Page Contents ×
This page gives some details on what hardware and operating systems are required for V-Ray to work properly.
Windows
Please make sure that your system fulfills these requirements before installing V-Ray. Note that V-Ray is only supported for 64 bit operating systems and 64 bit versions of Maya.
Processor
Intel®1 64, AMD64 or compatible processor with SSE4.2 support
RAM
4 GB RAM and 4 GB swap minimum – recommended 8 GB or more RAM, 8 GB or more swap file;
(Actual amount required will vary with scene requirements.)
USB PortRequired for customers using legacy hardware lock, preferably USB 2.0
TCP/IPOnly IPv4 required for distributed rendering is supported. IPv6 is currently not supported
GPU Acceleration
NVIDIA CUDA: Maxwell-, Pascal-, Volta-, Turing- and Ampere-based NVIDIA card(s) with with latest recommended video driver;
NVIDIA RTX: RTX cards with latest recommended video driver ;
V-Ray Production Denoiser: AMD or NVIDIA GPU supporting OpenCL 1.2;
NVIDIA AI Denoiser: Maxwell, Pascal, Volta, Turing or Ampere-based NVIDIA card with latest recommended video driver
The minimum required compute capability is 5.22
The following table shows the versions of Autodesk Maya and operating systems on which V-Ray is supported. Note that V-Ray is only supported for 64 bit operating systems and 64 bit versions of Maya.
Version of Maya Supported Operating System
Maya 2019Windows ® 8.1, Windows ® 10 Professional, and Windows® 11
Maya 2020Windows ® 8.1, Windows ® 10 Professional, and Windows® 11
Maya 2022Windows ® 10 Professional and Windows® 11
Maya 2023Windows ® 10 Professional and Windows ® 11
Linux
Processor
Intel® 64, AMD64 or compatible processor with SSE4.2 support (x64)
RAM
USB PortRequired for hardware lock, preferably USB 2.0
TCP/IPOnly IPv4 is supported. IPv6 is currently not supported
GPU Support
NVIDIA CUDA: Maxwell-, Pascal-, Volta-, Turing- and Ampere-based NVIDIA card(s) with latest recommended video driver;
The minimum required compute capability is 5.21
Maya 2019Red Hat ®  Enterprise Linux® 6.5 and 7.2 WS, or CentOS 7.2
Maya 2020Red Hat ®  Enterprise Linux® 7.3, 7.4, 7.5, 7.6, 7.7 WS, or CentOS 7.3, 7.4, 7.5, 7.6, 7.7
Maya 2022
Red Hat® Enterprise Linux® 8.2, 7.6-7.9 WS, or CentOS 8.2, 7.6-7.9
Maya 2023Red Hat® Enterprise Linux® 8.2, 7.6-7.9 WS, or CentOS 8.2, 7.6-7.9
macOS
Processor
Intel® 64, AMD64, ARM 3 or compatible processor with SSE4.2 support (x64)
RAM
 V-Ray GPU works only with C++/CPU devices under macOS. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s).
Version of Maya
Supported Operating Systems
Maya 2019Apple ® macOS ® 10.14, 10.13, 10.12 and 10.11.x
Maya 2020Apple® macOS® 11.x, 10.15.x, 10.14.x, 10.13.x
Maya 2022
Maya 2023
Apple® macOS® 12.x, 11.x, 10.15.x, 10.14.x
* The Autodesk Maya system requirements can be found here page: http://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/System-requirements-for-Autodesk-Maya.html
For additional information on hardware, see the Hardware Recommendations article.
1Windows 11 is required for running Intel Alder Lake processors.
2 – CUDA compute capability and card reference
3. – ARM support for versions prior to and version Maya 2023 is translated through Rosetta.
  • V-Ray for Maya 2022 supports Python 3 by default. Builds with Python 2 support are available in the stable folder of the nightly server.
