©BBB3viz
This page provides information on setting up V-Ray through a silent installation and removing V-Ray through a silent uninstall.
A silent installation allows you to complete V-Ray installation without user input during the process using a predefined set of options. To set up a silent installation, you need to perform two steps: creating an .xml file and running the installer.
You can remove V-Ray from your machine similarly through a silent uninstall.
By using the Chaos installer for automatic installation with the respective options for that (-auto or -quiet=1), or otherwise installing a Chaos product, you accept the Chaos End User License Agreement and the Chaos Global Consumer Privacy Policy.
Creating the .xml file
Run the installation file from the command prompt with the -gui=0 argument. You can also add the -auto flag to make the installation automatic with default settings. Note that this accepts both the EULA and the Privacy Policy.
vray_adv_xxxxx_max20xx_x64.exe -gui=0
Follow the instructions and set up the installation as you want it on all machines. This creates a file named config.xml in the installation folder.
Running the installer
In the second step, run the installer with the following command:
vray_adv_70001_max2025_x64.exe -gui=0 -configFile="xml_file.xml" -quiet=1
The -quiet=1 argument causes the installer to read the variable values from the .xml file and does the installation without user input. If you do not specify the -quiet=1  option, the installer asks for a confirmation of each variable before proceeding.
Configuration File
The config.xml file holds configuration information about the settings of the installation. Below is an example of such a config file.
Example installer config XML file: xml_file.xml
<DefValues>
<Value Name="INSTALL_TYPE" DataType="value">0</Value>
<Value Name="ANONYMOUS_TELEMETRY" DataType="value">1</Value>
<Value Name="PERSONALIZED_TELEMETRY" DataType="value">0</Value>
<Value Name="PKGROOT_SELECT" DataType="value">0</Value>
<Value Name="INSTALLROOT" DataType="value">C:\Program Files\Chaos\V-Ray\3ds Max 2025</Value>
<Value Name="REMOTE_LICENSE" DataType="value">0</Value>
<Value Name="AUTO_INSTALL_UIMENUS" DataType="value">1</Value>
<Value Name="SHOULDUNINSTALL" DataType="value">1</Value>
<Value Name="CLEANUP_LOG_FILE" DataType="value">C:\Program Files\Common Files\Chaos\chaos_installs_cleanup.log</Value>
<Value Name="VISIT_SPOT3D" DataType="value">0</Value>
<LicServer>
  <Host>127.0.0.1</Host>
  <Port>30304</Port>
  <Host1/>
  <Port1>30304</Port1>
  <Host2/>
  <Port2>30304</Port2>
  <User/>
 </LicServer>
</DefValues>
Below is a description of the variables of the installer:
PKGROOT_SELECT
Select the V-Ray for 3ds Max installation target direcotry:
0 - This is the common Autodesk application path for all users. The actual path is: %ALLUSERSPROFILE%\Autodesk\ApplicationPlugins\.
1 - This is the Autodesk application path for the current user only. The actual path is: %APPDATA%\Autodesk\ApplicationPlugins\.
INSTALLROOTV-Ray for 3ds Max additional installation files directory. Uninstall information, the V-Ray SDK files and example projects.
AUTO_INSTALL_UIMENUSCorresponds to the Register V-Ray menus toolbar functionality.
SHOULDUNINSTALL
Specifies whether or not the installation uninstalls previous version:
1 – Uninstalls previous version
0 – Skips the uninstallation of previous version
REMOTE_LICENSE
Specifies whether the V-Ray license server runs locally or on another machine.
0 – The license server runs locally on the same machine.
1 – The server is on a different machine in the network.
ANONYMOUS_TELEMETRY
Controls the anonymous telemetry data collection. Includes the most used Product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
0 – Disabled.
1 – Enabled.
Enables anonymized telemetry that contains personally identifiable information tied to an individual user's license to help Chaos tailor and optimize the Product for better personal use.
0 – Disabled.
1 – Enabled.
VIDEO_DRIVER_TDR_DELAY_INCREASE
This controls the increase in tdr delay setting from the installer.
For huge scenes it may take longer time to export and prepare the GPU for rendering. Usually drivers automatically stop the process if there is no response in a small amount of time and report the application as not responding. To avoid this, we change the default delay of the drivers to 8 seconds.
0 – The installer does not make the change of the delay.
1 – The installer makes the change of the delay.
VISIT_SPOT3D
Specifies whether or not to open the V-Ray online documentation after the installation is complete.
1 – Opens the V-Ray online documentation.
0 – Does not open the V-Ray online documentation.
INSTALL_TYPE
Specifies the installation type:
0 – Workstation
1 – 3ds Max render server
2 – Standalone render server
For a complete description of each installation type refer to the Installation of V-Ray section.
<LicServer>This section specifies the client license settings.
<Host>IP_Address</Host>Primary license server's IP Address
<Host1>IP_Address</Host1>Alternate license server's 1 IP Address
<Host2>IP_Address</Host2>Alternate license server's 2 IP Address
<DefValues>
 <Value Name="VROL_INSTALLED" DataType="value">1</Value>
 <Value Name="VROL_INSTALL_PATH" DataType="value">C:\Program Files\Chaos\VRLService\OLS</Value>
 <Value Name="ISRUNNING_VROL" DataType="value">1</Value>
 <Value Name="ISRUNNING_VRLSERVICE" DataType="value">0</Value>
 <Value Name="REVERT_INSTALL" DataType="value">1</Value>
 <Value Name="PROGRAMFILES" DataType="value">C:\Program Files</Value>
 <Value Name="MAXROOT" DataType="value">C:\Program Files\Autodesk\3ds Max 2021\</Value>
 <Value Name="STDROOT" DataType="value">C:\Program Files\Chaos\V-Ray\3ds Max 2021</Value>
 <Value Name="PLUGINS" DataType="value">C:\Program Files\Autodesk\3ds Max 2021\plugins</Value>
 <Value Name="STARTMENUPROG" DataType="value">C:\ProgramData\Microsoft\Windows\Start Menu\Programs</Value>
 <Value Name="COMMONFILES" DataType="value">C:\Program Files\Common Files</Value>
 <Value Name="VISIT_SPOT3D" DataType="value">1</Value>
 <Value Name="VIDEO_DRIVER_TDR_DELAY_INCREASE" DataType="value">1</Value>
 <Value Name="OPEN_CHANGELOG" DataType="value">1</Value>
 <LicServer>
  <Port>30304</Port>
  <Host1></Host1>
  <Host2></Host2>
  <User></User>
 </LicServer>
</DefValues>
SHOULDUNINSTALL
0 Skips the uninstallation of previous version
REMOTE_LICENSE
0 The license server runs locally on the same machine.
1 The server is on a different machine in the network.
REVERT_INSTALL
The parameter is used when the installer encounters an error – it triggers uninstallation and removes the files that have been populated before the error appears.
Should always be set to its default 1.
MAXROOT
Specifies the root folder of 3ds Max.
STDROOT
Specifies the destination folder for V-Ray additional files (tools, documents, samples, libraries and uninstall information)
PLUGINS
Specifies the plugins folder for 3ds Max; the default places it as a sub-folder of the 3ds Max root one.
STARTMENUPROG
Specifies the destination path where shortcuts are placed.
COMMONFILES
Specifies the destination folder for V-Ray common files.
ANONYMOUS_TELEMETRY
0 – Disabled.
1 – Enabled.
0 – Disabled.
1 – Enabled.
VISIT_SPOT3D
1 Opens the V-Ray online documentation.
0 Does not open the V-Ray online documentation.
OPEN_CHANGELOG
Specifies whether or not to open the Change Log once the installation is complete
1 – Opens the Change Log.
0 – Does not open the Change Log.
INSTALL_TYPE
0 – Workstation
<LicServer>
Silent Uninstall of V-Ray
Use silent uninstall to remove your V-Ray installation without the need for user input during the process. The silent uninstall uses a predefined set of options.
V-Ray for 3ds Max can be silently uninstalled from a console with the following command line:
C:\Program Files\Chaos\V-Ray\3ds Max 2025\uninstall\installer.exe -uninstall="C:\Program Files\Chaos\V-Ray\3ds Max 2025\uninstall\install.log" -uninstallApp="V-Ray 7 for 3ds Max 2025" -quiet=0
Where:
  • -quiet=0 is used to display the output of the silent uninstall in the console and can be omitted.
