Square Enix © Goodbye Kansas
This page provides information about the vray gpuDeviceSelect command in MEL.
This command makes a list with the available GPU device(s) and/or sets such to render with V-Ray GPU directly through MEL.
Syntax
The vray gpuDeviceSelect runs in the following way:
vray gpuDeviceSelect <engine_type > [list [-all | -enabled] | set <list_of_devices>]
To type all the available options you can run the command with help argument:
vray gpuDeviceSelect -help
vray gpuDeviceSelect help
ArgumentDescription
engine_typeSelects the engine type, where "0" is not considered, "2" is for CUDA and "3" is for RTX.
list
Lists:
-all - All available NVidia devices;
-enabled - Only enabled NVidia devices.
setSets which NVidia devices to use with V-Ray GPU render.
The CPU can also be used as a CUDA device with V-Ray GPU.
Examples
List enabled devices:
vray gpuDeviceSelect 2 list -enabled
This command will return a string array with all enabled NVidia devices.
Set CUDA device for render:
vray gpuDeviceSelect 2 set "NVIDIA CUDA GeForce GTX 750 Ti GPU index0"
Set CUDA devices for render:
vray gpuDeviceSelect 2 set {"NVIDIA CUDA GeForce GTX 750 Ti GPU index0", "NVIDIA CUDA GeForce GTX 1080 GPU index1", "c++/cpu"}
Set RTX device for render:
vray gpuDeviceSelect 3 set {"NVIDIA CUDA Quadro RTX 4000 GPU index1"}
