Square Enix © Goodbye Kansas
Date – August 26, 2014
Download – No longer available
New Features
V-Ray RT CPU
  • Added support for ray tracing with Embree
Modified Features
  • Added the V-Ray version string to the .vrscene file
  • Added a -displayOCIO command-line option and VRAY_VFB_OCIO environment variable to turn on the OCIO color correction in the VFB
  • Added support for the Maya's FilePathEditor with the VRayMesh
  • Save the log file from vray(.exe) started as server in a file in the temp folder
  • Abort rendering on missing asset now works also with missing GI caches
  • Improved UI when working with sets in VRayToon, VRayDirt, VRayDistance, etc
  • Added V-Ray shelf with most things from the Create -> V-Ray menu
  • Print information about the number of lights in the scene to the V-Ray log
  • More efficient calculation of the AA mask for the progressive rendering
  • Reduced memory usage with many rectangle lights using the same texture
  • Ability to add the "Skip render" attribute to VRayObjectProperties node
  • Adjust the OpenSubdiv attribute names to be different then the standard V-Ray ones
  • Always clear the frame buffer between frames when the render mask is enabled
  • Added ability to write multi-part OpenEXR images
  • Updated the OpenEXR library to 2.2.0
  • Added popup menu for the "Post translate python script" in the Render Settings
VFB
  • Made the buttons for saving an image into a drop-down with three buttons
  • Display color corrections (sRGB, LUT etc) are now applied when writing to 8-bit color formats (PNG, JPG etc);
  • Ability to select the render camera by right-clicking in the VFB window
GLSL
  • New built-in functions: sinh, cosh, tanh, frexp, lit, fresnel
VRayVolumeGrid
  • New render controls that allow proper rendering of FumeFX imported files
VRayMtl
  • Added GGX reflection brdf
VRayCarPaintMtl and VRayFlakesMtl
  • Added reflection depth limit
XGen
  • Added ability to animate the color of XGen archives through expressions
V-Ray RT GPU
  • Take into account the AA filter settings as much as possible
ply2vrmesh
  • added an option to merge two or more .vrmesh files into one
vrimg2exr
  • The -info option now prints a message if the file is partially written
  • Added -multiPart option to that produces an OpenEXR 2 file with each render element in its own "part"
Bug Fixes
  • Transferring assets does not transfer vrsssmap files
  • EXR textures are always loaded as 32-bit floating point
  • Low precision of 32-bit tiled EXR
  • Slow rendering of subdivision surfaces in certain cases
  • Difference in interpretation of alpha when using files without alpha channel
  • Connecting an image into RectLight's alpha is not working
  • Moving a layered texture slot connected to VRayPluginNodeTex crashed Maya
  • Maya crashed if a scene was loaded while V-Ray was still rendering
  • Fixed slower rendering when using Maya's Render View compared to using the VFB
  • Progressive sampling + DR + "Don't render final image" did not finish rendering
  • V-Ray materials did not respect the display/render layers for the lights in Viewport 2.0
  • When "Use irradiance map option" of a diffuse material was turned off, Maya crashes
  • V-Ray crashed when the "Flake map size" option for the FlakesMtl or CarPaintMtl was too large
  • Fixed various issues with VRayMtl on back-facing surfaces
  • VRayCarPaintMtl and VRayFlakesMtl with flake glossiness 1.0 resulted in invalid colors
  • VRayUserColor didn't work with VRayLightMesh and VRayLightMtl material with "direct illumination" enabled
  • Exporter's memory was not deallocated with hair and "Use camera path"
  • "Use camera path" produced wrong result when used with "Camera and Aim" after beta 3
  • The dome camera didn't work with FOV bigger then 165 degrees
  • Fixed crash with spherical harmonics GI
  • Fixed wrong rendering with multiple VRaySoftbox textures on the same scene
  • Fixed crash with renderable curves
  • Fixed incorrect filter file names for V-Ray nodes in the various dialog boxes
  • Don't hide the RenderView when pressing the Stop button in the VFB and "Hide Render View" option is disabled
  • The Pause IPR button of the Render View was not working
  • The default VFB stamp font was too small on OSX
  • When proxy Alembic offset was on, animated proxies wouldn't render correctly
  • Fixed crashes with Embree in specific scene
  • The VRaySun went wild if moved along the object axis
  • Save and load dialogs didn't remember their last used paths
  • Undo didn't work for changing the material connection to VRayMeshMtl
V-Ray RT
  • Fixed slowdown with render elements when working in the viewport
  • Fixed random crashes when rendering motion blurred meshes with changing number of vertices
  • The RT server didn't start automatically on Fedora 20
  • The RT ignored VRayProxy animation when the timeline was scrubbed
  • Hiding VRayMetaballs node stopped the RT
  • Fixed crash if RT is frequently restarted
V-Ray RT CUDA
  • Fixed wrong VRayDirt in VRayExtraTex RE
  • Fixed crash with dome lights
  • Some render elements caused data shift in the wrong channel
  • The "Invert normals" option of VRayDirt had no effect on backside polygons
  • Maya Noise texture was broken with beta 3
  • Error API 700 with specific scene
VFB
  • Random crashes on Linux with the VFB history
  • Odd files in the history were saved when the save button was pressed a few times fast
  • .vrimg files without saved preview in history folder did not reflect srgb on/off state
  • Fixed the stand-alone VFB support on 64-bit Mac OS X
  • Fixed render region shift when another scene is opened
  • The VFB window was missing after you dock the panel and then reset the layout
VRayVolumeGrid
  • Disabling the diffuse color renders black smoke
  • The bounding box is not visible in Viewport 2.0
  • Slow rendering with glossy reflections
  • Failure to load the cache file when using relative paths
XGen
  • Some VRayObjectProperties were not working with xgen archives
Distributed Rendering
  • 2.4 to 3.x DR-settings translation caused wrong ports for rendering
VRayToon
  • Fixed random crashes when rendering with "World Units"
  • Rendering with "World Units" produced random artifacts
  • Line width of 0.0 produced random artifacts
ply2vrmesh
  • Fixed conversion hang with high poly count object
  • obj converted to vrmesh produced corrupt mesh in Maya when "Show whole mesh" or "Create a mesh from this proxy" were used
img2tiledexr
  • img2tiledexr and vrimg2exr don't start in GUI mode on OSX
