Square Enix © Goodbye Kansas
Date – March 10, 2014
Download – No longer available
New Features
  • New progressive image sampler
  • Extensive optimizations for render speed, especially when using brute force GI
  • The Intel Embree 2.0 library is now integrated into the V-Ray core for static and motion-blurred geometry
  • Support for OpenSubdiv subdivision of meshes
  • New streamlined installer
  • Visibility sets for reflections/refractions in the V-Ray object properties
  • VRayVRmatMtl material for rendering .vrmat/.vismat/.vrscene files; VRmat converter to convert any material to .vrmat file
  • VRayMtlGLSL/VRayTexGLSL for direct rendering of GLSL shaders with V-Ray extensions
  • Option to cache geometry plugins and bitmaps between re-renders to reduce the scene export time
  • VRaySoftBox texture for creating studio lighting
  • VRaySwitchMtl which is able to swtich materials based on a texture input
  • VRayRaySwitch texture which switches the texture based on the ray type similar to the VRay material override
  • VRayCurvature texture which computes the curvature of the underlying mesh
  • VRayTemperature texture that sets a color based on Kelvin temperature
  • VRaySkinMtl material for rendering skin
  • VRayMtlRenderStats material that can override the per shape render stats; similar to VRay object properties
  • VRayNURBSTesselation node to controll the tesselation of multiple surfaces at once
  • Glossiness render element render element able to caclulate reflection and refraction glossiness
  • "Custom color" render element to calculate color render elements with arbitrary alias
  • Phoenix FD shader is now integrated and can render Maya fluids, OpenVDB and Field3D files
  • VRayVolumeGrid node for rendering grid based volumetric formats using the Phoenix FD shader
  • Initial support for XGen with Maya 2014.5 (via vrscene exporter module, archive and hair render types only)
  • VRayLensEffects render effect for producing realistic glow and glare
V-Ray RT
  • VRay RT can be now started as Maya Viewport renderer
V-Ray RT CPU
  • Support for VRayDirt, VRayFastSSS2, VRaySkinMtl materials
V-Ray RT GPU
  • Support for most render elements
VFB
  • Ability to write deep images (OpenEXR 2/vrst/vrsm)
  • Support for OpenColorIO color correction
  • New color corrections - contrast, HSL, color balance
VRayMesh
  • Support for the Alembic file format - meshes, hair and particles
VRayPhysicalCamera
  •  Support for bitmap aperture and optical vignetting
VRayFastSSS2
  • Option for geometry-based sampling for the illumination map
  • Raytraced mode for multiple scattering
Distributed Rendering Settings
  • Options to automatically transfer and cache missing assets to the DR servers
Texture Baking
  • Support for baking to a vertex color set
  • Support for baking to PTex
vRayMetaball
  • A new geometric object to create isosurface from particle systems
Lens analyzer
  • Ability to analyze distortion in arbitrary images
Modified Features
  • Camera 2D pan/zoom feature support
  • Support for mapped light radius for point/spot/direct lights
  • Option to use different texture filtering of GI samples (in the Rendering Settings/VRay/Misc)
  • Option to abort rendering on missing asset (in the Rendering Settings/VRay/Misc)
  • Option whether to take the up axis from the Maya preferences, or to specify it explicitly (in the Rendering Settings/VRay/Misc)
  • Option to ignore shadow and light linking (in the Rendering Settings/VRay/Global)
  • Option to disable self-illumination (in the Rendering Settings/VRay/Global)
  • Option to prevent inversion of normal bump in tangent space on flipped UVs (in the Rendering Settings/VRay/Global
  • Option "Max ray intensity" to help deal with fireflies in glossy reflections (in the Rendering Settings/VRay/Global)
  • Correct "raw" render elements for easier compositing (needs the regular and the filter elements to be present too)
  • Ability to enable/disable several render elements at once
  • Option to write the main RGB render element in a sub-folder when "Separate folders" is enabled
  • Ability to abort the rendering using the vrend MEL command
  • When maximum transparency level is reached, return environment color rather than black
  • Mappable "frame offset" parameter for File nodes
  • Default jpeg quality is now 100 in the image options
  • Automatically create folders that are used in paths for saving images and vrscenes
  • Improved UI for nodes created by the "Create from V-Ray plugin" menu.
  • Support for single channel TIFF and TEX files
  • Hash ID metadata in TIFF and OpenEXR file textures to recognize identical bitmaps
  • Updated the OpenEXR library to OpenEXR 2
  • Improved motion blur raycast accelerator for fast rotating objects
VRayPtex
  • Updated the Ptex library to the latest version
  • Rewritten the Ptex library texture cache for better multithreading on many-core machines
  • Support for vector displacement with ptex textures
Texture Baking
  • Support for displacement
  • Support for subdivision surfaces
  • Support for UDIM texture baking
  • Adjustable bucket size
VFB
  • Ability to switch between the most recent images in the history using the 1-9 key
  • Ability to switch between render elements in the VFB using PageUp and PageDown
  • The history thumbnails in the VFB now have sRGB color correction if the sRGB setting is enabled
  • Added MEL command to control the VFB UI functionality
  • Disable loading images from the history while RT is running
  • Added a button to stop the current rendering
  • Added a button to reset the VFB settings (from the Render Settings)
  • Ability to dock the V-Ray VFB window
  • Ability to load arbitrary file formats in the VFB;
  • A color correction rollouts can now be hidden or expanded by clicking on their title
  • Option to automatically save each render in the history (enabled from the VFB history options dialog)
  • Option for dynamic bucket splitting towards the end of the image
  • Option to auto scale the buckets, if the user have set "Test resolution" or renders in a region
V-Ray RT
  • Support for rendering animations/sequences
  • Added an option to progressively increase the rays per pixel
  • Added an option to disable the initial image undersampling
  • Support for interactive adjustment of V-Ray user attributes
  • Optimized scene transfer to the render servers
  • Improved refresh rate and responsiveness
  • Support for chaning layers
  • "Auto-start local slave" option is now removed, "Use Local Machine" should be used instead
  • Stop RT rendering when changing the scene to leave as much system resources as possible for Maya
V-Ray RT CPU
  • Internally uses the production renderer core running in progressive mode
V-Ray RT GPU
  • Use different GPU code depending on the features used in the scene
  • Faster loading of textures
  • Reduced noise on VRayBlendMtl materials
VRayPhysicalCamera
  • Added an "auto guess vert. shift" option to keep the vertical shift when moving the camera
VRayMtl
  • Added "Compensate Exposure" option for the self-illumination
  • Added "Affect channels" option for the reflections in VRayMtl
VRayMtl / VRayBumpMtl
  • The bump amount now works with normal maps also
VRayFastSSS2
  • Ability to save/load illumination maps for VRayFastSSS2 material
VRayHairMtl3
  • Faster rendering of transparent materials
  • "Simplify for GI" is now on by default
VRayMtlWrapper and VRayObjectProperties
  • Added "Use irradiace map" option similar to VRayMtl
VRayLightRect
  • Option to preview the texture in the viewport
  • Option for directional distribution of the rectangle light
  • Added manipulator (with the 't' key) for the light target
VRayLightDome
  • Option to multiply the color by the texture
VRayIESLight
  • Optimized rendering speed
VRaySun
  • Added a filter color for the light
  • Support for animated intensity
VRayHairSampler
  • Added a "Random by strand" output
VRayFur
  • Implement curl parameter;
  • Support for animated gravity vector
  • Added "Level Of Detail" option to reduce geometry along the distance from the camera
VRayMesh
  • Ability to bring in only parts of proxy files based on object IDs or object names
  • Ability to store the V-Ray user attributes when creating a proxies
  • Ability to specify a custom preview mesh when creating proxies and from the VRayMesh node itself
  • Option the VRayMesh node to act as a "placeholder" without loading the actual file except for rendering
  • Extra V-Ray attributes to the place3dTexture node for choosing a UV set name for proxies
VRayPlaceEnvTex
  • Added an option for ground environment projection
  • Support for motion blurred Horizontal and Verticle rotation
VRaySky
  • Added possibility to override the VRaySun settings
Import from .vrscene
  • Support for BRDFVRayMtl, Mtl2Sided, BRDFSSS2Complex, BRDFCarPaint, BRDFHair3, MtlWrapper, MtlOverride
  • Support for lights and geometry
Distributed Rendering settings
  • Option to exclude the local machine from DR rendering
  • Option to disable DR in batch mode
  • Ability to limit the DR servers
  • Added field "Server alias/description" for the DR servers dialog
GI
  • Autocreate folders for irradiance map auto-save output
  • Recognize %d and %0nd format when saving and loading irradiance maps, light caches, photon maps and caustics maps
  • Ability to use tags in file names of GI maps
  • Optimized the loading of irradiance map files over the network
Extra Tex render element
  • Extra Tex render element: Ability to include/exclude objects
Matte Shadow render element
  • Added "Consider for AA" option
Object ID render element
  • Option to store the values as integers when saving exr image files
Scripting
  • Extend addSceneContent/appendSceneContent to work with environment vars and wildcards
  • Ability to export cameras with the Python Scene Access API
  • Help messages for the vray MEL command
Subdivision / Displacement
  • True Catmull-Clark subdivision mode for quad meshes
  • The default subdivision level is now set to 4
  • Support for object-space vector displacement
  • Optimized memory usage of subdivision surfaces
  • Option to cache the normals for displaced surfaces
Batch
  • Support for the "Each frame in separate file" option
Hair
  • Added options for dynamic view-dependent hair tesselation
  • Option to use a global hair tree for faster rendering with many hair systems
samplerInfo
  • Added Bump Normal, Ray Depth, Path Length, Surface Material ID, Object ID and Parent Object ID outputs
ply2vrmesh
  • Added option to specify the name of the velocity attribute
  • Added support for material IDs in .obj files
  • Support for .hclassic and .bhclassic files produced by Houdini 12
  • Support for exporting the face and vertex normals in .geo and .bgeo files
  • Support for converting multiple uv sets from .get/.bgeo files
  • Convert RealFlow bin file using the correct coordinate system
  • Support for converting alembic files to vrmesh
  • Added .prt(krakatoa) to .vrmesh convert option
vrimg2exr
  • Added an option to truncate channel names to 32 symbols
  • -Info switch to print information about render time, scene name and comments, if present
  • Increase the default buffer size to 100 MB to speed up conversions
imapviewer
  • Reduced the number of messages that are printed to the standard output
Bug Fixes
  • TexSampler is exported in the main .vrscene rather than the textures one
  • VRay Extra Attributes are not dimmed properly in some cases
  • VRayBlendMtl doesn't do clamping on the amount textures;
  • VRayBlendMtl should propagate the "Use irradiance map" option from the base material;
  • VRayBumpMtl not working with VRayMtlSelect render element
  • Material override doesn't work with VRayHair2, VRayHair3, VrayBumpMtl
  • VRayPTex does not work properly when it is inside a switch texture
  • VRayStereoscopic: Linux builds generate wrong .vrst shademaps
  • Problem exporting custom nodes with more than one 3darray parameter
  • The "Use 3d mapping" parameter for the custom texture nodes must be off by default
  • VRayPlaceEnvTex is not created for the dome light when the attribute editor is closed
  • Instancers and light linking are not exported properly when using plugin name prefix
  • Bitmaps are loaded even when Maps option is disabled
  • Crash with 2D displacement when "Static displacement" is turned on
  • Clamped displacemend with layered texture and negative values
  • Maya Camera Film Offset parameter doesn't update during rendering animation
  • User attributes with multiple underscores are not exported properly
  • User attributes of the form vrayUserColor_ are exported multiple times for the red/green/blue child attributes
  • "cameraAperture" is always written as 36 in the OpenEXR meta attributes
  • Incorrect calculation of normal vectors for motion blurred subdivision surfaces
  • ExtraTex render elements with filtering disabled produce odd results on transparent objects
  • LightSelect render element doesn't work correctly through reflections with Ward and Phong BRDFs
  • Multimatte render element with all IDs set to the same number renders as blue instead of white
  • Velocity render element: Lights do not contribute any velocity information
  • Render elements names cannot be changed from the Render Settings dialog
  • Undo delete render elements is not updated in the Render Settings dialog
  • Fixed rare crashes with tiled textures and dynamic geometry when the dynamic memory limit was reached
  • Layer Overrides for the AA filter size don't work
  • Wrong image file name when "images" name in Maya Project Window is empty
  • Issue with animated visibility of the vray lights
  • SGI files are read without alpha channel
  • Wrong render results of mipmapped TEX file format in the last mip-map level
VFB
  • Do not show if the scene was saved without opening the VFB first
  • Fixed crash with curve color correction when there were NaN pixels in the image
V-Ray RT
  • Crash with "Keep bitmaps between renders"
  • Crash when changing shaders connected to PTex textures
  • Crash when changing properties of VRayObjectProperties node applied to mesh with contruction history applied to it
  • RT ignores the Cast Shadows toggle of VRayFur
  • RT doesn't detect changes to global camera FOV override
  • CarPaintMtl uses much more RAM in RT than in production
  • When changing the Material ID attribute, RT GPU is not refreshing
  • RT ignores displacement control attributes applied to the VRayDisplacement node
  • RT fails update correctly, when the creation of a light is undone
  • RT does not react to changes in the camera environment color
  • Modifying a material assigned to an object and a face causes the object to disappear
  • Crash with RT after clearing script editor history
  • Crash with bump map connected to VRayFastSSS2
  • RT doesn't detect changes to specular and diffuse contributions for standard lights
  • Stereo mode did not work correctly
V-Ray RT GPU
  • The "Camera Scale" attribute is ignored
  • The standalone crashes when trying to render a 16000x16000 texture on the GPU
  • Fixed issues with Multi/Sub-object materials on dynamic geometry (instances)
  • Wrong environment overrides in GPU when swapping or disconnecting textures
  • RT/GPU is not refreshing when changing the Material ID attribute
VRayMtl
  • The "Fix dark edges" option has no effect
  • Dispersion uses the full subdivisions for GI rays increasing the render time
  • Wrong color in the refraction filter render element when the diffuse is black
VRayFur
  • Error with projected textures
VRayStereoscopic
  • Linux builds generate wrong .vrst shademaps
VRayMesh
  • 'Show whole mesh' doesn't reconstruct the colour sets
  • Importing vrmesh file containing lots of material ids makes the attribute editor slow
  • Caches from previous frames must be cleared in batch mode
  • Proxy is not renderable if created with velocity interval start/end is 0/0
  • Deleting history on proxies erases the VRayMesh nodes
  • The proxy import/create command doesn't execute correctly in Maya non-GUI mode
VRayLightSphere
  • Scaling doesn't affect Intensity and Radius parameters
VRayVertexColor
  • "Set Name" for "Type" works only when VrayVertexColor has connection with the material of the object
Texture Baking
  • Region rendering must be disabled in texture baking mode
VRayPhysicalCamera
  • Gizmo scaling reflects on the brightness of the output
  • The camera should not lock "Fit Resolution Gate" parameter of the Maya camera when "Specify FOV" is "From Maya camera"
VRayFastSSS2
  • Fixed the greenish tint; controlled with a"legacy mode" option
  • Artifacts at very small scene scales
  • V-Ray steps one frame forward when velocity render element or motion blur is used in DR
nParicles
  • Randomly missing particles in specific scene when motion blur is off
Batch
  • V-Ray log message level setting is not respected in maya batch render
Hair
  • Artifacts with very thin strands
  • Strands with width less than 0.001 don't render correctly
samplerInfo
  •  The normals outputs are not correct for rays that don't hit anything
Spot Light
  • Barn doors are rendered flipped
Viewport 2.0
  • Incorrect gamma with VRay materials
