©BBB3viz
Build 3.50.04
Official release
Date Mar. 3, 2017
Download – Build 3.50.04
Modified Features
V-Ray / V-Ray RT
  • Optimize compiling geometry for scenes with displacement on machines with many cores
V-Ray IPR
  • Add settings rollout IPR options whether to track changes to the VFB size and whether to always use progressive sampling
V-Ray RT
  • Add an option to only render the visible part of image for OpenVR and Oculus renders (Follow VR headset)
V-Ray GPU
  • Do not consider Intel GPUs for V-Ray GPU
  • Take the adaptive lights number of lights into account
VRayDirt
  • Make unoccluded sub-texmap slot default when keeping replaced texture as subtexmap
VRayMDLMtl
  • Show MDL enum parameters as combo boxes instead of spinners
img2tiledexr
  • img2tiledexr should store its version and build date into the converted OpenEXR files
Bug Fixes
V-Ray
  • Animated Noise in VRayLightMtl with Direct Illumination On slows down the rendering drastically
  • Artifacts with Adaptive Lights in certain scenes
  • Deep image result is overwritten when post effects are enabled
  • Distributed rendering with no Use local host requires additional license
  • Improve saving time of progressive resumable files to a network location
  • Log flood with "Invalid normal index found on face" with specific geometry
  • Saving to raw images with non-ANSI names fails when post effects are present
  • The main thread hangs when some of the license servers are offline
  • Very slow compile geometry phase on particular scenes
  • Wrong VRayZDepth with use camera clip boundaries enabled and the physical camera's clipping planes disabled
V-Ray IPR
  • Constant refresh with VRayPhysicalCamera and V-Ray Exposure Control
  • Crash when adding a render element during IPR
  • Crash when using adaptive lights and a new light is added to the scene
  • Rendering hangs and 3ds Max 2017 UI freezes when Physical camera Lens Shift is modified
V-Ray RT
  • Export display sRGB parameter to .vrscene
  • Some machines can't load IFL files when accessing them from shared location
  • Unhandled exception when rendering scenes with Ornatrix feathers and displacement in production rendering mode
V-Ray GPU
  • Black regions with Projections
  • Different results with VRayClipper and Camera rays only option enabled
  • Adaptive Lights are not updated after change in region/resolution during ActiveShade
  • Compensate camera exposure of VRayLightMtl is not working
  • CUDA error 719 with specific scene
  • Fix potential crash with unsupported render elements
  • Alpha pixels missing with matte/shadow plane
  • Overexposed lighting when rendering with V-Ray GPU
  • The specular contribution does not get adjusted by the fog attenuation
VFB
  • Denoiser hardware acceleration type is not updated at render end
  • Denoiser is not applied progressively when rendering with V-Ray RT
  • Do not apply denoiser on load from history
  • Lens effects hardware acceleration mode doesn't work
  • Selecting a point in the curves color correction window causes the point to move
  • The curves color correction in the VFB should be applied after the exposure
  • Turning off the Select object mode during ActiveShade leaves the wrong cursor
VRayDenoiser
  • Denoiser is calculated every time before V-Ray RT rendering start if it was used before
  • The option Only generate render elements is producing corrupt file
VRayFur
  • Not properly generated with Bitmap texmaps
VRayGLSLMtl / VRayGLSLTex
  • Materials are transparent in BRDF mode
VRayGLSLMtl / VRayMDLMtl / VRayOSLMtl
  • None of the General shader properties are accessible through MAXScript
VRayOSLMtl / VRayOSLTex
  • Crash with 1000+ shader nodes
  • Exporting OSL materials with unconnected textures for V-Ray RT produces broken scenes
VRayProxy
  • Crash with Alembic file with containing incorrect UVW mapping indices in V-Ray RT
  • Custom attributes for alembic files are lost in Show whole mesh display mode
VRayToon
  • Active checkbox not exported for V-Ray RT
  • Add render element export for V-Ray RT
  • Missing toon effect with 3ds Max standard cameras
VRayMDLMtl
  • Crash when loading an .mdl while V-Ray RT is running and then stopping it
  • Exporting empty MDL materials fails
  • Merging light cache passes is very slow when rendering scene with missing MDL resource files
  • Shows as incompatible when V-Ray RT is set as production render engine
  • Spinners reject negative parameter values
  • Treat df::bsdf() as black diffuse
  • Wrong rendering of MDL texture with bump on geometry with incorrect tangents
VRayScatterVolumeMtl
  • NaN pixels occur
VRayScene
  • Animation is not working for V-Ray RT
  • Missing objects from imported vrscene when rendered with V-Ray RT
  • Snippet override with wildcards doesn't work on Windows 7
V-Ray scene converter
  • Broken lights instances after conversion
img2tiledexr
  • Fails to convert files properly after 3.50.03
Build 3.50.03
Official release
Date February 8, 2017
Download – Build 3.50.03
New Features
V-Ray GPU
  • Distortion support for physical camera
Modified Features
V-Ray
  • Move the VRayDenoiser progressive update frequency in the System rollout
V-Ray RT
  • The IPR button in the VFB should work when V-Ray RT is the production renderer
  • ActiveShade should render with the current VFB resolution and should track changes to the VFB size
  • Export Forest Color information as color instead of 3 float numbers
V-Ray GPU
  • Add a warning when users have Adaptive Lights and Shadows RE enabled
  • Support VRayUserColor to be used for mapping channels
  • Support the noise parameters for Gradient Ramp texture
V-Ray IPR
  • Add MAXScript callback when IPR completes rendering
  • Production IPR should fill the VFB and react to changes in the VFB size and changes to render resolution
  • Production IPR should react to changes in the render region in the VFB
  • Track changes to node properties both V-Ray and user during IPR
  • Track changes to the environment overrides in the render settings during IPR
VFB
  • Add command for VFB display control (vfbControl #show)
  • RGB button switches between RGB color and effectsResult channels
  • Show HSV values in the VFB pixel information window
VRayMDLMtl
  • Add displacement support to MDL
  • Display texture parameters in MDL materials as file buttons
VRayScene
  • Override material with 3ds Max native materials
VRayVolumeGrid
  • Option to disable the Optimizing Volumetrics rendering pre-pass
V-Ray Scene Converter
  • Blend material to VRayBlendMtl conversion support for sub materials and textures
  • Convert Corona's native materials, textures, and lights to V-Ray ones
Bug Fixes
V-Ray
  • Adaptive lights don't work with fly-through light cache
  • Concatenated node user attributes on VRayProxy objects
  • effectsResult channel is not saved with .vrimg file from Render Setup
  • Resumable rendering with bucket sampling and post effects stops with an error after the first completed frame
  • When saving a scene with GLSL, OSL or MDL the full path to the file is not always written
V-Ray RT
  • Incorrect adaptive lights with production (non-ActiveShade) renders
  • Light cache from map is not used in out of process rendering
  • Not located alembic proxies with local paths
  • Not updating the IFL sequences properly during time slider change
  • Some scenes with multiple MDL materials fail to export
  • Wrong rendering with light cache from file saved with adaptive light grid
V-Ray GPU
  • Adaptive lights with VRayClipper with affect lights off in some cases has artifacts
  • Artifacts with Skylight portal and adaptive lights
  • Artifacts with VRayLight exclude lists and Adaptive lights
  • Bump looks wrong with object-space UVW generator
  • Compiling geometry takes too long in a specific scene when using GPU
  • Crash when tweaking the displacement amount in specific scene
  • Crash with adaptive lights and disabled light portals
  • Discrepancy in rendering of Normal, Average and Multiply Blending Modes of Tint in Forest Color texture
  • Crash with empty Forest Color map channel
  • Don't save matte render elements for GPU when writing to image
  • ForestPro objects not rendered when Displacement is enabled in specific scene
  • Gradient Ramp connected to Gradient Ramp renders wrong
  • Lens effects Object/Material ID is not working with GPU rendering
  • Max ray intensity is not applied to self-illumination and light cache bleeding
  • Noisy results even though the sampling settings are high
  • Occasionally wrong lighting with adaptive lights
  • Random crash when using light cache with adaptive lights
  • Some Render Elements render wrong in specific setups
  • Render is very slow floods the kernel with invalid messages when rendering with On-Demand textures but there are no textures in the scene
  • Tweaking assigned Color Correction maps to Environment changes the output
  • Visible mesh edges on refractive objects
  • XRef Multi/Sub-Object material renders black with CUDA
V-Ray IPR
  • Changing properties of the VRayPhysicalCamera are not updated in IPR
  • Crash after using the V-Ray Light Lister during production IPR
  • Crash when accessing the Material Editor during an ActiveShade session with Clear cache on render end enabled
  • Crash when adjusting curves in VRayHDRI during IPR
  • Crash when cloning a specific object during IPR
  • Crash when creating instances in a particular scene during IPR
  • Crash when creating VRayLight without dragging for setting the size during IPR
  • Crash with IPR with VRayFastSSS2's object-based pre-pass
  • Crash with XRef materials during IPR
  • IPR crashes with VRayExtraTex Render Element
  • IPR render from camera that has Skew modifier applied doesn't match production render
  • Locked camera view is not respected in IPR
  • Making an object a shadow catcher from the V-Ray toolbar is not updated in IPR
  • Modifying VRayLight created in IPR as a Copy crashes 3ds Max
  • Occasional crash with IPR related to texture shortcut buttons
  • Unhandled exception with instanced objects during IPR
  • VRayLightMtl intensity is not properly updating in IPR
  • Hiding and unhiding of nodes is not reflected in production IPR
  • Render mult parameter of VRayHDRI is not working in IPR
VFB
  • Environment variables not re-read defined in OCIO
  • Fix scaling of non-native resolution images in the history
  • Hide lens effects ID masks when loading from the history
  • Lens effects are not updated every time the update button is pressed
VRayCurvatureMap
  • Crashes when rendering with VRayCurvatureMap inside VRayExtraTex Render Element
VRayGLSLMtl/VRayGLSLTex
  • Shader inputs are not shown when using Quick Shader
VRayMDLMtl
  • 3ds Max occasionally crashes on closing in shutdownNeuray()
  • Crash when changing parameters during out of process ActiveShade session
  • Crash when referencing missing textures
  • Materials with textures crash when connected to VRayBlendMtl
  • MDL files are not loaded on scene open
  • Reloading the same MDL material makes the preview disappear
  • The gamma mode is ignored
VRayNormalMap
  • The normal map is affected by the bump map multiplier
VRayProxy
  • User attributes aren't distributed to all references/instances
VRayScene
  • Alembic preview is not loaded
VRayToon
  • Map for color is not exported for V-Ray RT
  • The hidden edges of objects with non-fully opaque materials are drawn
VRayVolumeGrid
  • The Loop Overlap option is not exported to V-Ray RT and vrscenes from 3ds Max
vrimg2exr.exe / img2tiledexr.exe / V-Ray
  • Slow EXR saving process on network location
Build 3.50.02
Beta release
Date January 12, 2017
Download – Build 3.50.02
New Features
V-Ray
  • Add VRayRawDiffuseFilter, VRayRawReflectionFilter and VRayRawRefractionFilter render and bake elements
  • Fallback to limited functionality Demo mode if no license is present
V-Ray RT
  • Add support for adaptive lights
V-Ray GPU
  • All supported procedural textures to work for bump maps, when used through VRayColor2Bump texture
  • Implement support for Forest Color texture
  • Support for Mapped, Linear and 4 corners Gradient types in Gradient Ramp texture
  • Support for adaptive lights in CUDA (both in Production and in ActiveShade)
  • Support for the planar VRayClipper
VFB
  • Lens effects work on the denoised result if a denoiser render element is present
  • Lens effects can be enabled and adjusted during rendering
VRayMDLMtl
  • Integrate support for NVIDIA MDL
  • Initial support for VRayMDLMtl in V-Ray RT
VRayScene
  • Implement scene node that supports rendering geometry and materials from a .vrscene file and settings override with another file
VRayToon
  • Ability to store the toon outlines in a separate render element
VRayVRmatMtl
  • Does not update on filename change in V-Ray RT
V-Ray Toolbar
  • Add button to make selected objects shadow catchers
Modified Features
V-Ray
  • 3ds Max render effects should be applied when the Stop button is pressed in the render progress
  • Adaptive lights sampling improvement when the total lights are less than the Adaptive lights count
  • Bucket resuming writes its own .vrimg output if other output format is set
  • Enable adaptive lights by default
  • Faster 2d displacement on machines with many cores
  • Faster rendering of proxies on many-core machines
  • Improve the HDR images loading speed
  • Make 1 a possible value for Geometry samples in Render Setup
  • Remove limitation on parameters count for OSL and GLSL shaders
  • Restore the 3ds Max project folder after DR render
  • Rework post-effects pipeline to avoid Lens effects overriding the denoised image in particular
  • Right-click on parameters' spinners should reset them to the default values instead of zero for most of V-Ray plugins
  • The light grid for adaptive lights does not take specular light contributions into account
V-Ray RT
  • Allow irradiance map and light cache from saved file in ActiveShade
  • Change mouse cursors for some of the right click modes during Active Shade
  • Implement export of VRayToon
  • Implement the glossy Fresnel options
  • Improve random by render ID values generation for V-Ray RT and matched with VRayMultiSubTex
VFB
  • Add a render stamp variable noiseThreshold for the reached noise threshold of the progressive sampler
  • Add toolbar button for copying the current channel to clipboard
  • Increase default VFB history maximum files count to 100 and the size on disk in MB to 10000
  • Show a progress bar in the VFB during IPR session
VRayALSurfaceMtl
  • Support for Raytraced SSS ID V-Ray object property
VRayMtl
  • Disabled by default the GI checkbox for self-illumination
VRayMtlReflectIORBake
  • Replace the Store in fixed point format (rg.ba) option with an Invert value one
V-Ray Bitmap to VRayHDRI converter
  • Bitmaps in objects/modifiers/environment should be handled
Bug Fixes
V-Ray
  • Adding lights during IPR session produces wrong results when adaptive lights are enabled
  • Artifacts with adaptive lights and VRayFastSSS2 material
  • Crash when modifying matte object material in IPR
  • Deep merge strategy set as None renders incorrectly with non-fully opaque objects
  • Different bump with bitmaps since 3.50.01
  • Environment map ghosting through objects when matte/shadow objects are in the scene
  • If there is no license available V-Ray crashes when rendering
  • IPR crashes with Hair and Fur on render stop
  • IPR crashes with VRayExtraTex render element
  • IPR crashes while painting with the VRayFurStyler
  • Issue with finalToon and orthographic cameras
  • Noisy pixels not cleaned up by the progressive sampler
  • Random crashes after progressive rendering is finished
  • Render hangs when resuming with DR and distributed light cache
  • Rendering hangs at transforming vertices when there is a VRayVolumeGrid and many VRayLightMtl materials with direct illumination enabled
  • OSL preprocessor-only output is polluted with diagnostic messages
  • Wrong viewport drawing of objects after rendering in 3ds Max 2017
  • Scene renders brighter when there is glass at the windows
V-Ray RT
  • Crash during ActiveShade with a scene with instanced VRayProxy
  • Crash with time slider and motion blurred meshes
  • Error when rendering RT DR with Max Frame buffer and Render Mask
  • Matte for refl/refr of VRayMtlWrapper has no effect
  • Mismatched Vertical Tilt correction compared to production renderer
  • Noisy results with progressive sampler when Sub-pixel mapping is enabled
  • Skew modifier on Standard cameras is ignored
  • Unhandled exception when editing part of specific material used as Override during ActiveShade session
  • Using Array tool during ActiveShade rendering causes missing objects in 3ds Max 2017
  • VRayIntancer crashes when rendering out of process
  • When setting through the VFB the camera focus distance it gets messed if the user clicks on a dome light
V-Ray GPU
  • Add warning when using too many textures per material with on-demand textures
  • Artifacts with shadow catcher
  • Bitmap aperture is not rendered with CUDA
  • Broken shader with dirt as layer weight
  • Can't use more than 1 triplanar texture for bump
  • Crash with Distance texture
  • Difference in transparency between RT CPU and GPU in specific scene
  • Different shader result in scene with complex procedural texture tree
  • Hair is rendered very slow with light cache
  • OCL device select tool doesn't save changes on some computers
  • On demand textures produce different result to Full Size with specific scene
  • Only the initial image of ifl sequence is used when the Bitmap or VRayHDRI map is linked to Output map
  • Refraction volume is shaded differently compared to CPU
  • Specific GLSL shader files produce error with CUDA
  • Moving lights in 3ds Max is causing GPU memory leak
  • Negative values for distribution of VRayDirt produce unexpected results
VFB
  • Artifacts in Compare V-Ray Settings window from VFB History when resized
  • Crash when lens effects Bloom mode is set to Render elements only
  • Random crash when switching production renderer from V-Ray RT to V-Ray with open VFB
  • Render region issues when set through MaxScript vrayVFBSetRegion function prior to rendering
  • The width of History Settings window is not enough to display the whole Completed Renders Only checkbox label
  • V-Ray RT settings are not saved in the history if set as production renderer
  • Zooming the color corrections curve causes major lagging of the UI
VRayClipper
  • Mesh clipper doesn't handle motion blur
  • More precise rendering with GI
  • Moving a mesh clipper during IPR session doesn't work correctly
VRayOrnatrixMod / VRayHairFarmMod
  • Typo in dynamic_tessellation parameter (was dynamic_tesselation) in both UI and MaxScript
VRayProxy
  • Mesh preview memory leak after 3.50.01
VRayStochasticFlakesMtl
  • Shading produces blending artifact
VRayToon
  • Crashes when rendering with VRayScatter
  • Produces artifacts when width map is set
  • Removing objects from VRayToon exclude list sometimes removes wrong objects
  • The Remove button of VRayToon exclude list becomes inactive when multiple toon effects are applied
VRayVolumeGrid
  • Crash when previewing or rendering a cache where the ID channel cannot be uncompressed
  • Deleting a volume grid object and then rendering causes a crash
  • Exporting a VRScene with volume grid object calculates light and particle pre-passes
  • Broken Lighting and Specular render elements for reflective/refractive geometry
  • Lights that were in the scene before creating a new volume grid object are added to its exclude list
  • Ocean Rendering hangs at low altitude when the container is far away
  • Slow creating and deleting of many lights from the scene
Build 3.50.01
Beta release
Date November 22, 2016
Download – Build 3.50.01
New Features
V-Ray
  • Enable usage as an interactive production renderer (IPR)
  • Enable the resuming of bucket renders from raw .vrimg files
  • Enable the resuming of progressive renders
  • Experimental implementation of adaptive lights
  • Optimize GI rendering
V-Ray RT
  • Support for direct output to Oculus Rift and HTC Vive
  • Object picking in VFB
  • Enable Set focus distance in the VFB for the selected camera
V-Ray GPU
  • Aerial Perspective support
  • Support for matte materials shadow catcher
  • Support for the VRayStochasticFlakesMtl material
  • Initial implementation for on-demand mip-map texture in production rendering mode
  • Less CPU memory usage when rendering scenes with many textures
  • Less GPU memory usage when rendering scenes with many textures
  • Implement support for Render mask
  • Support for velocity render element
  • Better handling of geometry and materials updates during ActiveShade
  • Add Low GPU thread priority option
  • Support for additive mode of the VRayBlendMtl
  • Support for transparency for the layers of the VRayBlendMtl
  • Add support for VRayAtmosphere render element
  • Fixed differences in lighting between V-Ray RT CPU and GPU
  • Fixed differences in texture blending between V-Ray RT CPU and GPU
  • Support for Irradiance Map from file
  • Support for RenderID, ObjectID and MtlID render elements
  • Implement ground projection of VRayHDRI
VFB
  • Implement hardware acceleration support for lens effects
VRayMtl
  • Implement Glossy Fresnel option
VRayALSurfaceMtl
  • Include alSurface shader port for V-Ray in the installation
VRayProxy
  • Support for user property tags in the proxy file name
VRayScannedMtl
  • Add ability to capture and render the back lighting
VRayVolumeGrid
  • Add a render preset for Maya Fluids vdb
  • Support for Cap Mesh mode in V-Ray RT
Modified Features
V-Ray
  • Add control for panoramic pole merging for stereoscopic rendering (V-Ray RT MaxScript properties .top_merge_angle .bottom_merge_angle)
  • Dome light minor speed optimization
  • Display warning when View navigation in ActiveShade is selected without looking through camera
  • Increase the tooltip display times in the render settings
  • Remove the interpolated reflections/refractions options
  • Set the default value for the dynamic noise threshold for the progressive sampler to 80
  • Use adequate precision for render elements (full/half precision) in OpenEXR files
  • When using a dome light, matte objects have visible outlines unless GI environment is overridden with zero
  • Bundle License Server with the installation instead of the vrlservice.exe
V-Ray / V-Ray RT
  • The progressive sampler should finish the current pass when the given "Render time" is surpassed
  • Draw the alpha channel during the undersampling phase of the progressive sampling
V-Ray RT
  • Apply resolution changes without restarting the rendering
  • Add Select object and Get object material right-click options in the VFB
  • Add UI mode views switcher for V-Ray RT between Default and Advanced views
  • Make V-Ray RT to take the render state of the Laubwerk trees options, not the viewport
  • VFB output file paths are not exported in .vrscene file
  • View navigation in ActiveShade VFB is too fast
V-Ray GPU
  • Support for the directionality attribute of the VRayLight in Plane mode
  • Ability to load precalculated Irradiance map GI cache files
  • Changes on materials with baked texture to be updated quicker
  • Faster rendering of materials with bump maps
  • Faster rendering with Bitmap output curves
  • Faster rendering of rounded edges texture
  • Print the message about not having OCL devices env var as a info, not warning
  • Print the OpenCL Driver version in the log
  • Print warning when there is a render element that's not supported on the GPU
  • Print warning when max sample level is set to 0
  • Raise the number of rays per pixel when the number of active pixels is too low
  • Solid reflective material getting alpha dropouts
  • Support for UVW coordinates type in VRaySamplerInfo render element
VRayMtl
  • Make the GGX BRDF the default one and turn on glossy Fresnel by default
  • Move the reflect on back side option in the reflection section of the Basic rollout
  • The anisotropy controls should be disabled when the BRDF is set to Phong
VRayProxy
  • Allow for the viewport preview to be overridden by another .vrmesh or Alembic file
  • Add rendering support for Mudbox exported .vrmeshes with Level-of-Detail
  • Interpolate geometry data for heterogeneous Alembic files with velocity channel
  • Optimized the preview read and update for animated proxies
VFB
  • MaxScript commands to show/hide history and color corrections panels of the VFB
  • Contrast curve should be applied in sRGB color space
  • Change the default values of the Lens Effects
  • Improve history images saving speed
  • Move the history image compare buttons from the main toolbar to history toolbar
  • The button for showing the messages log should bring the messages window to the front
  • White balance should be applied before exposure
VRayClipper
  • Optimize plane clipper with empty exclude lists
VRayDenoiser
  • A warning should be printed when the VFB is disabled
  • Check the sampler settings before starting a render and warn if incompatible
VRayHDRI
  • Add a MaxScript parameter for axial rotation
  • Enable support for multiple include paths in OSL
  • Speed up the texture sampling in OSL
VRayScannedMtl
  • Add ability to render licensed materials (library licenses)
  • Add support for Nitrous viewport preview
VRayStereoscopic
  • Add new fragment merge mode, where fragments are merged by render ID and z-depth
VRayTriplanarTex
  • The blend and scale parameters should be animatable
VRayToon
  • Add an option to exclude an object in the V-Ray object properties
VRayVolumeGrid
  • High-DPI support for the render curves and gradients
  • Improve the motion blur for atmospherics
  • Improve the velocity voxel preview
  • Optimize rendering with emissive lights, Ray-Traced self-illumination and complex geometry
  • Respect the maxRenderThreads setting in V-Ray during rendering
  • Support V-Ray's per-object motion blur duration override
  • When several points on diagram are selected, right click on one of them should affect all points
vdenoise.exe
  • Add abort on OpenCL errors
  • The noise level channel can also be named "VRayNoiseLevel"
V-Ray Toolbar
  • Creating VRayFur from the toolbar button should select the newly created fur object
  • Added an option to convert only selected objects
.vrscene exporter
  • Renderer settings of V-Ray RT as production renderer are not exported
Bug Fixes
V-Ray
  • Crash on loading scene after rendering with time stamp
  • Remove the "(notUsed)" from the imageSampler_renderMask MaxScript properties
  • Unwanted GI caustics with refractive materials with affect shadows enabled
  • Tiled texture cache set message is flooding the log when using Slate Material editor
V-Ray RT
  • Composite texture with Output map on reflect and diffuse gives a different than production render result
  • Crash with Particle Flow and motion blur when sliding the time during ActiveShade session
  • Crash when there are materials with very long names and special characters
  • Effect ID of VRayMtl is not exported
  • Excessive progressive sampling AA filter memory consumption with ActiveShade rendering and render region
  • Exclude lists of VRayDirt don't work with HairFarm
  • Exporter doesn't resolve light cache file paths
  • Exporter is missing some of the VRayMtl and VRayFastSSS2Mtl features
  • Isolating geometry in a scene with duplicating nodes names and handles produces WndProc error with out of process rendering
  • Invalid geometric normal warnings with VRayLight and stereo cube camera
  • Static geometry of VRayDisplacementMod is not exported
  • There is no motion blur on VRayFur when applied to a geometry with a modifier
  • Motion blur samples are not applied to animated VRayPhysicalCameras unless they are set locally
  • Not all supported image filters are exported
  • Not exported opacity texture correctly if names are the same with other textures
  • V-Ray trace sets are not exported
V-Ray GPU
  • Auto update bitmaps is broken with in-process rendering
  • Crash when reading from large, 8k+ textures
  • Crash when switching Noise coordinates to Vertex color channel while rendering
  • Crashes on scenes containing textures with elliptical filtering
  • Crash with motion blur and Material IDs set
  • Different texture output with Color Map and tweaked Output Amount
  • Different bump compared to CPU with Mask map
  • Difference in shading VRayDirt in VRayTriplanarTex
  • Different indexes of Ornatrix hairs on each frame
  • Flicker when rendering animation with Backburner/Deadline with lights with include/exclude lists
  • GGX BRDF produce noise in Object ID render element in CUDA
  • IES lights with invalid paths to files sometimes are rendered wrong
  • Incorrect sun position when using VRaySun/Sky with specific procedural color correction textures
  • Mapped masks of Composite map don't work
  • Material shader tree does not reflect the materials changes in ActiveShade in all cases
  • Out of process V-Ray RT rendering crashes on frame change in a scene with duplicating nodes names
  • Random by Render ID mode of VRayTriplanarTex is not applied in bump
  • Render elements does not respect the transparency of materials
  • Render server crashes when rendering animation with lights with include/exclude lists
  • Undersampling artifacts occur on the bottom and right edges of the region during ActiveShade session
  • Using excessive host mem when there are a lot of textures in the scene
  • VRayColor2Bump in base material of VRayBumpMtl deactivates VRayEdgesTex
  • VRayLight type Disc produces different lighting when textured
  • VRayZDepth clamp zdepth option has no effect
  • Wrong blending between texture and color in Falloff texture
  • Wrong lighting with max ray intensity set to 1
VRaySamplerInfo
  • Crash when rendering an object with changing topology and VRaySamplerInfo render element with Forward/Backward occlusion type
DR
  • "Failed to delete server scene file" DR warning appears but the file has been deleted successfully
VRayGLSLMtl / VRayGLSLTex / VRayOSLMtl / VRayOSLTex
  • GLSL and OSL plugins crash Max when the error message contains %
  • GLSL crashes when compiling embedded shaders
  • The BRDFGGX plugin and the GGX mode of BRDFVRayMtl produce different results
  • 3D noises appear as stripes
  • Incorrect rendering of V-Ray OSL shaders when part of a VRayBlend material
  • Preprocessor-only output is polluted with diagnostic messages
  • Hair tessellation segments are not calculated correctly for orthographic views
Hair & Fur
  • Invalid geometric normal (000) for "HairVrShadeable" warning with Hair and Fur
VRayLight
  • Light portals appear noisier than rectangular lights due to undersampling
MultiMatteElement
  • Opacity is not working with MultiMatteElement
VRayFastSSS2
  • Render to texture crashes with VRayFastSSS2 material
VRayDisplacementMod
  • Rendering an animation with 2D displacement with VRayHDRI map with values greater than 1.0 causes the object to disappear on the second frame
VFB
  • Artifacts appear on the render channels drop-down control after show/hide history
  • color correction controls disappear and lens effects settings are misplaced if scrolled down and resized
  • Enabled color corrections cause major UI slow downs in ActiveShade mode
  • Incorrectly resized when loaded a scene and the side panels have been open
  • Raw output image file extension is not persistent
  • Render channels drop-down box progressively diminishing its height
VRayBlendMtl
  • Appears invisible in the viewport set to realistic preview
VRayBump2Normal
  • Bump map slot is not updated when plugging/unplugging a map in Slate Material Editor
VRayClipper
  • Artifacts with animated object
  • Exclude list is not considered for generating VRayEdgesTex round corners
  • Generates artifacts on excluded objects with VRayFastSSS2/VRaySkinMtl
  • Generates darker result when clipping VRayFastSSS2/VRaySkinMtl in Raytraced mode
VRayDenoiser
  • Falling back to CPU with very wide images
VRayDisplacementMod
  • Crash in View-dependent mode in orthographic views
  • Crash with object-based VRayFastSSS2
  • Setting 2D displacement resolution to 1 crashes 3ds Max
  • Subdivision displacement in View-dependent mode is not calculated correctly for orthographic views
VRayFur
  • VRayFur does not generate proper defocusAmount render element with motion blur
VRayHDRI
  • Displaying parameters in the Compact Material Editor reinitializes ActiveShade rendering
  • Elliptical filtering is very slow with displacement
VRayLight
  • Crash when changing type in creation mode
VRayNormalMap
  • Faceted results on subdivided meshes
VRayOrnatrixMod
  • Hair does not render when loaded through an XRef object
  • Hairs get occluded when light, camera and hairs are linked to an animated object
VRayProxy
  • Automatically create proxies loads vrmeshes very slow
  • Incorrect normals geometry with mirrored transformation
  • Loading a specific Alembic file with particles crashes 3ds Max
  • NaN pixels with in the VRayRawShadow and VRayRawLighting render elements
  • Slow down when loading Alembic files with many meshes in 3ds Max 2017
  • Visibility lists are incorrectly refreshed
VRaySamplerInfo
  • Multi-sampled motion blur produces artifacts on animated proxies
VRaySkinMtl
  • Doesn't work with the Vexus material from John Martini
VRaySky
  • Deleted VRaySun still appears in the VRaySky
  • Find VRaySun from an XRef'd scene when using VRaySky
  • Does not appear in the Material Editor when V-Ray RT/GPU is selected as render engine
VRayToon
  • Black color in Width map produces artifacts in the RGB and render elements
VRayTriplanarTex
  • Crash when connected to bump slot through VRayNormalMap
  • Invalid bump normals warnings when source texture returns zero UVW coordinates
  • Normal maps are not rotated properly
  • Wrong tiling when plugged into bump map slot
VRayVolumeGrid
  • 3ds Max crashes when playing animation with Time Bend Controls mode set to Loop
  • Artifacts with Grid-based Self-Illumination
  • Bucket artifacts with a moving grid using Phoenix Light Cache together with motion blur
  • Different render result when rendering on CPUs with different number of cores
  • Each time a render diagram is expanded or collapsed, it is fitted again
  • Emissive lights are calculated in V-Ray RT even when the Fire channel does not exist
  • Geometry behind simulator occludes render elements
  • It is possible to open the right click menu when moving a point in the diagrams or gradients
  • Interface lag when looking at a missing frame from a very long cache sequence
  • Motion blur for volumetrics does not take into account Interval center
  • Per-axis zoom in the shading diagrams does not respect the cursor position
  • Rendering with motion blur and duration=0 will preprocess forever
  • Scene saved with the old curves in Simple Smoke mode always has Inactive transparency diagram
  • Scrubbing the timeline with animated Direct Cache index leads to 3dS Max crash
  • The Fire Color and Intensity curves should act as a whole when fitted
  • V-Ray RT won't render smoke shaded by Smoke channel
  • Volumetric Geometry mode creates holes in Alpha at geometry intersection when Jittering is enabled
  • When editing diagram handle coordinates, Smooth Bezier handles stop working properly
  • Wrong velocity scaling with imported volumetric simulation from Houdini
V-Ray Light Lister
  • Rows are overlapping
ply2vrmesh.exe
  • Node transformation is applied only to the vertex channel but not to the normals channel
vdenoise.exe
  • Crash with 8K OpenEXR files
V-Ray Installer
  • Help button opens the system browser rather than default browser
