Square Enix © Goodbye Kansas
Official Release
Date - July 03, 2019
Download - Build 4.12.02
New features
SamplerInfo
  • Added a random by scene name mode to the sampler info additional outputs
Modified features
V-Ray
  • Better sampling with few lights in the scene
  • Texture filename will be printed if a tile fails to load for tiled textures
VRayProxy
  • Faster loading of VRayMesh nodes in bounding box mode
  • Increased the size of VRayMeshMaterial's shaders list control
  • Ability to change visibility for multiple selected objects in the VRayMesh visibility lists
Cryptomatte/VRayProxy
  • Fixed wrong manifest in Sub object name mode
V-Ray IPR
  • Optimized defaults for CPU IPR
Bug fixes
V-Ray IPR
  • Fixed wrong first frame when playblasting
  • Fixed sampling artifacts with few lights in the scene
VRayHairMtl
  • Fixed VRayHairMtl not composing back properly with consistent elements enabled
VRayEnvironmentFog
  • Fixed environment fog not composing back properly with consistent elements enabled
  • Fixed incorrect lighting with Environment fog and V-Ray Light Linker
Cryptomatte
  • Fixed AA on multi-material objects when using material mode
  • Fixed wrong Cryptomatte channel name when using DWA compression
XGen
  • Fixed XGen not working on macOS when V-Ray is loaded before the XGen plugin
VFB
  • Fixed saving to EXR from the VFB not saving the whole image when rendering a region
  • Fixed a crash when saving from the VFB when using V-Ray Standalone
VRayLightSphere
  • Scale was ignored when transform was controlled with an expression
VRayFur
  • Fixed wrong texture projection with V-Ray Fur
AppSDK
  • Fixed license issue when rendering through AppSDK on Windows
VRayScene
  • Fixed visibility option not being respected when in a group
Maya batch
  • Fixed "-im" command-line override not working with Render Setup layers
VRayTriplanar
  • Fixed Triplanar appearing in the wrong category inside the Create Menu
V-Ray
  • Fixed crash when rendering zero-sized regions with Light Cache
  • Fixed a crash when closing Maya on macOS High Sierra
V-Ray GPU
  • Fixed UDIM textures rendering black in IPR with on-demand mip-mapping
Chaos Cloud
  • Fixed cloud button not working on older Maya versions
