©BBB3viz
Build 3.30.05
Official release
Date – March 10, 2016
Download – Build 3.30.05
Bug Fixes
V-Ray
  • Fixed artifacts in alpha channel with specific scene when deep merge mode is by z-depth
  • Fixed DR servers not proceeding to next frame during animation rendering
  • Fixed rarely DR servers not taking part in light cache calculation due to desynchronisation with the render client
  • Fixed random pixels in render elements with layered materials
  • Fixed random hanging with very low texture cache memory limit and tiled textures
VRay RT
  • Matte objects were receiving shadows from themselves
  • Switching the input language during ActiveShade session was changing 3ds Max's decimal symbol to point
VRay RT CPU
  • Turning on "Enable color map" in Output was clamping textures in Environment and Dome VRayLight texmap slots
VRay RT GPU
  • Fixed crash due to very long node user properties string
  • Fixed VRayMultiSubTex "Face material ID" and "Random by Node Handle" modes rendering
VFB
  • Dragging a button from the VFB toolbar was causing focus freeze
  • Mouse cursor was sticking to the the sliders in the lens effects settings
VRayClipper
  • The mesh was inaccessible through MaxScript
VRayExtraTex
  • Fixed automatic name change when loading a scene saved with older version of V-Ray
VRayHDRI
  • Fixed "Use Real-World Scale" option affecting the material editor preview when not using the standard 3ds Max mapping
VRayInstancer
  • Fixed crash with ThinkingParticles
VRayGLSLMtl/VRayGLSLTex
  • Fixed crash with CUDA error 700 on shader parameters change during ActiveShade
VRaySamplerInfo
  • Integer scalar mode was producing wrong results
VRayScannedMtl
  • Avoid calculating shadow rays that are not needed
VRayStereoscopic
  • Writing deep output was crashing
VRayVolumeGrid
  • Fixed Houdini imported grid transformation
vrimg2exr
  • Broken output when converting to 16-bit EXR with "Data window" option enabled
Build 3.30.04
Date – January 20, 2016
Download – Build 3.30.04
New Features
V-Ray RT GPU
  • Added initial support for VRayTriplanarTex
Modified Features
V-Ray RT GPU
  • Optimized bitmap memory management
VRayMtl
  • "Opacity mode" option default set to "Stochastic"
VRayVolumeGrid
  • Enabled pure Volumetric render mode in V-Ray RT
  • Implement support for nameless VDB channels
  • Probabilistic volume sampling overrides the GI particle mode shading
setvrlservice
  • Added prompt for administrative credentials
Bug Fixes
V-Ray
  • Reduced memory usage for light cache preview with high resolution images
  • Closing of the DR settings window shown by the vrayEditDRSettings() MaxScript command was opening the V-Ray Message Log window
  • Fixed crashes with animation and light cache with distributed rendering
  • Fixed hanging with tiled textures and very small texture memory limit
  • Multi/Sub-Object material with a VRayBlendMtl that has the base material blank was not casting transparent shadows
  • The %os keyword in the frame stamp did not recognize Windows 10
  • Reduced noise with Adaptive sampling and "Sub-pixel mapping" enabled
  • Reverted to V-Ray's render messages window in 3ds Max 2016
VFB
  • Fixed incorrect loading of compressed .vrimg files with compression ratios greater than 100 percent
  • Fixed incorrectly received mouse clicks from other windows
VRay RT
  • Added support for the ColorCorrection map "Printer lights per" and exposure mode options
  • Dynamic geometry was disappearing after the first frame in Light Cache phase when rendering animations
  • "Enable color map" was causing clipping of texture colors with environment and VRayLight dome lights
  • Fixed crash if VRayExtraTex texmap change during ActiveShade
  • Fixed crash with Progressive sampler when the region is out of the image dimensions
  • Shader linking did not update in Slate Material Editor during ActiveShade rendering
VRay RT CPU
  •  Fixed memory usage for layered materials with opacity maps and fully transparent regions
VRay RT GPU
  •  Optimized memory usage for geometry instances' user attributes
  • Portal lights blocked shadows from other lights
  • The ColorCorrection map HSL to RGB and RGB to HSL conversions changed to match the production rendering
  • Texture mapping size and offset with "Use real-world scale" enabled were not working when the mapping was "Planar from World XYZ"
VRayAerialPerspective
  • Fixed overbright pixels with "Inscattered light intensity" less than 1.0
VRayEdgesTex
  • Fixed dark edges with rounded corners and Blinn/Ward/GGX BRDFs
  •  Fixed crash in V-Ray RT GPU when no input file was attached
VRayLensEffects
  •  Bloom mode with "Render element only" option produced darker images
  • Fixed changing params through MaxScript
VRayProxy
  •  Fixed animated rendering of proxies in "Show full mesh" mode with applied modifiers
VRayScannedMtl
  •  Fixed rendering transparent
VRayTriplanarTex
  •  Fixed Material Editor preview
VRayVolumeGrid
  •  Fixed self-shadowing export in V-Ray RT causing rendering slowdown
  • Fixed incorrect position changes with animated .vdb caches
  • Fixed incorrect frame smoothing
  • Fixed 3ds Max hanging when rendering with render cutter
  • Fixed multi-threaded cache files loading after a render has been completed in V-Ray RT and V-Ray Standalone
  • Fixed crash after repeated adding and removing of color gradient points
  • Fixed crash during GPU preview of fire in RGB mode with own opacity graph
  • Fixed differences between GPU viewport preview and rendering of fire
  • Fixed flipped meshing with .vdb caches from Houdini
  • Fixed "Object XYZ" texture mapping and preview in mesh mode for the Surface texmap
  • Removed noise on flat iso-surfaces produced by texmaps
  • Fixed rendering of speed channel from .f3d/.vdb caches
  • Fixed artifacts with grid-based self-illumination with DR
ply2vrmesh
  •  Mesh transformations were ignored with the -mergeVoxels option
  • Instancing reverted to disabled by default when converting Alembic files because it's causing problems with previews
V-Ray Scene Converter
  •  Avoid script errors on converting Standard material with Strauss BRDF
.vrmesh Exporter
  •  Fixed exporting of VRayProxy objects in "Show full mesh" mode with modifiers
V-Ray Quick Settings
  •  The "AA Quality" slider was not changing the "Color threshold" of AA settings
Build 3.30.03
Official SP3 release
Date – December 15, 2015
Download – Build 3.30.03
Modified Features
V-Ray
  • Minor speed up of rendering with the light cache
  • Minor speed up when accessing tiled textures
  • Enabled assigning of existing trace sets to object nodes through the vrayAddTraceSets MaxScript function
VFB
  • Faster activation of the mouse tracking with the progressive sampler and V-Ray RT
V-Ray RT
  • Added option to disable the in-process rendering
V-Ray RT GPU
  • Increased the GI bounces when retracing the light cache
Bug Fixes
V-Ray
  • Fixed crash when rendering Particle Flow system with VRayLightMtl with Falloff map
  • Wrong samples distribution with VFB mouse tracking and progressive sampling and V-Ray RT
VFB
  • Fixed random crash when displaying RT stamp variables
  • Prevent restoring from maximized state when starting rendering
VRayHDRI
  • Fixed crash with EXR files using custom data window
  • Fixed "affect environment rays" support for V-Ray RT
  • Fixed export of the sun node for V-Ray RT
  • Avoid unnecessarily affected shadow rays or unscattered light for shadow rays
  • Fixed issues with dome lights
Build 3.30.02
Beta 2
Date – November 30, 2015
Download – Build 3.30.02
New Features
V-Ray
  • Minor performance improvements
V-Ray RT GPU
  • Initial support for rounded corners on the GPU
  • Initial support for the MultiTexture plugin from CGSource
V-Ray RT GPU OpenCL
  • Support for VRayDirt
Modified Features
V-Ray
  • Include the name of the material causing "invalid bump normal" warnings itself
  • Removed the V-Ray PowerShader banner from all it's appearances
  • Improve light cache quality for small render regions
  • The "Adaptive tracing" option for the light cache is removed as it didn't work reliably
VRayHDRI
  • Added tiling support and Real World Mapping in the Material Editor and viewport previews
Bug Fixes
V-Ray
  • Fixed crashes with ForestPack when preparing the scene for rendering
  • Fixed crashes when cancelling render while tessellating subdivided/displaced objects with "static geometry" enabled
  • Fixed crashes with dynamic meshes that have no faces but have more than one vertices
  • Fixed wrong URL of the Global DMC settings "?" button
  • The V-Ray option to show the render messages window on warning/error was still taken into account in 3ds Max 2016
  • Work around an issue with notification system in 3ds Max 2012, causing old scenes loading to crash
VFB
VRay RT
  • "Blur" parameter of VRayHDRI map was not correctly exported
  • Fixed broken scene updates since Beta 1
  • Fixed crash on render end with VRayMtlWrapper
  • Fixed crash with dynamic noise threshold when rendering as production renderer through Backburner
  • VRaySky randomly stopped illuminating the scene when the sun was disabled
  • Fixed unhandled exception when rendering motion blurred particles with longer duration and more than two geometry samples
VRay RT GPU
  • Fixed crash when rendering through Backurner
  • Fixed incorrect orientation of VRayHDRI in environment slots
  • Wrong ground color for the VRaySky texture
  • Fixed wrong rendering of VRayMultiSubTex texture in DR mode
  • Different "phase" parameter of the Noise texture compared to RT CPU
  • "Cast shadows" option not working on objects with Multi/Sub materials
  • Fixed flipped normals on objects with negative scaling and displacement/subdivision
  • Fixed crash with empty Output maps
  • Fixed wrong implementation of the "saturation" parameter of the ColorCorrection map
  • Fixed wrong mapping of VRayFlakesMtl when using in-process RT
  • The "Clamp" output option of the Bitmap texmap was not working
  • Fixed crash if there was no VRaySun in the scene
VRayMetaball
  • Wrong motion blur on PFlow events that reduce the particle count
  • Fixed crash when encountering duplicate structures with different layouts
  • Fixed crash when re-loading shaders with syntax errors
  • Fixed crash when VRayHDRI texmap is attached as input
VRayVolumeGrid
  • Fixed black pixels occurring when rendering Phoenix FD with "Affect background" off and "Color Clamp" on
.vrmesh Exporter
  • Fixed wrong results when total mesh faces were less than "min faces"
Build 3.30.01
Beta 1
Date – November 10, 2015
Download – Build 3.30.01
New Features
V-Ray
  •  General speed improvements
  • New adaptive sampling algorithm for better detection and clean-up of noise in the image
  • Added option for automatic subdivs calculations for materials and lights
  • Better GI distribution (more robust handling of reflective GI caustics) for interior scenes
  • Experimental support for machines with more than 64 logical cores (enabled through VRAY_USE_THREAD_AFFINITY=1 environment variable)
  • Better sub-pixel filtering for the progressive sampler
  • Dynamic noise threshold for the progressive sampler for more even noise distribuion
  • Internal spectral color space switched from CIE RGB to sRGB
  • Updated default settings
  • Added "Generate render elements" option to the V-Ray object properties
  • Added vrayGetStampVariable() MaxScript function to return the value of any VFB stamp variable
V-Ray RT
  • In-process RT engine (no separate command-line opens up)
V-Ray RT GPU
  •  Support for lights include/exclude
  • Better support for AMD hardware
  • Initial support for GLSL texture shaders
  • Support for hair and particles from VRayProxy objects
  • Added initial support for VRayMultiSubTex
  • Added support for 3ds Max procedural textures in environment slot
  • Added support for VRayFur
  • Added support for MultiTexture
  • Added support for mapped IOR of VRayMtl
  • Added support for the physical camera bitmap aperture
  • Added support for the "cast shadows" option of the V-Ray lights
  • Added support for VRayPlane
  • Added support for VRayUserColor and VRayUserScalar
  • Support for texture-mapped "radius" parameter in VRayDirt
VFB
  • Ability to compare the V-Ray settings recorded with the VFB history images
  • Ability to export the color corrections settings as single LUT (.cube) file
  • Ability to load color corrections from VFB history
  • Ability to remember the window position since the last 3ds Max session
VRaySun / VRaySky
  • New sky model (Hosek et al)
  • Added ground color parameter
VRayMtl
VRayStochasticFlakesMtl
  • New stochastic flakes material for car-paint like materials
VRayEdgesTex
  • Implemented raytraced rounded corners when used as bump map
VRayNormalMap
  • Added an "Additional bump map" slot
  • GLSL shaders are now compiled to binary code through LLVM for increased render speed
VRayTriplanarTex
  • Added a texture for triplanar mapping
  • New aerial perspective atmospheric effect
VRayClipper
  • Ability to clip against arbitrary meshes
VRayFur
  • Implemented options for hair curling
VRayInstancer / VRayMetaball
  • Added ability to pick individual PFlow events
VRayProxy
  • Specify the proxy preview faces as percentage of the original faces, min and max values
VRayVolumeGrid
  • Added options for probabilistic volume sampling in the VRayVolumeGrid atmospheric effect
  • Added support for importing VDB caches from FumeFX 4
Modified Features
V-Ray
  • Automatically disable the bitmap pager
  • Distributed calculations of the light cache with distributed rendering
  • Further speed improvements for proxies and instances (beyond what we had in V-Ray 3.20.03)
  • Improved CPU utilization for the progressive sampler when using noise threshold
  • Speed improvements when rendering displacement/subdivision surfaces
  • Added progressive sampling buffer memory usage info to the V-Ray rendering messages log
  • Optimized Mitchell-Netravali filter performance on Intel Xeon CPUs
  • Added warnings about compatibility issues with Blend, Shellac and Composite materials
V-Ray RT
  • .vrscene exporter support for VrayScannedMtl
  • Added "Show log" button in the System rollout when set as production renderer
  • Avoid burning the RT statistics into the final saved images
  • V-Ray plugins can be loaded from multiple paths set in the VRAY30_RT_FOR_3DSMAXNNNN_PLUGINS environment variable
  • Moved the "Ignore in RT Engine" option from Object Properties to V-Ray Properties
V-Ray RT GPU
  • Improved light cache with support for motion blurred hairs
  • Optimized the "Compiling geometry..." phase on scenes with many nodes
  • Print warning for unsupported textures
V-Ray RT GPU CUDA
  •  Prevent kernel recompilations during ActiveShade
VFB
  • Added tooltip with the image comment to the images in the VFB history
  • Adding/removing render elements will not delete the contents of the frame buffer
VRayMtl
  •  Moved the "Use interpolation" options for reflections/refractions to the relevant rollout
VRayBlendMtl
  •  Added toggle controls for the coat materials
VRayOSLMtl/VRayOSLTex
  •  Added user tags support for textures connected to a GLSL/OSL texture or material
VRayDirt
  •  For newly created VRayDirt textures, the subdivs (and samples quality) is no longer influenced by antialiasing settings
VRayHDRI
  •  Tiled textures caching optimizations
  • Support for UDIM tiles greater than 1999
VRayOSLTex
  •  Fixed incorrect results when the "Mirror" and "Tile" options are switched off
VRayEnvironmentFog
  • Enabled adding of multiple lights in the Environment Fog field through "Select by name" dialog
  • "per gizmo fadeout enable" option is disabled by default
  • Renamed the per-gizmo "fadeout" parameter to "falloff"
VRayVolumeGrid
  • Added automatic preview detail reduction
  • Allowed the render diagrams/gradients to be resized by MaxScript
VRaySamplerInfo Render Element
  •  Added modes to extract a specific node user attribute as an integer or floating-point render element
  • Added support for Corona 1.2.1
  • Added support for the Output rollout and crop/placement values;
V-Ray vrmat Converter
  •  Added support for VRayHDRI and VRayNormalMap
V-Ray Installer
  •  Auto-run the license server if it was running prior the installation
vrayspawner.exe
  •  Accepts "-numthreads" option to limit the number of threads for the DR node when not using NUMA options
Bug Fixes
V-Ray
  • "Transfer missing assets" option wasn't working trough Backburner
  • Automatically turn off image filtering with Cube 6x1 cameras because it is causing "Invalid geometric normal (-0 -0 -0)" errors
  • GI "Leak prevention" parameter name was disappearing when loading settings from VFB history file
  • Light Cache was crashing at Merging Passes stage with Motion Blur and particle systems
  • Fixed wrong results with sharpening image filters when rendering with progressive image sampler and V-Ray RT
  • "Maps" option in Global Switches doesn't disable the textured lights properly
  • Per-pixel statistics were wrong with region render
  • Render mask in texture mode was loading only the top level bitmap if there were sub-textures
  • Rendering was freezing with static subdivision and tiled textures when the displacement map is missing
  • Rollouts in the Render Settings window were disappearing when loading V-Ray presets
  • The "?" button for the Adaptive image sampler was opening broken URL
  • Fixed crash with Free Directional Lights
  • Fixed wrong result in the VRayShadows render element
  • Added missing V-Ray items in the 3ds Max menus
VRay RT
  • 3ds Max Photometric lights' filter color was not exported to .vrscene files
  • Camera animation was not properly exported to .vrscene files
  • Could not lock render view if Phoenix FD GPU preview is in one of the viewports
  • Fixed crash when creating spherical light during ActiveShade
  • Fixed 3ds Max crash when inserting VFB stamp variables after rendering as production renderer
  • Fixed crash when re-connecting Multi/Sub-Object material to VRayBlendMtl during ActiveShade
  • Fixed different results with VRayIES lights compared to the production renderer
  • Fixed error when rendering Normal Bump map with texture in Additional bump map and no Normal map set
  • Fixed export of textures redundantly wrapped in TexOutput plugin
  • Fixed random error "stage 2" after tweaking exposure settings due to uninitialized resources
  • Fixed silent crash when closing 3ds Max after rendering
  • Fixed VRayBlendMtl exporting of redundant BRDFLayered plugins for the sub-materials
  • Fixed wrong scaled camera rendering
  • Gradient Ramp texture had Surface Normal not properly calculated for backfacing polygons
  • MaxScript/Quad menu export to .vrscene was always creating animation keyframes
  • Meshes with subdivision should be exported as GeomStaticSmoothedMesh
  • Prevent hidden geometry export
  • Subtract function in VRayCompTex was producing incorrect results
  • The parameters for probabilistic lights were not exported to .vrscene files
  • The RGB Offset, Level and Output Amount from the Output texture and rollout were not applied correctly
  • VRayDistanceTex was not exported
  • VRayFur placement by material ID was offset by 1
  • VRayGLSLTex and VRayOSLTex were not shown as compatible textures in the material editor
  • VRaySun exclude list was not applied
VRay RT GPU
  • Fixed crash on closing of the Render Message window in 3ds Max 2016, during ActiveShade
  • Fixed lighting with dome light if it was not the first light in the scene
  • Fixed wrong results with textured VRayLights
  • "Inverse square" decay of Standard lights was not working
  • MultiMatte render element was not working when rendering with motion blur
  • Objects with animated displacement were disappearing on time change during ActiveShade
  • Removed artifacts caused by overlapping faces on VRayProxy objects with motion blur
  • VRayNormalMap was not rendering correctly
VRay RT GPU CUDA
  • "Auto update bitmaps" was not working
  • Fixed crash when deleting VRayClipper during Active Shade
  • Refractions were rendering differently compared to the V-Ray RT CPU
  • The "Mix Curve" of Falloff maps was not taken into account
  • Optimized memory allocation when loading scenes with many textures
  • VRayProxy objects' G-Buffer ID was not filled correctly
VFB
  •  Prevent auto-save an image in the history if the VFB has just been cleared
  • Adding points to the curve color correction was resetting the right tangent of the last point
  • Channels were mismatched in compare A/B mode when channels were different in both of the images
  • Fixed %frame variable in the frame stamp doesn't work
  • Fixed color correction rollouts scroll position after hiding rollouts
  • White balance color correction was causing hanging after rendering
VRayDisplacementMod
  •  The "max subdivs" parameter was not disabled for modes other than subdivision surfaces
VRayEnvironmentFog
  •  Fixed result affected by inactive instances
  • Was not irradiated by VRaySun in V-Ray RT
  • Wrong deep output was generated when using with multiple/overlapping gizmos
VRayHairFarmMod & VRayOrnatrixMod
  • Fixed crash when rendering with VRaySamplerInfo render element
VRayMtl
  •  Anisotropy and Rotation texmap shortcut buttons did not have context menus
VRayColor2Bump
  •  Was not returning correct number of sub-textures
VRayDistanceTex
  •  Fixed "inside color" leaking out with particular geometry
VRayFastSSS2 / VRaySkinMtl
  • Lights include/exclude list was ignored when motion blur was enabled
  • Fixed visible edges in raytraced mode when intersecting with other invisible geometry
VRayHairMtl
  • Fixed reflections when the material has glossy reflections and GI is off
  • Fixed missing direct light from VRayAmbientLight
VRayHDRI
  •  Elliptical filtering was crashing when assigned as environment map
VRayFur
  • "Placement" option was not reflected in the viewport preview
  • Source object's scaling was not taken into account
VRayNormalMap
  •  Fixed crash when the map channel is set to 100
VRayLight
  •  Environment was wrongly contributing to irradiance maps when there was a dome light with "affect alpha" disabled
VRaySky
  •  The wrong VRaySun lights was chosen in case there were multiple hidden but one
VRaySun
  •  Exposure in viewport was too dark in the in 3ds Max 2016
VRayPhysicalCamera
  •  Rendering with bitmap aperture was producing black images
VRayStereoscopic
  • Camera exposure from the VRayPhysicalCamera was applied twice to render elements when rendering with shademaps
  • Disable the DOF effect while rendering shade maps
VRayVolumeGrid
  •  Deleting and then undoing breaks all rendering and simulation functionality
  • Fire in "own opacity" mode was rendering very dim in reflections with glossiness < 1
  • Workaround F3D files from FumeFX using boundless simulation or wavelet are not scaled correctly
V-Ray Bitmap to V-RayHDRI converter
  •  Fixed error if there are Bitmap textures with no file names
