in the slate Material Editor
VRayFastSSS2
  • Fixed crash when rendering the object has Dent texmap for displacement
VRayFur
  • Fixed fur placement on "Selected faces" for 3ds Max 2014/2015
VRayHDRI
  • EXR textures are always loaded as 32-bit floating point
  • Fixed crash with IFL input when saving in a material library
  • Fixed Crop/Place not working
  • Fixed overbright pixels occurring with specific texture values
  • The texture cache size for tiled textures in VRayHDRI did not work correctly for values over 2 GB
VRayLight
  • Fixed incorrect rendering of Dome lights with scaling, they should not take it into account
VRayMtl
  • Fixed Self-illumination multiplier value not taken into account
VRayOSLTex
  • Fixed crash when used as environment texture
VRayPhysicalCamera
  • Tilt/Shift parameters were not reflected in the viewport when loading a scene
VRayProxy
  • Cannot select in the viewport if there is a recorded preview mesh that falls outside the render-mesh bounding box
  • Fixed crash when opening a scene containing a proxy created from an empty group
  • Fixed incorrect UVW coordinates with point clouds
  • The Alembic subdivision parameters were the same for all proxies
VRaySkinMtl
  • Fixed textured scatter radiuses not taken into account
img2tiledEXR
  • Alpha channel was created even if there was not such in the input image
  • Fixed wrong pixel aspect in the output image
miscellaneous fixes
  • Crashes with building the SD tree in specific scene
  • Render mask was not exported to .vrscene files
  • Fixed incorrect depth with camera motion blur for deep image output
  • Fixed 3ds Max crashes when pressing the "Last VFB" button with V-Ray RT set as Production renderer
  • Fixed a crash with "Render to fields" enabled on 3ds Max 2012
  • Fixed unhandled exception error when rendering geometry imported from Revit
  • Fixed render crash with ProBoolean scene geometry
  • Fixed slow SD tree build on many-core machines
